Riding Impressions:
I have a couple rides on the Ritchey Break Away now and wanted to share some first impressions. The best thing I can say about it is that I did not notice it’s a travel/folding bike. It just rode like a bike with no flex, no squeaks, no fuss. I was a little bit concerned that the lightweight coupler on the downtube would affect the ride but it and the seat tube were as solid as normal tubes.
The build is insanely light and it came in at a hair under 20 lbs with Candy SL pedals. With this setup and rigid carbon fork, the head tube and riding position is pretty steep. It takes some getting used to and is a touch retro. The bike comes with XT v-brakes to save weight and to avoid hydraulic brake cables. When travel bikes are dismantled in half, it’s easiest when the all the cables can be separated with each frame half. The Ritchey Break Away accomplishes this with big aluminum brake couplers. They are easy to assemble but they make a big racket during riding as they hit the frame. They definitely need to be wrapped with some sound deadening material.
This bike is a climber. With the sub 20 lb. weight and the aggressive XC position, it is easy to translate leg power to uphill motion. It climbs with ease and has good traction. The titanium material is not only comfortable but seems to aid traction as well.
Descending is solid but I need to put some time on this bike to get a valid feel for it. The steep riding position and v-brakes are different from my normal setup. The bike steers nicely though and the frame is laterally stable. I’ll post an update as I ride this bike more.
Specifications for Break Away WCS MTN Titanium Frame Kit
- Custom drawn and mitered 3/2.5 Ti tubing
- Does not include fork - designed around 80mm travel
- 5 sizes 14-21″
- Includes travel case + WCS headset
- Disc or V-brake compatible
- Case size: 8.5″ W x 26.5″H x 31″L w/ wheels
- Ritchey does not guarantee Airlines will not charge
- 3.6 lbs Frame only (large)
Price: $2495
Size: 18″ or Large
Top Tube: 22.85 inches
Seat Tube Angle: 74 degrees
Head Tube Angle: 71 degrees
More Info: http://www.ritcheylogic.com/dyn_prodfamily.php?k=114351
Francois
July 24th, 2008 at 6:16 pm
francois: That is sweet. The really amazing thing to me is the travel case. I think you can check it as “bike parts” and get away with it.
Anyway, I think the Ritchey guys said that the joints were stronger than welds when locked into position on the Breakaway bikes,which is another amazing thing about the bike.
For me though, I’d have to stick with the 700c and go with that nice SS cross bike in Breakaway flavor.
July 25th, 2008 at 12:52 pm
Sweet! I have a break-away fixed gear/track bike that was built around the Ritchey break-away kit.
I love it. I am surprised they have not come out with their own yet. With no cables to deal with getting it together out of the suitcase is just a matter of tightening a few bolts!
July 28th, 2008 at 9:14 am
Good call man. A fixie with just a front brake would be a dream setup. It will be so clean and convenient. Now I just need to learn how to ride fixie!
fc
September 21st, 2008 at 2:08 am
I’d love to read a more detailed review - put some shocks on there and go ride!
September 21st, 2008 at 2:30 am
I’d love to read a proper review of this bike - but please, put some shox and XTR parts on it!
