BikeYoke REVIVE MAX unveiled
Dedicated 34.9 dropper post with up to 185mm travel
Components News
BikeYoke REVIVE MAX
German component maker BikeYoke has launched what it’s calling the first truly dedicated 34.9 dropper post for trail bikes. Dubbed the REVIVE MAX, the post comes in 125mm, 160mm, and 185mm travel lengths, meaning riders will no longer need to utilize a shim adapter for bikes such as the Specialized Enduro or Evil Wreckoning.
“Until now there was no dedicated 34.9 dropper post available that had various travel options with up to 185mm of travel,” said BikeYoke. “While there have been some brands with 34.9 options, all of them are based on their regular sized siblings with original upper tube diameter, meaning those posts just used a bigger lower tube and kept the general design unchanged.”
BikeYoke REVIVE MAX
But, BikeYoke contends, more space inside the seat tube comes with the potential to make the post stronger, stiffer, and smoother. The REVIVE MAX will also come with the latest revision of the company’s patented instant reset function and integrated quick-reset lever, which allows the post to be bled trailside in about 10 seconds using nothing more than an Allen wrench.
“High end bikes deserve a properly designed dropper post,” added BikeYoke. “And while to be fair, there is one dedicated 34.9 post with an oversized upper tube (made by Specialized), that post only offers 115mm of travel.”
BikeYoke REVIVE MAX
The new REVIVE MAX features a 28mm stanchion (compared to the original REVIVE at 25mm), optimized wall thicknesses, increased bushing strength, all the while keeping stack height and overall length low.
This minimizes the weight penalty to less than 50g (compared to a 160mm/31.6 post), resulting in a total weight of 590g for the post only. That is still lower than many other posts with less travel and a smaller diameter. And that is not accounting for the extra shim inside the seat tube.
BikeYoke REVIVE MAX
The BikeYoke REVIVE Max will sell for between $455 and $499 depending on travel length. Claimed weight is 530g (125mm), 590g (160mm), and 630g (185mm). The Triggy remote adds 23g for the direct mount without clamp or 36g including clamp.
You can learn more at www.bikeyoke.de.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
