CamelBak Chase Vest Front
It may look dorky, but it's comfy.​
Chase Bike Vest
At first glance, the CamelBak Chase bike vest looks like something that belongs on the back of an ultra-runner. It's kind of dorky - until you put it on. Then, in my opinion, it becomes the most comfortable hydration pack you've ever worn.
CamelBak Chase Vest Back
The Chase isn't just a running pack with a mountain bike label slapped on; it's a careful redesign.​
It's designed for maximum stability, so the front and rear loads are balanced. Unlike the running versions, this mountain bike specific pack uses tougher materials, more zippers, and larger storage pockets. As an added advantage, it's short enough so you can still access your jersey pockets. Price is $100.
CamelBak Kudu
The K.U.D.U. is the ultimate bag for enduro-style events. It meets CE2 levels of certification and offers impressive storage capabilities.​
K.U.D.U. 10/20
For 2018, CamelBak has completely redesigned the K.U.D.U. The new pack sells for less, while adding a number of new features. The removable tool roll, integrated rain cover, helmet/armor straps, and side pockets all carry over. Items such as the belt, sternum straps, and back protection have all been redesigned.
Kudu Backpack Specs
The K.U.D.U. comes in a 10 and 20L.​
The new back protector now meets the more stringent CE2 motorcycle safety standard and is designed to be more flexible. This allows it to better conform to your back, making it more comfortable on long rides. The pad also receives additional perforation for improved airflow.
CamelBak K.U.D.U. Back Protector
Want to go light? CamelBak gives you the option of unzipping the bag and using just the back protector.​
Perhaps the coolest feature is that the back protector can work without the cargo pack. If you want to go light weight, the entire back zips off to reveal a stand-alone back protector with jersey style pockets. The pack is available as either a 10L or 20L. Price is $200 and $230 respectively.
CamelBak Toro 8 vs 14
Both the T.O.R.O. 8 and 14 carry a 3L (100oz) reservoir. The 8L (pictured left) offers an additional 5L of storage, while the 14L (right) offers an extra 11L.​
T.O.R.O. 8 and 14
Don't want to drop two bills on a CE certified backpack you'll only wear at the bike park or when required at races? CamelBak's new T.O.R.O. features a CE2 certified back protector, but ditches some of the bells and whistles found on the K.U.D.U.
T.O.R.O. 8 Red Back
The T.O.R.O. uses a narrower back protector than the K.U.D.O. Both meet the same safety certification, but the slimmer pad helps reduce costs.​
If you can live without the rain cover, zip off design, and removable tool roll, you can pick up the T.O.R.O. 8L for $160 or the T.O.R.O. 14L for $180.
CamelBak Repack LR 4
The new Repack resolves our minor complaints with the Palos. Read our review of the Palos here
Repack LR 4
If hydration packs aren't your thing, then the new Repack might be more your style. Based loosely on the Palos waist pack, this new bum bag resolves many of the complaints Mtbr had with the previous design.
A new compression strap system helps reduce bouncing.​
The key is the new compression system, which should keep the bag from flopping around. CamelBak also reconfigured the pockets, so the new pack is sleeker. It will still tote a 1.5-liter reservoir, plus 2.5L of gear (or 4L of stuff and no reservoir). Price is $75.
The Podium Dirt series retails for $2 more than the regular version.
The Podium Dirt series retails for $2 more than the regular version.​
Podium Dirt Series
When you're headed on a shorter ride, sometimes you don't need to carry a pack. A water bottle on your frame and some basic tools are enough. The only downside with a water bottle is that the nozzle can get covered in gunk. Enter the new Dirt Series. It's basically the bottle and bite valve we've come to love, but with a silicone dust cap. The water bottle is also a touch shorter, so it's less likely to rub on your shock.
The Dirt Series is available in standard and insulated versions. Both hold 21 oz. Retail is $11 and $15. That's a $2 up charge over the standard Podium, which does not come with a dust cap.
CamelBak Sternum Protector
For that ultra clean look, you could wear the sternum protector next to your skin and cut a hole in your jersey for the action camera. This look has become widely adopted in motocross.​
Sternum Protector
On a non-hydration related note, CamelBak was showcasing a new Sternum Protector with an integrated GoPro mount. This CEII level protector is made from the same material as the back protector in the K.U.D.O. and T.O.R.O. series and is cut to work in conjunction with a backpack. The Sternum Protector is available in one size (28-47" or 71-116 cm). Retail will be $100.
To learn more head to https://www.camelbak.com.
