Bontrager Team Issue XR1 TLR tires review
Forward thinking tread design means wider sweet spot than just XC
29er Tires
Full Wheel
Bontrager’s XR1 tires mounted on Bontrager Kovee XXX TLR wheels is a seriously fast combo.
What is it
Bontrager is no stranger to the demands cross country racing where tires can mean the difference between a podium finish and walking to the finish. Bontrager revamped its XR1 tire to meet the demands of more challenging cross country courses and pickier racers.
Fast rolling and grip rarely appear in the same sentence when describing tires, but it applies here. Tightly spaced, staggered center tread deliver traction on roots and slick rocks. Widely spaced, lower on shoulder corning knobs offer confidence when diving into corners and berms. And the supple casing is a major upgrade. Just a slight drop in pressure is felt instantly, conforming over roots and rocks. For a cross country race tire, Bontrager’s 495-gram XR1 can be ridden in nearly every condition except deep mud, and even in that it preformed ok.
Pros
  • Easy tubeless set up with floor pump
  • Lightweight
  • Reasonable price
  • Wide spaced cornering knobs
  • Cut resistant side walls
  • Supple casing
  • Predictable tread performance
  • Fast rolling
Cons
  • Tread wears quickly
  • Side wall design collects mud
Mtbr’s Take
It would be great to ride one tire all season. But it’s a lot to ask. Ripping downhill? Give me something that can handle cornering at high speed with some rocks thrown at it, too. Racing cross country? Give me a tire that rolls fast, is light, and will hook up if I venture off line. Well, cross country courses have changed a lot in past years and so are the demands of the racers. Adding more technical features and longer double track/road sections means you need a truly versatile tire to compete.
All that said, Bontrager’s XR1 has become the go-to tire for me. You can feel the suppleness of the casing when mounting. Though 120 TPI is commonplace for a quality cross country tire, it’s rubber durometer and sidewall stiffness that make a difference you can feel on the trail.
Bontrager wheels have a proprietary rim strip that is designed to offer easy set up and little mess. I was able to set up the XR1’s with a floor pump with little to no sealant spillage. Paired with 29mm internal rim width on Bontrager’s Kovee XXX, and these tires measured a touch over the claimed 2.20. It was more like 2.30.
Tire Side
Running lower pressure helped in the snow, where a bigger contact patch it key.
For my first ride on the XR1’s I hit some classic local single track that’s pedal heavy with some flowy sections. On the gravel road to the trail, I felt like I was on road tires. There was minimal rolling resistance, but the feel was a bit abrasive. I knocked the pressure down to 21 PSI (less than I would ride normally) and it clicked.
On the trail, I was on pillows. I did bottom out on some roots but that was few and far between. I felt confident taking turns fast, and braking traction was there when needed. I felt comfortable during the ride, seeking out rumble strips of roots to check compliance. All was good there, too.
Tread Detail from Behind
A staggered center line tread adds grip and low rolling resistance.
Next up was the real test: damp roots and rocks in central Pennsylvania. Riding over moss covered boulders, I never slipped or lost grip in a turn. Traction was predictable and consistent. After a full day of bouncing around on sharp rocks the XR1 had a few cuts but nothing you wouldn’t expect from a lightweight XC tire. Thin sidewalls are common in race tires, especially higher TPI ones. However, I was bummed to see the details fade on the center line tread and side knobs chipped away slightly. (I must mention that these tires were my go-to, so they we’re at about 200 miles at this point.)
Tread Detail with Snow
Smaller dimples help the XR1 release mud and dirt from the tread.
Lastly, the XR1’s got a taste of snow and ice as you can see from the pictures in this review. I wasn’t expecting much, but when paired with the Kovee wheel’s wide footprint there was ample contact patch and grip. This time I lowered pressure to 19 PSI, yet pedaling traction was still firm and the XR1’s handled very well in these conditions, especially considering this is not their intended use.
Tread Detail from Top
Lower shoulder knobs are great in the corners and loose terrain.
Bottom line, Bontrager has improved its tire offerings year after year, and I would recommend this latest option to anyone looking for a race day XC tire that you can train on and not worry about getting stranded. And considering most cross country race tires are coming in around $75-$80 these days, the XR1 is a steal at $55. The forward thinking tread design opens a wider use for Bontrager’s XR1 besides cross country racing and dry pine forests. Any rider looking for confident traction and fast rolling from a tire are advised to check these out.
Rating: 4 out of 5 4 Flamin' Chili Peppers
Price: $55
More info: www.trekbikes.com
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
Wordpress Comments:
  • Tom says:
    Agree. Surprising tire. These came on my Procaliber, and I almost didn’t ride them (usual combo is XR2/XR3).
    I’m glad I did. They are faster than the XR2s, but seem to have just as much grip. Stuck with the XR3 up front, though.
  • Teleken says:
    Looks like a Specialized Fast-Trak with smaller shoulder knobs.
  • Flynbryan19 says:
    Sadly I did not have the same positive experience. Perhaps since they were original equipment on my bike (17′ Trek Top Fuel) they are a harder rubber compound… The tire is “reasonably light” and it is a very fast rolling tire. The down side for me though was traction in loose over hard (which an XC tire should be designed for) was very poor. Even with pressures as low as 20/23 front/rear respectively they have very poor traction on the climbs. They would also wash out suddenly and never catch in corners w/ the same conditions. I will say traction in damp dirt was great though. Again why I think it maybe a rubber compound issue?
    Went to a Schwalbe Rocket Ron / Racing Ralph combo and traction is MUCH improved. Also dropped rotational weight. Win/Win. They’re not a “bad” OE tire, but I would not recommend buying them to replace existing tires. There are much better options.
