I am up at Snowbird Ski and Summer resort for the 2010 Specialized Global Press Launch mountain bike presentation. Yesterday I saw the new Stumpjumper, the new Epic 29er, the new Safire and era women’s bikes, and the new 27 pound S-Works Enduro. I also got to ride the carbon S-Works Stumpjumper and the Epic 29er. I’m hoping to ride the Enduro today. I’m not going to be able to give you all the details on the new bikes right now because I have another presentation to run off to. But I will leave you with some photos of new bikes and the event here at Snowbird.
Here are a few photos of some of the 2010 Specialized mountain bikes for you. Yes – there’s more. I will be writing a more in-depth article after this event is over.
2010 Specialized Carbon S-Works Stumpjumper:
2010 Specialized S-Works Eduro – 27 pounds!
Here are some more pretty pictures of the Snowbird Ski And Summer Resort that I took when I arrived. I’m more used to seeing it in winter and I expect it’s the same for other skiers reading this. So it’s probably fun to see what it looks like in the summer.
Let me know if you’ve got questions about Specialized stuff. I’ll do my best to get answers for you.
Photo-John
June 28th, 2009 at 10:05 am
I have a question regarding the 2010 line: We’ve seen photos from Sea Otter of the 29er Epic. It’s an M5 Aluminium frame with a tapered head tube, and a custom fork. Will we see something similar with the 26er Epics? A 26er Epic Marathon full alu frame with an E100 fork is my absolute dream bike.
June 28th, 2009 at 3:41 pm
what about A spider for the S-works crank for mounting the XX chainrings
also the 1 1/8 – 1.5 alu headtubes
reason for the Alu lower bridge on the S-works 2010 Stump FSR
weight changes in the Epic carbon frames??
thanx
June 28th, 2009 at 6:34 pm
I have a question about snowbird. I heard they built some new singletrack in gad valley. I see it on the new map as well. How is it? I also heard they built a bike park to try out some of the freeride/dh bikes. Is that true? I also see on the new trail map a “sports park” what is that?
June 28th, 2009 at 9:29 pm
i’m wondering the same thing as josh, please give us some info about any new trail that has been added or is currently in the works for the upcoming events. i really would like to see some freeride or rippin singletrack up there.
June 29th, 2009 at 12:53 am
hmm what a nice resort for a paid riding …
BTW will there be any horst-link improvement from traditional specialized fsr config this 2010? say more efficient than ICT..?
June 29th, 2009 at 11:18 am
Do you have any pics of the new Demo?
June 29th, 2009 at 11:22 am
Bugger, that was my press trip!
Judging by your photos and the speed at which you got this up, mtbr sent the right guy!!!
francois
June 29th, 2009 at 12:57 pm
what is the new weight and travel (rear) on the Stumpjumper?
June 29th, 2009 at 6:34 pm
Would love to see some pics and details on the new Demo – if available.
Enjoy the rest of the launch.
June 29th, 2009 at 7:58 pm
Thanks for the insight, what about the 2010 Epic? Are there any changes there, even with the pricing? We have all seen the 29′er Epic, but what about the 26″.
Thanks man!
June 29th, 2009 at 9:10 pm
Ok, I’ve got some answers for your questions. Sorry I wasn’t able to get them to you sooner.
1) Kevin – There’s a 26-inch Epic with M5 tubing but it won’t be available with the E100 fork. The E100 fork is only spec’d on S-Works bikes. Part of the reason is the tapered head tube. The only aluminum frame with a tapered head tube is the Epic 29er. The reason it has the tapered head tube is to stiffen the front end of that bike.
2) Daan – The answer to your first question is, yes – Truvativ is making a spider so you can use the XX rings with the Specialized S-Works cranks.
I’m not sure what you’re asking with the other questions, though. If you’re asking about the tapered head tube, it’s only being used on one aluminum frame, the Epic 29er. It’s being used on that frame to give the front end of that bike more stiffness while maintaining the same bar height as a 26-inch Epic.
They haven’t given us complete bike specs, although I have asked. But the press kit I have says the Epic can have “complete bike weight as low as 21.5 pounds.” That’s the best I can do for you right now.
3) Josh – new Gaad Valley singletrack – they just started it. They’re building it right now. Not sure when it will be ridable. We couldn’t ride it. I’m hoping it’s good because Little Cottonwood Canyon could definitely use some more singletrack.
4) derry – I’m not sure how to answer your question about Horst link improvements. They refine and fine-tune the Horst link for each bike. For 2010 they tried to make the bikes feel more supple. One of the things they did to accomplish that is add cartridge bearings to the Stumpjumper linkage to make it smoother. I’m not sure how it compares to the ICT linkage, though. My understanding is that the ICT linkage is a Horst link. It’s just being tuned a differently from the Specialized Horst link.
5) Colby – I’ll try to get you some Demo photos tomorrow. They have it here, although they have a separate launch event for that bike and didn’t really tell us about it.
6) Conor – The new S-Works Stumpjumper has 140mm of travel, front and back. It weighs 23.4 pounds “out of the box” – that is without pedals. I rode it and was pretty goddamn sweet.
June 30th, 2009 at 8:23 am
Have the fork internals of the S-Works Epic E100 and Stumpjumper S90 forks changed from 2009 to 2010 ?
The Epic’s 2010 rear shock is labeled both Specialized and Fox. Is it the same rear shock as last year, only manufactured by Fox, or has the rear shock been renewed internally?
Will the aluminum models also feature a rear shock labeled ‘Fox’, or is it only for the S-Works biakes?
Many thanks!
June 30th, 2009 at 10:37 am
Photo-John,
Is the front fork on the new Enduro using a 20mm thru axle ? Also, is that fork a Spesh fork or a Fox fork or a combo-fork ?
Pls post move pics/info when you get a chance.
June 30th, 2009 at 10:38 am
Oh, one more… what is the wheelset on the new Enduro ?
July 6th, 2009 at 2:57 pm
Hey, where can i see the demo pics at?
July 7th, 2009 at 1:13 pm
I have posted a bunch more photos of the new Stumpjumper and Enduro in action on my gallery: http://gallery.mtbr.com/showgallery.php/cat/500/ppuser/75191
I’m catching on PhotographyREVIEW.com work right now. But I have more photos and some first impression articles in the pipeline.
July 24th, 2009 at 2:44 pm
Concerning the 2010 Epic 29′ers… I understand there will be 2 available… zAny word on pricing and availability???
September 17th, 2009 at 1:31 pm
Can you explain to me what the difference is between the rockhopper and the rockhopper SL? I can see the SL frame is resembels the stumpjumper but is it lighter, is it better, are they both going to be sold? I can’t find a decent answer on the specialized website or on forums. Furthermore I question or the lineup in Europe will be different the in the US (as was last year).
September 27th, 2009 at 12:06 pm
anywhere i can get some reviews of the 2010 enduro? i have read bike mag’s write up about the sneak peak, but i am looking for some more in depth info. any suggestions?
many thanks!
kevin
