2011 SRAM XO Groupset
News
Truvativ GXP Bottom Brackets:
bottombrackets
Overview:
“Welcome our new Gutter Seal Technology! Gutter drastically improves sealing against the elements while reducing seal drag. We’ve designed a fresh new cup forging for a new high-end look. A new standard in external bearing performance!”
* Gutter Seal Technology
* Improved tool engagement
* Sealed cartridge bearings
* English or Italian threads
Ceramic – Ceramic bearings. Red Ano finish
Team – Custom steel bearings. Tungsten finish
XR – Custom steel bearings. Black finish
Code R Brakes:
code_r
code_brakes
Overview:
“BRINGING POWER TO THE PEOPLE.”
“Code’s little brother just got tougher. With an all new, forged dual-diameter, four-piston caliper, Code R offers increased power without compromising control or feel. With a simplified design to make it a little easier on the wallet, Code R maintains the Code family values of reliability, strength and ridiculously easy serviceability. Now featuring the fade-free braking of TaperBore Technology and the sleek yet oh-so-powerful integrated reservoir on top of Avid’s proven Power Reserve Geometry™, the Code R will make you think before you call this brake anyone’s “little” brother.”
Specifications:
Weight 395 grams (160mm rotor; front post mount)
Lever Material Aluminum Lever, 3-cartridge Bearing lever pivot
Caliper Design 4-Piston, Dual-Diameter, Forged 2-piece
Finish Graphite Grey, Lever: Aluminum
Rotor G3 CleanSweep 160mm, 185mm, 203mm
Pad Organic, Top-Loading
Fluid DOT 5.1
Mount Ambidextrous
Adjustment Tool-Free Reach Adjustment, Adjustable Banjo, Tri-Align Caliper Positioning
Special Features TaperBore Technology
Reversible,break-away lever, Split Clamp, MatchMaker compatible
Technology TAPERBORE TECHNOLOGY, DEEP STROKE MODULATION, POWER RESERVE GEOMETRY™, TRI-ALIGN™ CALIPER POSITIONING SYSTEM™, BEND ZONE, INTEGRATED RESERVOIR, DOT 5.1, TOOL-FREE REACH ADJUST, TOP-LOADING PADS, MATCHMAKER COMPATIBLE
More info: XO on SRAM’S website
About the author: Gregg Kato
Gregg Kato studied journalism and broadcasting in college while working many different jobs including deejaying, driving a forklift and building web sites (not all at the same time). Kato enjoys riding local Santa Cruz trails. Besides being an avid mountain biker, he is also a motorcycle fanatic. Two wheels, one Passion.
Wordpress Comments:
  • DaGoat says:
    Yeah, but what we really want to see is the XO 10Spd Grip Shift! No XX in my whirld until that happens! I know… “soon”!
  • Brian says:
    Have installed the entire system on my 07 IH Mark III 5″ trail bike. Having come from the 3×9 system (Fnt 22/32/44 & Rear 11-32) and multiple riding trail with a complete mix of gradual and steep climbs, fast flats and rough and fast down hill trails, I was skeptical of the range that the 2×10 system would offer. Probably, the hardest decision was whether to commit to the 26/39 front or the 28/42 option. I based my decision off of simple math with my common gear choices used on my 3×9 for each extreme. For extremely hilly stuff I could do it fine in the 22 front ring & 28 rear cog; thus, I equated the 2×10 option equivalent to be 28 frt & 34 rear. Therefore, I knew that 28/36 would make a bit easier than 22/28, but could not quite equal my previous option of 22/32. So, far I’ve found myself using the 28/32 for gradual climbs and 28/36 on the steep stuff. I actually think that a 27/42 option would have been even better. For the front, I’ve found that the 42 ring with 11-36 10 spd option in the back has been a pleasant change from jumping back and forth from the middle to big ring with the 3×9. Pretty much, I stay in the 42. Until I get to the climbs or approaching the 36 cog, then I drop down to the 28 up front. I find myself only using the largest 3 cogs in the back with the 28 up front while climbing. Anything else gets done in the 42. I must note that the shifting performance is absolutely crisp and perfect each time. And for the mechs like myself, initial set up and fine tuning the install is quite simple. Only hard part is guestimating how much the front derailleur will turn as you tighten down the clamp bolt. It’s final tightening turns it toward the rings, so you have to loosen push it back in the oposite direction slightly and try again until the final clamp torque gets the guide parallel with the rings.
    Note: I matched all the XO drivetrain to a XX Cassette and 1091R chain.
    For those still wondering whether to make the 2×10 leap, if you find the 2×10 too expensive and don’t mind the extra shifting up front then stick with 3×9. If you’ve decided to take the leap to 2×10 then use the 28/42 & 11-36 for those with strong legs or the 26/39 & 11-36 for everyone else or if your trails continue to send you heading up more than down.
  • Eric says:
    Just installed full silver (“Bling!”) x0 drivetrain on my RacerX 29er. I think it looks better than XX. Can’t say that I have ridden XX, but this certainly shifts better than anything I’ve ever been on. I was a bit hesitant about getting rid of a 22/34 low gear on a 29er for a 26/36, but I have found the 26/39 adequate for the short quick climbs we have around here. In areas with more extended climbs, you should keep a triple, especially on a 29er.
    I use the 39 virtually all the time and find my speed around familiar trail areas is much higher, and braking is becoming more important. I think the mid and outer rings were just leaving too big a gap for me, and a 39 is the perfect ‘sweet spot’ for most of my riding, especially when you throw in a few big cogs to keep you in it longer. Even going from a 32t mid ring to a 39t big ring, I stay in the 39 about the same amount of time as the old 32.
  • ika sw dikromo says:
    Sram xo speed 10 group set is very okay
