2013 Pivot Cycles Bike Lineup
26er 29er News
2013 Pivot M4X
Suspension:
  • dw-link suspension design with position sensitive anti-squat for superior pedaling and out of the saddle sprinting performance.
  • 4” (100mm) rear Travel
  • The M4X is designed to have an ultra firm feel to hold the suspension up in the travel while railing corners and boosting jump faces.
  • New Adaptive Logic RP23 Kashima shock with custom tuned Rebound and Propedal settings: New Rebound settings offer twice the number of adjustment options for more precise tuning of the rebound speed. Boost valve and compression tuning are M4X slalom/dirt jump specific.
Geometry:
2 sizes (short and long). Stable geometry for handling high speed runs.
Size STL TTL HA SA BBH CSL HTL WB Fork
S 15″ 22.3″ 67.5 72 12.5″ 16.5″ 4.5″ 42.1″ 100mm
L 15″ 23.5″ 67.5 72 12.5″ 16.5″ 4.5″ 43.3″ 100mm
Frame Stiffness:
  • As with all Pivot frames, frame stiffness and durability are a key part of all our designs. The M4X takes this to another level.
  • Large diameter tubing based off the Firebird specifications.
  • Double upright tubes on rear triangle and large tubular cross brace
  • New Lower dw-link based off Phoenix lower link design places larger double row bearings at an even wider placement for the main pivot.
  • Hollow box one piece BB and main Pivot assembly further increases stiffness and accuracy.
  • 142 X 12mm through axle design
  • New forged 7075-T6 derailleur hanger with integrated axle nut.
Design Details:
  • Tapered 1.5” Headtube
  • ISCG 05 mounts
  • 73mm threaded BB shell compatible with all threaded BB designs for maximum compatibility with products in the long travel trail/gravity category.
  • 142mm rear spacing with 12mm through axle.
  • Additional cable routing for dropper seat posts.
Racing:
The New Pivot M4X has already been ridden to numerous podium finishes in slalom including a bronze medal at Crankworks and winning the best trick competition at the Claymore Challenge.
Pivot Bike Lineup Photo Gallery »
