Cane Creek eeWings titanium cranksets launched
Plus All-Road and Stages power-meter equipped eeWings
Gear News
Cane Creek eeWings
Cane Creek has announced that their eeWings Mountain cranks will now be available equipped with an optional power meter from Stages Cycling with Stages-equipped eeWings All-Road cranks available later this fall. Additionally, Cane Creek Cycling Components has announced the release of the eeWings All-Road – a new version of their titanium eeWings cranks designed to fit road, gravel and cyclocross bottom bracket standards.
Like its mountain bike oriented sibling, the Cane Creek eeWings All-Road crankset is made entirely from high-grade titanium and is designed for stiffness and durability while weighing in at less than 400 grams. That’s in the same weight range as premium carbon cranks but 20% to 30% stiffer and significantly more durable, claims Cane Creek. The eeWings All-Road also carries the same 10-year limited warranty as the eeWings Mountain.
In addition to the existing 10-year warranty, Cane Creek has announced that they will offer a 30-day, 100 percent satisfaction guarantee to any rider who purchases a set of eeWings cranks, Mountain or All-Road. Regardless of reason, if a rider is not 100 percent satisfied with the cranks, they can be returned to the original place of purchase within 30 days for a full refund.
Cane Creek eeWings
“The response to the eeWings Mountain has been overwhelming,” said Sam Anderson, product manager for Cane Creek. “And we’re excited to add the eeWings All-Road and eeWings with Stages so more riders on more bikes can experience these awesome cranks.”
The eeWings All-Road are compatible with direct mount X-SYNC chainrings and are available in 170mm, 172.5mm and 175mm arm lengths. The cranks also have a titanium 30mm spindle and are compatible with BSA68mm, PF86.5 and 386EVO bottom brackets as well as PF30 and BB30 bottom brackets with outboard bearing configurations.
The eeWings All-Road also include an innovative CNC machined aluminum preloader that is compatible with multiple other high-end 30mm spindle cranks – providing a more durable solution over preloaders from other manufacturers, which are often made from plastic or other less durable materials.
Cane Creek eeWings
Like the eeWings Mountain, they also come in a subdued, brushed titanium finish with only a minimalistic laser-etched graphic on the face of the crank. In addition to allowing the titanium to take center stage aesthetically, this simple design will allow riders to use Scotch-Brite or a similar abrasive to remove small scratches and blemishes that accumulate in the finish over time and use.
The eeWings All-Road retail for $999 and Cane Creek eeWings MTB equipped with a Stages power meter retail for $1499. Both options are available through Cane Creek distributors and retailers or factory direct through the company’s website at www.canecreek.com.
Cane Creek eeWings All-Road Specs
  • Weight: 395 grams
  • Materials: Grade 9 Ti-3Al-2.5V titanium (crank arms), Grade 5 Ti-6Al-4V titanium (spindle, herth joint/chainring interface, pedal inserts), 7075 T-6 Aluminum (preload assembly)
  • BB compatibility: 30mm spindle only. BSA68mm, PF86.5, 386EVO, BB30 (External Bearing), PF30 (External Bearing)
  • Chainring compatibility: Compatible with X-SYNC Chainrings
  • Length: Available in 170mm, 172.5mm and 175mm
  • Warranty: 10-year limited warranty
Learn more at www.canecreek.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
