Cane Creek Helm Coil fork springs into action
Return to article
The Cane Creek Helm Coil in full glory. Taking off the cover gives you access to the 18 mm bolt which you need to unscrew to open the fork leg, so you can change the coil (three spring rates available) or the fork’s travel.
