Continental Rubber Queen Review
Pro Reviews
I would like to thank Brett at Continental for his assistance and patience during my long test.
Bottom Line
The Rubber Queens 2.4′s are a big fat beast of a tire that has great suspension characteristics. They grab well on rocks and rough terrain, and seem to really dig in and adhere to the terrain. They need to be run with low pressure, and they seem most at home when they are carrying a lot of speed through terrain. Their size, the Apex sidewalls and the sticky Black Chili compound give the tire great braking and traction abilities, and they can carve a beautiful turn when dropped over far enough.
The little sister 2.2′s are lighter, and roll and turn better than the 2.4′s, and fortunately they still share the same characteristics. However, where size counts, they are just a tad slimmer, so I much preferred the 2.4′s.
The Rubber Queens are a great All Mountain tire with some wonderful characteristics, outside of a propensity to pinch flat and an occasional washout while cornering.
Strengths
-Big, need I say more!
-Traction and braking monsters
-Sticky rubber
-Decent mud tire
-Suspension
Weaknesses
-Pricey
-Prone to pinch flats
-Heavy
-Can washout while cornering
Value Rating: 3.5 Flamin’ Chili Peppers
Overall Rating: 4.5 Flamin’ Chili Peppers
Tire Dimension Color Weight MSRP
Rubber Queen 2.4 Black Chili,Apex 26 x 2.4 black/black 850 $74.95
Rubber Queen 2.4 UST 26 x 2.4 black/black 1050 $94.95
Rubber Queen 2.2 Wire 26 x 2.2 black/black 650 $44.95
Rubber Queen 2.2 Black Chili,Apex 26 x 2.2 black/black 650 $59.95
Rubber Queen 2.2 UST 26 x 2.2 black/black 850 $64.95
Rubber Queen url: http://www.conti-online.com/generator/www/de/en/continental/bicycle/themes/mtb/downhill_freeride/rubberqueeneng/rubber_queen_en.html
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Mile High Mark says:
    These are some of the tallest tires I’ve come across. I’m running the 2.2″ UST version, and had to switch to a 2.1″ Nevegal in the back because the Queenie only cleared my Trek’s chainstay bridge by a hair.
  • Reformed Roadie says:
    Umm…what non-studded tires work on ice? How can you really harp on that as a negative?
  • Brian Mullin says:
    Yes, studded tires are what you want if you are running around on lots of icy conditions. I have run plenty of tires in the Colorado winter, where patches of ice between snow are very common, and you need to be careful with any non studded tire, since they are not going to the best in those conditions. All of those tires I have ridden have offered at least some traction, the Rubber Queens were just useless, and slipped around, the Conti Mtn Kings did admirably on ice (an attribute for them). My job as a reviewer is to identity both positive and negative aspects and characteristics of a tire, and this was a very glaring issue with this tire while riding this winter.
  • RF says:
    who gave you the MSRP for the tires??? why is it that the price of the RQ 2.4 UST at competitive is more than $100++/tire here in the states, while in UK it’s only close to $60???
    Prices were given to me by US Brand Manager for Continental, I will cross check with him again.
  • RF says:
    so prices were updated. heard really nothing but good and rave reviews. but i still won’t buy the tires here though. why is the price almost doubled compare to UK for the RQ 2.4 UST? at least the US Brand Manager can answer you.
  • Oni says:
    have to say, was totally stoked to buy these tires, but as far as actual performance I’m not as excited. Need more time on them, but have noticed they are very dependent on PSI. Have also noticed that they are a straight line tire, once you start leaning over, things can get interesting (again, PSI dependent).
    Wear seems good for a sticky tire. Have a ride that involves a long road climb on the front and a 30 MPH road descent on the back. Still have the little hairs on them.
    A riding buddy had it on the back for one ride and then switched back to the Mountain King.
    Cost on these tires is $ as well.
    Oni
  • Grant says:
    I’ve got both the 2.4″ and 2.2″ UST versions. The 2.2″ UST tyre is made in Taiwan and does not use the Black Chilli compound. When mounted i couldn’t pick any real weight resistance difference. They are both very similar in size. I agree that the 2.2″ corners a little better than the 2.4″ version, but neither of them corner as well as a 2.5″ UST Maxxis Minion DHF. The lower weight is worth the trade off though. The 2.4″ have a smoother feel when riding. I think the tread pattern negates the need for the Black Chilli compound when running these tyres on the rear. Both seem to have plenty of traction. It’s usually a little sandy with plenty or rocks where i ride and it has been wet while running these tyres. So far they are definitely better than the 2.25″ Nobby Nics i had previously and more confidence inspiring than 2.35″ Maxxis Ignitors.
  • Dylan B says:
    Will these tires clear the rear end of a 2009 SX Trail?
    Dylan
  • Anonymous says:
    The 2.2 will fit, and most likely the 2.4, knowing Specialized geometry it should be fine
  • Dylan B says:
  • Bam says:
    Will these tires clear the rear end of a 2010 Ellsworth Epiphany SST (Medium)?
  • Cesar says:
    I read everywhere that the Blackchilli compound is not only grippy but also long lasting. In my experience with the Der Kaiser, this seems to be a big lie. 7 rides and already falling apart.
    How was the duration of your set?
    They were stickier and offered more grip, but I am not sure if it extended the tread life? I haven’t used the Der Kaiser, so I can’t comment on that. Regardless, any tire shouldn’t give durability issue after that many rides, Black Chili or not.
