2013 Scott Genius 700 – 650b Ride Report
27.5 All Mountain Trail
Let’s face it, trails have evolved. No matter what trail you ride, you want a bicycle that can handle anything, and do it well. Whether it’s that epic singletrack that you look forward to riding over and over, or that tough uphill that leads to a fun or demanding descent. That was the spirit of the very first mountain bikes and that’s what this evolution of the trail bike represents; one bike to rule it all. The Genius is full-suspension chassis that’s designed to handle Any Trail, Anytime. It is the most capable trail bike ever produced and offered in two unique forms. The Genius 900 has 130mm of travel and all the benefits the 29″ wheel has to offer without the negative effects that forcing too much travel onto the wheel size incurs. The Genius 700 utilizes an entirely new wheel standard that is positioned nearly between 26″ and 29″. The 27.5″ tire/wheel combination offers the benefit of improved roll over trail obstacles and increased traction, like 29″, but without travel limitations. Because of this we can offer it in 150mm.
10 Years ago, Scott conceived the Genius, the first “Do-it-All” super-lightweight carbon trail bike. From inception, it was developed for the trail rider who desires a bike that possesses proficient uphill performance while remaining capable on demanding technical trails and descents. The Genius shock produces three unique modes – Lockout, Traction and Full travel. Scott’s invention of TracLoc in 2004 transformed trail riding in that it made the rider think carefully about the bikes attitude and the efficiencies offered when three unique modes are available right at your fingertips to control the rear shock. Then with TwinLoc we added front suspension into the mix giving the rider full control of the shock and fork with one switch. Often imitated, there is no substitution for the total control TwinLoc offers. Today’s mountain biker has evolved, and so has Scott’s approach. Our engineers have totally re-invented the Genius, and the new 700 (27.5″) and 900 (29″) series of Genius take Trail Riding to the next level. It’s been 10 years since the first stroke of Genius, it’s about time we change the game, again.
Key Features:
  • Travel to wheel size optimization
  • Improved Linkage and OS Pivots
  • Nude2 compression style shock with DAS
  • TwinLoc – One Lever, Total Control of the Shock and Fork
  • IMP Frame
Wheel Size Technology
With three wheel sizes to choose from it’s best to find the size that suits your needs rather than becoming hung up on a diameter. Once you’ve chosen type of bike you want, look at the geometry to be ensure the fit works for you while the travel suits your riding style. Bigger can be better, but only until the travel reaches a certain measure. See the research below. Improved roll-over effect is the most prolific attribute when it comes to 29er wheels. The big wheels are great for rolling over nasty roots and rocky sections, essentially making it easier to ride these conditions. Improved traction is also a key factor with the increased wheel diameter compared to 26″ wheel’s as tire contact to the ground is larger. When discussing the pros and cons of the big wheeled bikes, shorter riders find themselves in an ambivalent situation; They want to benefit from the 29″ wheels, but suffer from the negative effects when fit is considered. Additionally, the increase in rotational weight challenges many lower watt-producing riders, so the performance gains are negated when the rider cannot accelerate the wheel system as quickly.
Frame Technology
Scott has always been a leader in Carbon frame technology, going way back to the Endorphin in (1992) which was one of the first Mountain Bikes made completely of carbon fiber. In 2003 Scott Engineers revolutionized frame construction with the CR1 Process. This was procedure of creating individual tubes with the layers completely managed in order to avoid wrinkles and gaps between the layers, as well as mitering the joints and Carbon Welding them.
Highlights for the New Genius Frames
Molded Oversize Bottom Bracket
The PF BB 92 bottom bracket is molded using our IMP technique. Because its shape is optimized to manage the main pivot load and seamlessly interface with the down tube it offers much higher lateral stiffness so that riders’ pedal input is efficiently transferred into torque.
Forged Mono ‘U’ Link w/ Geometry Adjustment
The newly designed Mono Link is low profile and able to handle the loads of a harder hitting Trail Bike. The link is more solid than the one used on the Spark with an additional bridge incorporated in the design while the bearings have been moved outboard into the seat stay to widen and stiffen the link. The link also features adjustable geometry by way of a shock mount chip. Simply flip the chip to either mounting position to affect the bottom bracket height and head tube angle by 6mm 0.4 degrees respectively. The Genius is the only Trail Bike on the market that offers this feature.
IDS -SL Dropouts (Interchangeable Dropout System-Super Light)
Interchangeable and lightweight, the IDS-SL dropout system works with 142x12mm, 135x12mm and 135x10mm QR rear axle standards. Shred the turns more aggressively and with enhanced control, because the rear end is laterally stiff.
Tapered Head Tube
The Genius features a tapered head tube for a seamless joint to the oversized down tube. This increases stiffness, safety, durability, and control.
Oversize pivots
Increasing the pivot diameter better manages loads, and in turn increases the lateral stiffness of the frame. Because of this, we’ve upgraded the pivot axle sizes to match those used on all of our current suspension bikes.
Direct Post Mount
We’ve saved even more weight by eliminating bulky brake hardware for mounting the rear caliper and integrated a direct post mount to the chain stay. This mounting position also decreases the load the brakes apply to the swingarm parts.
Internal Cable Routing
Routing the cables internally saves weight by omitting bulky hardware and looks cleaner. The cables can endure a longer lifetime as they are hidden from view and protected within the frame.
Chainblocker and ISCG Mounts
The chainblocker plate protects the frame from “chainsuck” by blocking it from falling off the inner ring and damaging the frame. The system is compatible with 3x and 2x front drives. An optional ISCG adaptor allows riders to run a chain device for single or 2x chain set and is removable to leave a clean, light mainframe when not in use.
Suspension Technology
TwinLoc – the Lever for Total Control
The patented TwinLoc system is found on the all of our full suspension mountain bikes. TwinLoc now features Traction mode on both shock and fork so you can choose between Lockout, Traction mode and Full mode options via handlebar-mounted switch. This is perfect for Climbing, Riding and Descending. With One Lever you have Total Control of the shock and fork simultaneously.
There are two types of suspension management:
LTD is only available on Scott bicycles equipped with our DAS (Dual Air Spring) suspension technology. This unique suspension design allows for a static Lockout, available via our TwinLoc switch on the handlebars. It also offers “Traction” mode. This mode offers a unique geometry and travel adjustment because of the air volume adjustment via DAS. This differs from a ‘Platform’ that does not allow for a unique travel setting and spring rate. Descend mode is another unique travel and geometry setting for the bike adjoined by the full travel the bike offers.
LRD continues to use the TwinLoc switch, but the ‘Ride’ mode is a platform only and does not offer a geometry adjustment or a travel setting. You still get three settings, but not three unique bike characteristics. LRD is offered on models equipped with aftermarket suspension, like FOX.
Nude2 Rear Shock
The second evolution of our Nude rear shock gains performance and technology while remaining lightweight. It works exclusively with our patented TwinLoc system and comes stock on both 27″ and 29″ versions. The Nude2 is a completely new shock with an improved air spring and damping system. The shock possesses a more progressive damping curve and mode sensitive damping than its predecessor. This means that both travel modes have separate damper settings relative to their travel length and effective forces. When collecting data for the Genius project, we also calculated rider input data, including forces such as the rider’s gyro-scoping pedal stroke and its’ effects on the suspension. We simulated a rider’s pedaling and jerky motions made while pedaling or clearing obstacles, and measured their influence on the suspension. Many other designs assume that a rider is static and coasting, or they only include acceleration forces on the suspension and drivetrain. We are more concentrated on suspending the movement of the rider instead of negating pedaling forces.
Front Suspension
We worked with our suspension partners, both FOX and RockShox, to build forks with damping that matched our rear shocks. All Genius 700 and 900 series bikes offer mode sensitive damping front and rear and work with our TwinLoc switch.
Wordpress Comments:
  • duder says:
    beautiful bike with a lot of quality bits and geo, but meh on a single pivot
  • PROEDGEBIKER.COM says:
    Looks like a spark
  • duderabides says:
    Meh, I’d ride a single pivot…..nothing wrong with ‘em. Bike looks great. Well done, Scott.
  • Wasupwitdat says:
    And my bikeshop guy said 650b wouldn’t go anywhere. I turned my Spark into a 650b two years ago and never looked back. Also dumped the Nude shock for a Fox RP3. That Nude shock sucks. The Fox is fantastic. Scott must be using a 29r fork because Fox hasn’t made that leap to 650b yet. I went with a White Bros. The bike is a dream now.
  • Izzy says:
    “an entirely new wheel standard”
    It’s statements like these that is fodder for 650B critics, and doesn’t help the 650B-ignorant.
    I’m still not a fan of switches. I went SS to simplify things. If I were to go full sus I’d rather go with a design that doesn’t require extra switches or levers to make it more efficient.
    That said, everything else on the new Genius screams engineering art. I love that linkage, and the dropout system is way cool. I also like how clean the rear brake mounting is. However, I’m no suspension expert, so this leads me to ask, how will this affect braking on this single pivot design?
  • Brad says:
    This is the future thanks scott
  • professore says:
    So far the best looking bike I’ve seen. I love how the linkage disappears. Well done Scott.
  • Daniel Owen says:
    Izzy, when you ride a single pivot bike you just don’t use the back brake as much,,, makes you a much faster rider,,, and anyway, with small rotors it should should not “brake jack”…. but SP do climb well as the tend to dig in…
  • SpruceHead says:
    Was this written by MTBR or by Scott? Anyone else concerned about snagging something on those cables hanging off the BB?
