Burley Coho XC bike trailer first look
Open up trail possibilities with this versatile trailer
Pro Reviews
Burley Coho XC enabled a picnic and RC Crawl session on top of the hill.
When Burley invited us to test their new bike trailer, the Coho XC, we were not that interested. We had visions of troublesome mounting and rear hub compatibility problems with this current crop of rear thru-axles. Much like bike trainers, the bike trailer has been granted an impossible compatibility landscape with skewers, axles, Boost and SuperBoost standards. But they assured us they had a solution for this puzzle so we accepted the challenge.
Over the years, we had dreams of venturing deeper into the trail and doing some overnight camping. Fishing in remote lakes, doing some trail work with real tools have crossed our minds too. And finally, we’ve always entertained the idea of moving our post-ride feast on to the top of the mountain instead of the usual parking lot.
This explains the concept pretty well.
The mounting solution
Built to address one of the most common problems of the bike trailer – the inability to adjust the yoke to a wide range of axles and hubs – the Coho XC uses a variable width yoke. This feature allows installation on a wider range of hubs and tire sizes, including 700C with full wrap fenders, 29 plus wheels, off-road tires and road tires. Boost, Superboost and Fat bike axles have met their match
“Consumer feedback and unique innovation are top of mind as we prepare to enter the single wheel trailer category,” says Burley President Allison Coughlin. “This is the most anticipated launch for our brand yet and we can’t wait to show the world how much thought we’ve put into this.”
Users simply spread the yoke to the width of their rear axle, and then drop and lock the trailer to the bike with the new dual ball hitch that allows the yoke to connect at multiple angles.
Now you can take proper trail building tools deep in the woods.
Features
• Release lever instantly disconnects the trailer
• Yoke adjusts to a wide range of hubs and tire sizes instantly without tools
• Integrated kick-stand holds trailer and bike upright
• Removable side panels hold cargo when not using a dry bag
• Customizable with three available trailer wheel sizes (Plus 16 x3”, Off-road 16”x2.125”, Road 16”x1.75”), pannier rack and cargo ladders
More features
• Multiple integrated accessory mounts for easy bottle cage/accessory attachment
• Disassembles without tools into a compact form for storage and travel
• Large object compatible: The level frame and fender design accommodates long and wide objects
• Adjustable suspension
The expanding arm is the key to the Coho’s verstaility
From single track bikepacking to long-distance touring, the Coho XC is an ideal product for everyone and will be available for purchase March 2018 in the $439-$469 price range.
Specifications
MSRP: $419.00
Weight (net): 21.5 lbs (9.74 kg)
Towing Capacity: 70 lbs (31.8 kg)
Cargo Area Volume: ~70 liters (4270 in3)
Cargo Area: 24” x 15” x 11.5” (61cm x 38cm x 29cm)
Hub Compatibility: 126 to 197mm (Typically)
Tire Size Compatibility: Most wheel/tire sizes including: 26 (including Fat Bikes), 700C, 650B/27.5 (including Plus) & 29
Burley Coho XC with cooler, ready for action
Dimensions
Length: 66.5” (168.91cm)
Width (Trailer Body/ Kickstand):17” (43.18cm) / 17.5” (44.5cm)
Height:21.25” (53.97cm)
Ground clearance: 8.25” (21cm)
Suspension Travel: 2.375” (60mm)
Product dimensions: 66.5” x 17” x 21.25”(168.91cm x 43.18cm x 53.97cm)
Burley Coho XC cargo net expands capacity securely.
Our take:
We’ve only used it three times and we’re pretty shocked with how well it works. Mounting and dismounting the trailer takes about 6 seconds each, once the special axle is installed and left on the bike.
Climbing up hills, it is very stable and maneuverable. Added traction on the rear tire gives the bike some climbing prowess as long as the watts are supplied. Descending, it is capable indeed as it can slither through corners and tight spots. We just have to remember to maintain a smooth flow, especially on loose terrain. Hard braking efforts tend to make the heavy trailer push the bike and cause instability.
And handling this trailer, it is built like a fine bike with quality materials, welds, and construction. We feared it would cost $800+ but a quick check of the specs reveals a very fair price of $419. Thumbs up so far and we can’t wait to take it on some big adventures.
More Info: https://burley.com/coho-xc-launch-guide/
