The outgoing Pivot Mach 6 carbon was a highly successful bike for Pivot. Cable routing opened the door for some improvements and the high price of carbon called for an aluminum version as well. The call is answered here.
Many improvements have been made to compete with other bikes at the highest level, but it was made more accessible too with an aluminum version of the frame. The aluminum version is $1999, which is a full $1k less than the $2999 carbon frame. Weight is 7.4 lbs for the aluminum compared to 6.5 lbs for the carbon version.
Differences include an all new double wishbone rear triangle and new linkage design for huge gains in overall stiffness. The upper linkage alone is 40% wider, 150% stiffer and utilizes larger bearings at the frame attachment point, while the redesigned clevis is now lighter, stronger and provides increased clamping force on the shock body. The new rear triangle also incorporates Boost spacing for an overall increase in frame stiffness, power transfer and even more tire clearance, allowing for a wide range of tire choices. Additionally, the Mach 6 Carbon now features the innovative Pivot Cable Port System for the first fully Di2 integrated long travel bike.
The Mach 6 Aluminum adds even more options to the new Pivot enduro/trail line up. Pivot has met the same standards for stiffness, power transfer and perfectly dialed suspension performance as their carbon bikes.
The Mach 6 Aluminum features the same new linkage design as the Mach 6 Carbon, Boost spacing and acclaimed dw-link suspension.
Pricing, Specifications, and Availability
The Mach 6 Carbon frameset features a FOX Factory Kashima Float X shock with EVOL air sleeve and will retail for $2,999, with complete builds, from Shimano SLX to XTR Di2, to fit a wide range of rider budgets starting at $4699. The new Mach 6 Carbon will join the Pivot Demo tour this month at Outdoor Demo, and begins shipping to dealers immediately.
The Mach 6 Aluminum frameset features a FOX Factory Kashima Float DPS Shock with EVOL air sleeve and will retail for $1,999, with complete builds to fit a wide range of rider budgets starting at $3499. The new Mach 6 Aluminum will join the Pivot Demo tour this month at Outdoor Demo, and begins shipping to dealers in September.
Continue to page 2 for more details on the carbon and aluminum models and a full photo gallery »
Mach 6 Carbon
- Full carbon frame featuring leading edge carbon fiber materials and Pivot's proprietary hollow core internal molding technology
- 155mm (6.1") of renowned dw-link suspension
- 27.5-inch wheels for the fastest descents and superior rollover in technical terrain
- Pivot's new ultra-stiff, DH-inspired, double-wishbone rear triangle design
- All new, cold-forged wider and stiffer upper and lower linkage design with Enduro Max Cartridge Bearings
- New 12 x 148mm Boost rear spacing for maximum stiffness and control
- Custom-tuned FOX Factory Kashima Float X shock with EVOL air sleeve
- Designed to work with forks from 150-160mm in travel
- All new internal cable routing, featuring Pivot's Cable Port System and full Di2 integration
- Internal stealth dropper post compatible
- New Pivot removable front derailleur mount for a clean frame design with 1X and perfect front shifting with Shimano's side-swing 2X system
- Post mount disc brake mounts for precision and weight savings
- PF92 bottom bracket for light weight, durability and ease of maintenance - co-designed by Pivot Cycles and Shimano, now the industry-leading standard for high-end mountain bikes Rubberized leather chainstay, inner seat
- stay, and down tube protectors for a quiet ride and higher impact resistance
- Medium frame weight: 6.5lbs including shock
- Available in sizes XS, S, M, L, XL for riders between 4'10" and 6'2"+
Mach 6 Aluminum
- Pivot's newest aluminum frameset utilizes next-generation, variable wall thickness hydro-forming - bringing carbon-level strength, stiffness, precision, and control to produce the ultimate aluminum frame design
- Custom-tuned FOX Factory Kashima Float DPS Shock with EVOL air sleeve
- Easy to use mix of external and internal cable routing
- Medium frame weight: 7.4 lbs including shock
Geometry
For more information on the new 2016 Mach 6 carbon and aluminum bikes, visit www.pivotcycles.com/bike/Mach-6-Carbon and www.pivotcycles.com/bike/Mach-6-Aluminum.
