Mtbr Lights Shootout Main Page | Mtbr Lights Reviews | Mtbr Lights Forum
Lupine Tesla 4
| Light | Price | Claimed Lumens | Runtime | Battery Type | Light head weight | Battery Weight | Installed Weight | Lumens per gram | Lumens per dollar |
| Lupine Tesla 4 | $488.00 | 700 | 3 hrs | Lithium Ion | 98g | 220g | 320g | 2.19 | 1.43 |
Description:
The Lupine Tesla is completely new design from these light wizards from Germany. It extremely compact with a single Seoul Z-Power P7 LED emitter that puts out 700 lumens. It is complemented by an equally small 4.5Ah Li-ion battery tha provides three hours of burn time on full power. Three levels of brightness are accessible from the lighthead mounted switch. And a flashing mode is mode is available for commuter riding.
The switch on the rear of the light unit allows switching through the available light settings, and remains illuminated for easy location during night riding. This switch also acts as a low-battery warning light by changing color. In our previous test, Lupine lights were impressive but we thought the remote, handlebar-mounted switch was unnecessary and caused handlebar clutter. Thus we were very pleased to see this light mounted switch that was one of the easiest to operate in all the lights we’ve tested.
Beam angle is 13° with a very clean and well defined light halo or outer illuminated area. There is also a bright, but not harsh spot in the center of the beam pattern. This worked extremely well on the trail as a wide swath of trail was illuminated while the spot threw light very far into the trail. The total weight is a 320 grams.
Performance:
The Lupine Tesla measured 51 Lux on our light measurement setup. This is just below the Light and Motion Seca Race at 52 Lux and just above the Exposure MaxxD at 48 Lux. The comparison table is available here: http://reviews.mtbr.com/blog/lights-shootout-light-meter-measurements/.
The Tesla’s real strength however is its beam pattern. The halo is very wide and well-defined. And the center spot is just the right size and throws the light very far. As you can see in the beam pattern here http://www.mtbr.com/beamcomparisoncrx.aspx, it’s not the brightest light but it is extremely clean and usable. Coupled with its weight, size and ergonomics, this light is just right.
Strengths:
- Perfectly sized package makes it versatile for all mounting applications
- Light is extremely bright and wide
- Switch and electronics are very easy to operate
- Excellent packaging and carrying case
- Cool operation with outstanding run time
Weaknesses:
- We continue to be unimpressed by this mounting system. It is simple to a fault since it’s not so easy to install or aim.
Bottom Line:
This is perhaps our favorite light of the year. The performance, packaging, reliability and ease of operation is perfect. And get this, it’s affordable!
Beam Pattern Photos:
Lupine Tesla 4
Beam Pattern rollover and side by side comparison page available here.
Value Rating:
5 out of 5 Stars
Overall Rating:
5 out of 5 Stars
Read or write reviews:
Francois
July 7th, 2009 at 11:06 pm
“it’s not so easy to install or aim. ”
I agree that it doesn’t have lots of side to side adjustability (I run this one on the helmet, don’t need to adjust to sides. Note: there is a screw that allows the movement of the light that you could use to micro-adjust; just be sure to tight it again)
As fas as the easiest to install? how more simple is that? no plastic base that snap, no untighten of screws to aim up ot down….
July 8th, 2009 at 8:58 am
Good tip on the little screw.
The Lupine rubber strap is very tight and hard to grip. I believe there is one specifically for oversized bars but the normal one will work with a lot of effort.
It’s not a big deal but when I used the Light and Motion Stella mounting strap, it was wayyy easier and side to side adjustable.
