9Point8 and Wolf Tooth collaborate on Digit dropper lever
New version of ReMote designed specifically for Fall Line post
Components News
9Point8 Digit Lever 2017
The new 9Point8 Digit uses the same bones as the Wolf Tooth ReMote, but has a modified leverage ratio and lever shape.
Last year at Interbike, we gushed over the new ReMote dropper lever from Wolf Tooth. This aftermarket unit operates on the same principle as a quality paddle shifter, but is unique in that it spins on a giant sealed cartridge bearing for smoother actuation. This mechanism sits on a plastic axle pivot, which can break away in the case of a crash.
The 9Point8 Lever will also work with the Race Face Turbine and Easton Haven dropper posts.
At launch, it was compatible with a number of mechanical dropper posts, including the 9Point8 Fall Line. But to make this lever work even better with their posts, 9Point8 has collaborated on a new version called the Digit.
The new lever may seem pricey, but says here it’s worth it. We have a ReMote in for review and it is phenomenal.
The Digit lever shares the same features as the Wolf Tooth ReMote, but the lever geometry and leverage ratios have been specifically designed for the Fall Line. The lever has also been reconfigured for a lower profile.
The new Digit lever is available from 9Point8 for $70. The lever will also be available as an upgrade with any new 9Point8 DropLoc seatpost for an additional $18.
For more info, visit www.9point8.ca.
Wordpress Comments:
  • gg@gmail.com says:
    Breakaway axle pivot is bung.
    Adjust the bolt tension so that the lever rotates on the bar in a crash.
    Just like we’ve been doing forever with brake levers.
