Available July 13th are ceramic bearing bottom brackets from Chris King for external bearing crank systems in road or mountain models.
We've also added a page to our website with general recommendations for re-greasing all bottom bracket models. Here's that link:
https://chrisking.com/files/upload/bottombracket/grease_chart.pdf
MSRP
$199 for Shimano™ compatible external bearing 24 mm crank spindles
$209 for SRAM GXP™ compatible external bearing 24 mm crank spindles
Available now
Source: Chris DiStefano, Chris King Precision Components
chrisking.com
- Made in the USA
- 5-year warranty
- Fully serviceable bearing. Designed to work with our BB Injector Tool
- 24 balls per bearing
- The bottom bracket is identical in construction to our standard bottom bracket but with color changes to the center sleeve, spindle sleeves and seal retainer snap ring. These color changes serve as identifying marks for the new model.
- Cups available in 10 colors.
MSRP
Available now
chrisking.com
