Devinci Troy Carbon 29 rolls out
All-mountain machine with super boost 157 and split-pivot design
27.5 29er All Mountain Trail News
New Devinci Troy rolls out
Ready to rip in 27.5 or 29er with 140mm of trail taming rear suspension.
Powered by their testing is everything ethos, Devinci’s latest Troy all mountain bike boasts the company’s fifth generation split-pivot suspension platform, which is claimed to increase bottom-out force.
The new frames are 100% carbon including the rocker.
Meanwhile, its team-inspired geometry, including a 66-degree head angle, is designed to tame steep, rugged, and unpredictable terrain, while stubby 432mm chainstays keep things playful and snappy. The bike is available in 27.5 and 29er forms. Suspension travel is 140mm rear, and 150mm or 160mm front depending on the build. Here’s a rundown of other key features.
Key Features
  • Threaded BB
  • Full carbon Frame (including rocker)
  • Relocated adjustable geo flip chip
  • Asymmetric construction
  • Downtube and chainstay molded rubber protector
  • Two bottle cage position options
  • Low standover height
  • Dropper compatibility up to 170mm on L and XL frames
  • Chainring clearance 38t with 55.5mm chainline
  • Tire clearance 29×2.4
  • Metric rear shock with Trunnion mount
  • Coil compatible
  • Post mount 180mm
  • Compatible with FRG cup
The split-pivot design is aimed at increasing bottom-out force.
Prices for the carbon framed bike range from top of the line SRAM XO1 Eagle build for $8799, to a less eye watering SRAM NX version for $4449. Frame and fork are $3249. There’s also an aluminum frame model set for release in late fall. It will have the same 140mm/150mm travel set-up, and will also be available in 27.5 and 29er with SRAM Eagle GX ($3749) and SRAM Eagle NX ($3199). The alloy frame and shock will sell for $1999. Scroll down to see complete build specs on the carbon bikes.
For more info on the Devinci Troy head to www.devinci.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
  • LarsV says:
    I like the dark orange accents!
    That rear end however, stacking superboost, split pivot and a DT RWS skewer, is going to be wider that yo’ mamma’s 🙂
