No. 1 component upgrade? A set of shiny new wheels. Lighter, faster and stronger are all potential gains when you swap out your old hoops. And what better time to do so than around the holidays. So whether you're buying for a significant other - or just sprucing up your own rig, here are eight great mountain bike wheels - plus two amazing tires to wrap around them.
Mavic Crossmax XL Pro LTD Wheel-Tire System
Famed French wheel maker Mavic takes a holistic approach to development, paying careful consideration to how wheel and tire work together as one. The Crossmax XL Pro LTD Wheel-Tire System is a shining example of this process. The 23mm internal width rims are designed to be more impact resistant, while ISM (Inter Spoke Milling) machining reduces weight and inertia. The end result is a wheelset that's playful, easy to handle, and helps you save energy whether speeding up or slowing down. Meanwhile, the Mavic tires serve the specific needs of the front and rear wheels. Up front the Crossmax Charge XL has an aggressive tread profile with large and high knobs, excellent mud clearing, and a soft compound for better grip. The rear-specific Crossmax Quest XL has a shallower profile, with smaller knobs, and the new X-mix dual compound for fast rolling performance, better traction, and confident cornering. Both tires use a dual ply casing for solid durability at a competitive weight. Claimed wheelset weight is 1710 grams sans tires. Price: $1000 | More info at www.mavic.us
Nox Composites Kitsuma 27.5 Carbon Fiber Wheels
For those days when durability and confidence in your gear is essential, the Nox Composites new Kitsuma 27.5 carbon fiber wheel is a great choice. All Nox Composites hoops feature UniWeave construction for improved stiffness and durability, an Anti-Burp bump for easier tubeless set-up, and confidence boosting RockGuard rim protection that's more resistant to surface damage. The Kitsuma 27.5's asymmetric offset design improves spoke tension, and there's even a downhill version of this rim that has the same profile but adds about 50 grams of material for increased stiffness and structural integrity. And perhaps most important of all, rim width is 42mm external, 36mm internal, allowing you to take full advantage of the new breed of 2.3" to 3.0" tires flooding the market. Get ready to experience grip and lateral holding forces like you didn't think were possible on a mountain bike. Price: From $1398 | More info at www.noxcomposites.com
SRAM Roam 60 Wheels
At 21mm internal depth, these wheels fall at the narrower end of this round-up. But with a claimed wheelset of 1,570 grams for 27.5, and a price below $1000, they present great value whether your gift getter is an XC racer or all-mountain trail masher. These UST compatible hoops come spun with Sapim CX Sprint bladed straight pull spokes, and a DT Swiss Star Ratchet freehub. They're also easily convertible between the various axle types. Indeed, SRAM calls them a one-wheelset quiver thanks to its process of layering extra material onto stress points, which makes the Roam 60 rim light enough for long climbs, but burly enough to tackle enduro racing. Price: $970-$1230 | More info at www.sram.com
DT Swiss XMC 1200 SPLINE Wheels
Roll out for big adventure rides on the new DT Swiss XMC (cross mountain carbon) 1200 Spline wheelset that has a claimed wheelset weight of 1410 grams and is available in 27.5 and 29. Internal rim width is 24mm for improved tire support, while the hookless design of the rim eases tubeless set-up. The new Spline hub is the lightest DT Swiss has built. Price: $2600 | More info at www.dtswiss.com
Maxxis Minion DHF Tire
You need tires for your wheels, and you'd be hard pressed to do better than the standard in trail-ready rubber, the Maxxis Minion DHF. These tires are designed for the loose (and sometimes muddy) conditions of aggressive all-mountain terrain. The DHF incorporates ramped knobs for low rolling resistance and channel-cut knobs to increase gripping edges, giving straight-line control and precise cornering. Now available with DD technology 120 tpi folding downhill casing. Price: $85 | More info at www.maxxis.com
Continue to page 2 for more hot wheels for your favorite mountain biker »
ENVE M Series 60 Forty Wheels
Billed as a true do-anything-go-anywhere wheel, the M Series 60 Forty from ENVE is equally at home zipping up steep climbs or bashing down gnarly rock gardens. Designed for tires from 2.1" to 2.35", these full composite rims have a modest 23mm internal width, 29mm external. And of course they are light, with a claimed wheelset weight of 1368 grams. If you want to run bigger tires, ENVE offers a high volume version of the rim that will accommodate up to 2.4" rubber. Available in 26, 27.5 and 29-inch with 28- or 32-hole counts depending on whether you want to shave a little weight or increase stiffness. Price: $2375 | More info at enve.com
e*thirteen TRS Race Wheels
This race ready wheelset from e*thirteen features a hub flange-rim profile combination that creates a wide spoke angle for improved stiffness and cornering stability. The TRS Race is also more dent resistant, crisper steering, and lighter than its alloy cousin, and six-degree freehub engagement ensures you can quickly snap through turns and get back up to speed. TRS Race hubs include a one year no questions asked bearing guarantee. Claimed wheelset weight 1690 grams. Price: $900 | More info at bythehive.com
Rolf Prima Rage Wheels
These alloy wheels from Oregon's Rolf Prima are designed for heavy combat. Internal rim width is a bulbous 25.5mm to enhance tire traction and grip, while the CNC-machined titanium hub shell will stand up to frequent abuse. Spoke counts are paired 24 front and rear. By pairing the spokes, Rolf Prima neutralizes the left and right outward pulling forces allowing them to build consistently true wheels on lighter rims with fewer spokes. Price: $949 | More info at www.rolfprima.com
Custom WheelBuilder.com Wheels
If you cant find exactly what you're looking for via traditional channels - or you simply want to create something custom for your favorite mountain biker (or yourself), head over to WheelBuilder.com. The California-based company is religious about providing great products and service via meticulous quality control and parts selection. Every wheel they sell, whether hand built by them or factory purchased, goes through a rigorous measurement, inspection, and adjustment process that ensures you wont be busting out your personal truing tool after that first rowdy ride. Price: varies depending on rim/hub choice | More info at www.wheelbuilder.com
Maxxis Aggressor Tire
Designed for high-speed modern mountain bike trails, the Maxxis Aggressor tire features advanced knob shaping that creates extra gripping edges, and reinforced side knobs that offer enhanced stability when cornering at speed. This is an all-around tubeless ready trail tire that excels on everything from loose cross-country race courses to heavy all-mountain riding adventures. Now available with DD technology 120 tpi folding downhill casing. Price: $62 | More info at www.maxxis.com
This article is part of Mtbr's 2015 Holiday Gift Guide. For more gift ideas and holiday guides, CLICK HERE.
