Capo Interbike Booth
Interbike VTSB
Gary Vasconi shows us the new 2013 GS-13, Ceramica, and the Donna SC-12 Super Corsa series kits. The GS-13 race inspired kit features a tapered cut, longer sleeves and leg length, 4-way stretch carbon with 4% carbon fiber, and 6mm lockable zippers. It is part of the Resistex family with built-in SPF 50, anti-microbial, anti-odor and reduces static electricity. The new Ceramica features bio ceramic polyester that helps with equilibrium and thermal regulation, and fine gague mesh under the armpits. The Donna SC-12 kit for women also features the Carbon E fabric with built-in SPF 50 and anti-microbial and has a cross over waist band.
Capo Interbike Booth Gallery
of
    Capo Drago
    • Next generation technology with advanced thermal regulation, rapid moisture transfer, and SPF 50 protection.
    • Ultra-high muscle compression reduces fatigue and innovative harness provides bib short stability and support.
    • Anatomic chamois with multi-density foam positioned strategically for support and ultimate pressure relief.
    • Jersey/Bib short: $250/$300
    Capo Drago
    Capo Drago Mesh
    Capo Drago Carbon Panel
    Capo Volta
    • Carbon and coldblack technology system provides advanced thermal regulation, UV protection and moisture management
    • Designed to provide ultimate muscle compression, stability and power in the riding position
    • Anatomic chamois with multi-density foam positioned strategically for enhanced support and ultimate pressure relief
    • Jersey/Bib Short: $230/$280
    Capo Volta
    Capo Volta Mesh Panels
    Capo Volta Jersey Pockets
    Capo Padrone
    • High-stretch compression technology increases circulation, regulates moisture and heat, and provides SPF 50 protection
    • Optimal muscle compression combined with a seamless harness system delivers extreme support with proven comfort
    • Anatomic Carbon "6-hour" chamois provides superior support and flexibility for longer rides
    • Jersey/Bib Shorts: $200/$250
    Capo Padrone
    Capo Padrone "6-Hour" Chamois
    Capo Padrone Anatomical Fit Detail
    Capo GS-13
    • CarbonES and HydroStretch technologies provide a balanced fit and seamless vertical transition that moves in unison with the body
    • High-gauge Lycra matched with a skillfully constructed harness system delivers muscle support and vertical stability
    Capo GS-13 Leg Gripper Detail
    Capo GS-13 Bib Harness Material
    Capo SC-12
    • CarbonE and HydroDrop provide optimal body temperature, vertical structure, and enhanced elasticity
    • High-gauge Lycra reduces fatigue and increases circulatior keeping legs fresh
    • Anatomic Carbon chamois is compact and efficiently padded for freedom of movement
    • Jersey/Bib Short: $150/$200
    Capo SC-12
    Capo SC-12 Sleeve Detail
    Capo SC-12 Base Layer Detail
    Capo Ceramica
    • European race-inspired fit with strategic panels for comfort and performance in the riding position
    • Ceramica and Carbon technologies control temperature, offer UV protection and provide unmatched durability
    • Jersey/Bib Short: $170/$220
    Capo Ceramica
    Capo Ceramica New Fabric Detail
    Capo Ceramica Base Layer
    Capo Cipressa 2.0
    • Precision design with strategic panel construction that provides optimal fit, support and SPF protection
    • Carbon Lycra and coldblack technology aid in muscle support, thermal regulation, and moisture management
    • Women's specific high-density carbon chamois provides optimal protection and enduring comfort for long rides
    • Jersey/SL Jersey/Bib Short/Short: $150/$130/$190/$170
    Capo Cipressa 2.0
    Capo Cipressa 2.0 Mesh Panel
    Capo Cipressa 2.0 Jersey Pockets
    Capo SC-12 Donna
    CarbonE and HydroDrop provide optimal body temperature, vertical structure, and enhanced elasticity Supple micro-fiber leg bands combined with high-gauge Lycra for maximum comfort and muscle support Women's specific high-density carbon chamois provides optimal protection and enduring comfort for long rides Jersey/Short: $140/$150
    Capo SC-12 Donna
    Capo SC-12 Donna Mesh Panel
    Capo SC-12 Donna Leg Bands Gripper
    Capo Bacio
    • Attractive, supple and high-elastic construction with proven moisture control and lightweight breathability
    • Extremely comfortable, non binding fit that was tested and refined by Capo women's test panel
    • High-density chamois is efficiently padded for maximum comfort and freedom of movement
    • Jersey/Short: $120/$140
    Capo Bacio
    Capo Active 15 Compression
    Olefin 200-needle high gauge construction with a lightweight single-layer 15cm cuff and footbed.
    • Made in USA
    • S/M, L/XL
    • $20.00 MSRP
    Capo Active 12 Compression
    Olefin 200-needle high gauge construction with a lightweight single-layer 12cm cuff and footbed.
    • Made in USA
    • S/M, L/XL
    • $20.00 MSRP
    Capo Active 6 Compression
    Olefin 200-needle high gauge construction with a lightweight single-layer 6cm cuff and footbed.
    • Made in USA
    • S/M, L/XL
    • $20.00 MSRP
    Capo Active Compression 2
    • Olefin 200-needle
    • Made in USA
    • $20.00 MSRP
    Capo Meryl 14 200N
    • Meryl SkinlifE 200-Needle
    • Made in Italy
    • $20 MSRP
    Capo Meryl 8 200N
    • Made in Italy
    • $20 MSRP
    Capo Avante 200 Olefin
    • Olefin 200-Needle
    • Made in Italy
    • $20 MSRP
    Capo Strada 200 Olefin
    • Olefin 200-Needle
    • Made in Italy
    • $20 MSRP
    Capo Trofeo 200 Olefin
    Olefin 200-needle high gauge construction with a 6cm cuff, padded footbed and reinforced heel and toe.
    • S-XL
    • Made in Italy
    • $20 MSRP
    Capo Custom Kits
    Capo Custom focuses on meeting the needs of all cyclists by providing a complete collection of next-generation custom cycling apparel.
    Capo Custom Kits
    Capo Custom™ focuses on meeting the needs of all cyclists by providing a complete collection of next-generation custom cycling apparel.
    apo has established itself as a premier brand of cycling apparel and accessories. Our products are designed to deliver technical performance, progressive design and proven quality. Our passion for the sport, its rich history and rewarding lifestyle make up the core of the Capo brand.
(Visited 5,381 times, 1 visits today)
