2013 Pivot Cycles Bike Lineup
26er 29er News
2013 Pivot Phoenix DH
The Ultimate World Cup Downhill Bike with the heritage of Dave Weagle’s 6 world Championships behind it.
Suspension:
  • dw-link suspension design with position sensitive anti-squat
  • 8.15” (207mm) rear Travel
  • The Phoenix is designed to have an ultra plush feel and compliance exceeding that of the world’s best downhill bikes. However, it also has a distinct advantage in overall control and pedaling efficiency. Square edge bump absorption is incredible and the suspension remains stable and controlled in even the most extreme conditions.
  • Although based on the World Championship winning Sunday, the Phoenix is not a Sunday! The Sunday took the concept of using a position sensitive shock as a bottom out device. Phoenix DH shares a similar leverage ratio curve for the first part of the travel, and then remains slightly progressive through the end travel (The opposite of the Sunday). The Phoenix DH runs slightly higher spring rates and a curve that is more in line with what we developed for the Firebird.
Geometry and Handling:
The Phoenix DH features a 64 degree head tube angle, 13.6” BB height, and 17.25 Chainstay length.
Dropouts are changeable and will allow for a change in chainstay length. The removable dropout option offers a lot of flexibility to tune the bike to the rider and the course.
Adjustable Head Angle:
The Phoenix DH headtube is indexed and head angle is easily adjustable at 0, and +/- ½, or 1, degree settings via the Cane Creek Angleset design.
All frames have indicators on the headtube for Angleset locating and come stock with 3 different Cane Creek Angleset cups
Lower Center of Gravity:
The shock and main linkage are mounted as low as possible in the frame. The shock housing/main pivot/bottom bracket area are designed to allow easy access to all damping adjustments on the Fox RC4 shock.
The Phoenix DH’s low center of gravity and low BB give the bike excellent cornering and handling characteristics. Combined with the dw-link design’s position sensitive anti-squat, we can achieve the handling and cornering benefits of the lower bottom bracket without the negatives of a low BB height on other designs.
Frame Stiffness:
  • As with all Pivot frames, frame stiffness and durability are a key part of all our designs. The Phoenix DH takes this to a whole new level.
  • 1.5 Headtube with massive oversize thin wall hydro-formed downtube.
  • 2 part hollow BB/seat tube/main pivot forging is both lightweight and incredibly stiff. Plus all front triangle pivot locations are machined on one part, making the pivot locations extremely accurate.
  • Rear swing arm features two piece hollow forged box uprights. The rear triangle is stiff and accurate with all pivots being located on the main uprights. This design is incredibly stiff and lightweight.
  • Lower link uses 17mm diameter main pivot pins and double row EnduroMax bearings for maximum durability and frame stiffness.
  • The upper linkage features 16mm diameter hardware and double row EnduroMax bearings for maximum durability and frame stiffness.
Design Details:
  • Optimized lightweight design. Complete test bikes are sitting at 39lbs. Team bikes weigh under 37lbs.
  • Standard 83mm Threaded shell with ISCG mounts.
  • 150mm rear spacing with 12mm through axle.
  • New Fox RC4 Kashima coated rear shock
  • Two frame colors with multiple decal color options. White comes stock with Blue decals (Orange and Green are included). Black comes stock with Green decals (Blue and Orange are included).
  • Frames are a painted with a highly durable powder coat finish.
Pivot Bike Lineup Photo Gallery »
