GRAND JUNCTION, CO – MRP, the long time pioneer in chain guide design has raised the bar for 2008 with the planned October release of the patented G2 chain guide system. The G2 will be the first model to go into production utilizing MRP’s patented integrated chainguide/bash guard technology.
The G2 showcases a fully integrated skid plate, boomerang, and lower guide design never before seen on a bicycle. The result is a no-compromise guide that is light enough for the most weight conscious racers without sacrificing chain retention, rigidity, or protection of the chain and chainring.
G2 Features:
- Patented Integrated Skid Plate Design
- 260 grams complete, including all hardware
- 5mm thick CNC Alloy Boomerang with weight-optimized relief’s
- 13mm thick replaceable polycarbonate Skid w/full boomerang support
- 3-point attachment of Skid to Boomerang
- Derailleur cage style upper guide providing full chain enclosure
- Integrated Skid/Lower Guide including sealed bearing pulley wheel
- Enhanced Lower Guide rigidity and protection
- Front-access, single-bolt positioning of Upper and Lower Guide
- Low profile installation compatible with wide range of chain lines
- Available in ISCG or ISCG ’05 mounting standards
- 36-40 tooth capacity
G2 Benefits:
- Low weight, more protection
- Skid resides 2mm inboard of chainring for the same amount of protection as a traditional bash ring, with less than half the weight!
- Skid adds structural integrity to boomerang, and provides inside lower guide surface
- Seamless transition when sliding over rocks and obstacles
- Transfers energy from impacts into the strongest part of the frame, instead of to the bottom bracket bearings and crank spider. No more bent spiders!
- Easy to install and adjust
- Minimized chance of crunching the lower guide
- Expected availability: October, 2007
source: Ryan Cranston, MRP
adam
