Contour+ Camera Review
Cameras Pro Reviews Video
Contour+ Rear Controls and Features
Camera Features
On the back of the camera is a simple power button, along with two LED’s that informs you of the available memory and battery levels, and they fluctuate from green (50-100%) to yellow (20-50%) and finally red (0-20%). The back has rubber flaps that cover the mini USB and HDMI ports, so they can be accessed without opening the rear door. The front has an LED that indicates if the camera is on (green) or in record mode (red), and in addition, it blinks green while acquiring a GPS satellite, and turns blue when the Bluetooth is engaged.
Inside the back door, is the battery slot, a switch to change between preset video resolutions (aka 1/2), a MicroSD and Connect View card slot, a mini USB and HDMI port, and a recessed format button. Connection to various mounts (helmet, flat surface, etc.) is done via Contour’s TRails system, which is sort of like tongue and groove, and the camera has two female grooves, and the mounts have two male tongues.
Contour+ Top and Bottom Controls and Features
On the top of the camera is a mechanical slider that turns the recording mode on and off, and it is also where the 4Hz GPS receiver chip is located. Under the back of the slider is a record mode light (red), which is hidden when not recording, and at the front is the indented button to engage Bluetooth.
The lens rotates 180° clockwise and 90° counter-clockwise of the top center, which allows the camera to be mounted at varying angles, and is cross checked by using the viewfinder on a smartphone or mobile device to indicate the horizontal alignment for proper recording. The addition of a full 270° of rotation now allows the Contour+ body to be positioned upside down, while maintaining the proper lens orientation.
Measured Specs:
  • Camera – 126.2 grams
  • 8 GB MicroSD card – .2 grams
  • Connect View Card – 1 gram
  • Battery – 22.3 grams
  • Total – 149.7 grams
  • Size: 99 mm long x 58 mm tall x 35 mm wide
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Brian says:
    Great review. I had this or the model below on my wish list but switched to the Hero2 for my wish list after looking closely at the mounting options. Can’t believe it doesn’t come with a vented helmet mount.
  • Thad says:
    I just scanned the entire review and didn’t see a ” $ “. Thank you for writing it, but I’m not reading it.
    • Brian Mullin says:
      It’s on the last page just before the Overall Rating, I’ll stick it in the first page for clarification. Retail is $499
