Key Strengths:
- No rubber, foam, or plastic pieces to degrade in the sun.
- No part of the rack contacts the frame of the bike.
- Folds up small enough for any trunk.
- Small fold-up size allows for storage anywhere – even the floor of a small closet.
- Very sturdy. Zero wobble in the hitch (2-inch version)
- No assembly at all. Just take it out of the box and insert into hitch.
- Very solid, extremely well built to last
- Easiest rack I’ve ever used to fold up, rock back, install on vehicle, add/remove bike, even assemble cause it comes assembled!
- Doesn’t stick very far out (can close garage door without removing or folding up)
- They shipped the same day from order
- Can run with just 1, and easily throw the add-ons for 2 more when I take my kids riding
- The rack looks awesome with its materials and construction
- Just an ingenious design for compactness and modularity
Weaknesses:
- 2 rack system is a bit heavy at 50 lbs.
- Not cheap and a bit more expensive than the competition
- Can block license plate when folded up
- Very small company and customer support delays have been reported
- Lever mechanism can be stiff and creaky
- Opening the second arm can require three hands since the bike needs to be supported from falling.
Bottom Line:
We’re really stretching here to find weaknesses as this is one of the best designed racks today. In the areas where it really matters, ease of use and out of mind, this rack is a home run.
What do you think? Can you compare this to others that you’ve tried?
I have been looking for a new rack. This would be perfect if the height when folded could be adjusted as to not block the license plate of a pick up. My ancient Yakima gets me pulled over without bikes and that’s a square tube blocking 2 1/2″ of the plates center.
move the license plate maybe…?
I bought one of these after several encounters with the Yakima warranty dept.(he asked me if I was using my rack during the winter,What is that?)
Hauled my 50lb Sinister R9(long) no problems. Best money I ever spent,IT IS!!!!!
I use a bungy to hold the second lever up. I just then hold the tire to remove the bike.
Used Yakima, Thule and Kuat. 1up has been great on ALL front and way better anytime.
Sylvain
I love mine, I had another brand on the back of my Samurai but it bounced so much it wore through the rubber and scratched my Fargo frame ( unacceptable, it’s a constant embarrassment). The One-Up works great and takes the horrible Samurai suspension in stride. Plus it’s from Wisconsin what could be better?
Went from a Kuat NV to the 1up. Loved the Kuat, but I think the 1up is my soulmate.
I toohave 20 and also 16 and the fit works perfectly. Just make sure you followinstrcutions and place the bike inthe middle so the arms are “evenly” used on each tire.
Does anyone know how well smaller bikes fit? I have a couple bikes with small 20 inch wheels. Also, how about recumbent bikes?
Hey, where is APBT LVR (1st pic) ? Haven’t seen him and his dog Ruby over on the fatbike forum lately.
Francis: If you just roll the bike to the left or right, or turn the handlebars slightly, when loading or unloading, the entire “three arm problem” goes away. For any readers, this is as easy as any other mount I have ever used.
To be specific, open the arms to the vertical or slightly past vertical position. You will learn in one try what works best for your specific bike(s). Load the rear wheel then either rolling your bike a little further backwards or twisting the handlebars, load the front wheel. Center the bike, then holding the bike with one hand, use the other to close/compress the arms, one at a time.
The mechanism to tilt the rack is a bit awkward to reach, but once you are used to it, it uses much less effor than the Thule mechanism.
Hope this helps.
