BikeYoke Revive Dropper Post Review
On-the-fly reset function makes post true class leader
The price tag is a tad steep, but the value of not having to send your post off for servicing is borderline priceless.
What is it
German’s are often a literal bunch, and BikeYoke is no exception. The company sprung to life after a couple of engineers with mountain biking habits decided to create aftermarket frame yokes that would allow Specialized owners to run alternative shocks on their bikes. Next the pair took aim at the often dubious dropper post market, which as of a few years ago became both the most coveted and often unreliable component on any bike that wasn’t earmarked for World Cup cross-country duty.
The result is the (again) aptly named Revive, an infinite travel mechanically actuated dropper post that directly addresses the issue of air leakage (and the ensuing mushy performance) by equipping the post with a valve that when activated resets the hydraulic circuit, meaning no more mush. More importantly, this revival is achieved via a quick turn of 4mm Allen key inserted into an externally located reset valve, thus you don’t have to remove your post (or send it back to the manufacturer) to get it working properly again.
Available travel lengths are 125mm, 160mm (tested), and 185mm for 30.9 and 31.6 seatposts. And there are two remote trigger options, paddle or radial style lever. It also plays nice on your handle bars with the likes of Formula, Hope, Magura, Shimano, and SRAM. Mtbr tested an 160mm travel 30.9 post which weighed 527g, plus another 113g for hardware and lever.
  • Can be bled without removing post from bike
  • Infinite travel
  • Ergonomic paddle style lever
  • Great lever feel
  • Low stack height means more travel
  • Discernable clunk upon return
  • Twin chamber design instead of IFP
  • Not affected by cold temperature
  • Experienced no side-to-side play
  • Angled saddle retention bolts easy to reach and adjust
  • Three travel lengths available
  • Better fit on smaller frames
  • Less prone high seat-clamp force issues
  • Expensive
  • No external option
  • Turning bike upside down can require post bleed
The post’s lower stack height means more dropper travel in some frames.
Mtbr’s Take
Unless you’re a product engineer there’s no need to take too deep a dive down the tech rabbit hole. But when it comes to the BikeYoke Revive dropper post it helps to have at least a basic understanding of how it works. In this case the key is its twin-chamber rather than internal floating piston design, which is employed but many of the popular droppers currently on the market.
Those other IFP-using posts rely on a perfect seal to keep oil and air separate, lest you end up with that mushy post feel. But as most of us know from experience, maintaining that perfect seal is not easy, and air often leaks in, resulting in sub-par performance or worse (think bleeding and sending your post out for servicing). Conversely, BikeYoke’s twin-chamber design instead uses just two seals (versus the more common four), which lessens the chance for oil-air mixing.
Lever action is buttery smooth.
However, it’s not a perfect system either, which is why BikeYoke added in the revive function. With the quick twist of a 4mm Allen key in an easily accessible nut and a push down of the post, the Revive is revived, its hydraulic circuits cleared and mush eliminated. And it works. I had to reset this post a couple times during testing, and it typically took longer to fish out the requisite tool than to do the actual repair. (And since sending out this test post, BikeYoke has started offering the Revive with an integrated mini-reset lever, so you don’t even need a tool anymore. The mini lever is retrofittable and owners of the original Revive can purchase it on-line.) Here’s the revive process on the original post:
And while we never had to do this, BikeYoke claims that if you do have to perform a full service, there is no complicated bleeding procedure because all wearing parts can be swapped out without opening up the hydraulic circuits.
The Revive also features a one-piece lower tube, which provides better load displacement and yields extra wall thickness at the collar area, so it’s less prone to problems if you accidently ham-fist tighten the seat clamp. It also has been impervious to cold, as witnessed by a winter’s worth of testing on a Canyon Dude fat bike.
The Revive had no issue with cold weather testing on this Canyon Dude fat bike.
Other notable features of the Revive include a low 41mm stack height, which means you can typically get a longer travel post into even frame’s with shorter seat tubes. In essence if you’re running a 150mm post now, you should have no problem jumping to a Revive 160mm. BikeYoke also nailed small details such as the cable cutting guide that’s printed on the base of the post. Indeed, stealth-routing install is fairly painless (unless you have a PITA frame), and all the various matchmaker compatibilities net a clean cockpit. Even the seatpost head is well thought out, with its classic two-bolt design and easy-to-access bolt heads.
But what’s really notable is how this post feels on the trail. Lever action is light and smooth, breakaway force is negligible, and the post returns to fully extended with a reassuring thunk. Bottom line, this is one of, if not the best droppers we’ve ever used, making it far easier to justify the somewhat steep $400 price tag, which includes remote.
Dropper posts make fat bikes more fun. Photo by Neil Beltchenko
Rating: 4.5 out of 5 4.5 Flamin' Chili Peppers
Price: $400
More Info:
About the author: Jason Sumner
An avid cyclist, Jason Sumner has been writing about two-wheeled pursuits of all kinds since 1999. He’s covered the Tour de France, the Olympics, and dozens of other international cycling events. He also likes to throw himself into the fray, penning first-person accounts of cycling adventures all over the globe. Sumner, who joined the Mtbr staff in 2013, has also done extensive gear testing and is the author of the cycling guide book "75 Classic Rides: Colorado." When not writing or riding, the native Coloradoan can be found enjoying life with his wife Lisa and daughter Cora in and around their home in the MTB Mecca of Crested Butte.
Wordpress Comments:
  • Mike D says:
    Bought one to replace my mushy broked reverb for 385 and it came with the bled lever, works pretty good, the only problem is that my butt got use to the mushy seat action so it now hurts a bit to ride a seat that doesn’t move. The release lever is a decent size and works pretty good.
  • justin says:
    Jenson 20% off coupon works on these, and it comes with lever. So not that expensive
  • adaycj says:
    “infinite travel” … now that is amazing.
    I love the idea. Just admit that it is going to screw up and make it a feature. I’m sticking to my long lived cheap dropper posts until the market has proven that a high end offering is actually reliable. The high end market for these things is a shameful mess.
    Maybe this thing will be reliable, and added bleed will make occasional fixes easy and quick. I’ll check back in maybe in a year …
    • dave says:
      I’ve had mine for 4 months and revived it once (revive = the bleed process that takes all of 10 seconds). I’m not sure what else to call a post that’s done close to 1000 miles with 10 seconds of maintenance other than reliable.
