Contour+ Camera Review
Cameras Pro Reviews Video
The Contour+ is a small, light and compact video camera, that is easy to use and includes the capability to do GPS Video Mapping. It has an excellent usage factor, combining a mechanical start/stop recording slider, loud and distinct indicator beeps for mode changes, a 270° rotatable lens and uses a Bluetooth connection to a smartphone or mobile device, as a viewfinder for horizontal alignment and to alter camera configurations. The camera records in a vast array of high-definition video resolutions up to 1080p, and has proven itself to take excellent footage with great clarity and realistic colors.
Contour+
The Contour+ is a POV (point of view) high-definition sports CMOS camera with a 5MP sensor and 2.8″ aperture, that can record video footage in 1080p, 960p and 720p formats, along with GPS mapping information (speed, location and elevation). It records data onto a MicroSD card (2GB included) up to 32GB in size, and is powered with an internal rechargeable Li-Ion battery that gives around two and half hours of recording time. The cameras Connect View card uses Bluetooth V2.1 to wirelessly converse with iOS and Android based smartphones or mobile devices to align the camera and change settings. It has ports for a mini USB for computer connection and recharging, a mini HDMI for live streaming to a TV or other sources, and an external microphone for higher-quality audio recording. The 270° rotatable lens, is flush mounted, and uses a custom six element glass for additional clarity and decreased aberrations. The small and light camera is mostly made of plastic, and uses a fiberglass lower body, with a protective anodized aluminum barrel surrounding the lens and electronics, and its impact, shock, and water resistant. The camera attaches to an assortment of mounts, including a goggle, profile, flat surface, universal adapter (camera and RAM), flex strap, vented helmet, and handlebar, using their proprietary TRails system. It retails for $499.
Contour+ Kit Contents
The kit comes with the Contour+ camera, a low profile and two rotating mounts, an instruction guide, a USB, HDMI and Mic cable, a rechargeable 3.7V 1050mAh Li-Ion battery, lens cap, leashes, and a Connect View and 2GB MicroSD card.
Video Resolutions
The Contour+ can shoot in High Definition, in three video resolutions. It can shoot in 1080p (widescreen) at 30fps (frames per second), 960p (full frame) at 30fps and 720p (widescreen) at either 30 fps or 60 fps. The 720p 60 fps allow for slow motion playback, which is pretty cool to watch, and in addition, it gives the normal footage a smoother and more fluid look. Each of the video resolutions is captured at different bit rates (which can be customized), which entails varying recording times and storage requirements, meaning greater resources are needed for the higher usage formats. The resolution settings are done within Contour Storyteller software on your local computer, or through the Bluetooth connection to a smartphone. There are two preset video resolutions for the camera, which can then be changed by using the 1/2 switch on the inside back of the unit. The camera records in two viewing angles, unique to its video resolution, so 1080p is 125°, while 920p and 720p are at 170°. It uses the H.264 video codec, AAC audio compression, and a .mov file type. Everything defaults to the NTSC standard, but it can optionally record PAL video in 25fps and 50fps increments.
Photos
The Contour+ can shoot still 5MP photos with a resolution of 2592 x 1944 pixels and 135° field of view, in an automatic mode, which allows photos to be taken every X number of seconds, where X is 3, 5, 10, 30 or 60-second intervals.
1 2 3 4 5 6Next
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
(Visited 10,162 times, 1 visits today)
Wordpress Comments:
  • Brian says:
    Great review. I had this or the model below on my wish list but switched to the Hero2 for my wish list after looking closely at the mounting options. Can’t believe it doesn’t come with a vented helmet mount.
  • Thad says:
    I just scanned the entire review and didn’t see a ” $ “. Thank you for writing it, but I’m not reading it.
    • Brian Mullin says:
      It’s on the last page just before the Overall Rating, I’ll stick it in the first page for clarification. Retail is $499
