Reviewed by Brian Mullin aka Gram and MTBR.com Pastajet
http://www.gramslightbikes.com/
I have been using Magura Marta SL brakes for many years, and had always been satisfied with the brakes, but I always wanted a tad more power and modulation. Magura revamped the Marta line in 2009, and then sweetened the pot with a lighter version using forged magnesium. The new brakes have met my expectations and then some!
Magura Marta SL Magnesium
Magura updated the Marta lineup with some new innovations for 2009. The upgrades include a redesigned caliper and reservoir body, a better lever pivot, and the use of the larger Louise pads. The new reservoir body contains a new bleeding system, that is drastically easier to use.
Which brings us to the Mags, their latest tweak on the Marta SL. The Mags come with a titanium hardware, a special paint job (white/red), a magnesium reservoir body and an aluminum caliper. The rotors are sold separately in 160, 180 and 203 sizes in either the default SL Wavy, Drilled SL or Venti rotors.
Magura were originally going to have a full magnesium set, but due to some tooling issues they have stuck with an aluminum caliper, so the weight wasn’t quite at their projected project weight. The weight weenie crowd not surprisingly, was up in arms over the lack of a full magnesium brake for Magura’s lightweight flagship and benchmark model. Hopefully, they can overcome the issues and release a magnesium caliper sometime soon.
I love the smell of napalm in the morning…Smelled like…victory.
Magnesium 101
Magnesium is a chemical element with the symbol Mg, and atomic number 12. It is a fairly strong, silvery-white, light-weight metal, and was first produced in England by Sir Humphry Davy in 1808. The name originates from the Greek word for a district in Thessaly called Magnesia.
With a density of only two thirds of aluminum, it has countless applications in cases where weight reducing is important. It tarnishes slightly when exposed to air, and is protected from air and water by a thin layer of oxide, which is fairly impermeable and hard to remove. Magnesium is a highly flammable metal, but while it is easy to ignite when powdered or shaved into thin strips, it is difficult to ignite en masse or bulk. Burning or molten magnesium metal reacts violently with water, since it creates hydrogen gas, so if your brakes spontaneous combust throw sand on them!
Brian Mullin
September 22nd, 2009 at 9:27 am
Hi Brian, do you know the thickness of the Ashima rotors? Thanks
September 22nd, 2009 at 11:00 pm
Last I measured them they were 2.0mm, same as the Magura’s
September 29th, 2009 at 12:30 pm
Brian, would you recommend using the Magura Endurance or Performance brake pads with these rotors?
September 29th, 2009 at 12:33 pm
Performance
September 30th, 2009 at 8:57 am
Bryan, in the article you said that “the power difference between the 2008 to 2009 is significant, although it still doesn’t approach the power of some of its competitors.” Who are the magura´s brake competitors who have more power modulation ?
October 1st, 2009 at 1:58 pm
I was only speaking about power, not modulation. I think the Hayes and Formula brakes have a bit more power, I like the modulation is better on the Magura’s (for my tastes). I haven’t used Avid nor Shimano in long time, so can’t comment on them
October 1st, 2009 at 11:14 pm
Why all the Mg when your weighting the whole lot down with Steel bolts? F’in daft!
