DT Swiss Interbike 2013
Interbike Sponsored post
Chad Eskins with DT Swiss shows off the newest offerings in their MTB lineup, with the Spline One series featuring the XR 1501, XM 1501, and EX 1501 wheels.
The XR 1501 Spline One comes in every wheel size, 26, 27.5 and 29-inch and is suited for Cross Country Race. It has a 20mm internal width, 24mm external width, and is easy to convert from quick release to thru axle. It comes with 36 tooth star ratchets, is compatible with the SRAM XD body and the 26″ weighs in around 1400g.
The XM 1501 Spline One for Cross Mountain features 22.5mm internal width and 27mm external, is fully taped and tubeless ready.
The EX 1501 Spline One for Enduro racing has 25mm internal width, 30mm external width, 36 tooth ratchets, fully taped for tubeless and the 26″ set weighs in at 1660g.
For more information visit www.dtswiss.com.
DT Swiss Interbike 2013 Gallery
of
DT Swiss Spline 1 Hub
Spline One wheels showcase DT’s modular hub system, allowing the user to adapt to different axle and frame standards through a simple tool-free end cap swap. Interchangeability isn’t the only benefit to this system. Addi-tionally our design allows for simple and quick routine maintenance of the hubs internals using little to no tools.
High Pressure Rim Tape
New high pressure tubeless tape makes it easy to apply and easy to repair.
24, 27, 30mm Rim Widths
Spline One wheels feature a unique rim profile that addresses the trend for wider rims in a lightweight package, but still remains durable. All wheels feature rim profiles engineered specifically to maximize the rim’s material across all categories of weight, width and performance.
DT Swiss XRC 1250 Spline
Cross Race Carbon. Every Cross Country racer's dream. The superlight and wide carbon rims paired with high performance Spline Ratchet System hubs create attention and respect right from the startline. 1360g per set. $3051 per set for 27.5" and $3076 per set for 29".
DT Swiss Carbon Rims
XMC 350 27.5 and 29" Rims.
DT Swiss EX 471 and XM 401 Rims
EX 471: Wide tires and the most demanding trails: Enduro rims are made for the rough stuff. Yet from the value oriented 533d to the race ready EX 500, they are light enough to master any climb. XM 401: The best of both worlds: Light enough for any climb, wide enough for 2.4” tires. High end alloys and sophisticated profiles – now available in 26, 27.5 and 29 inch options.
DT Swiss X 313 Carbon
The X 313's technology paired with the superlight full carbon air chamber result in the world's lightest shock. The perfect choice for sporty trail or XC racing bikes! 145g.
DT Swiss XMM 100/120 One Piece
Cross Mountain Magnesium. With the new One Piece Mag lowers, these XMM forks are built on a superlight platform available in 26", 27.5" and 29". Adjust air pressure and rebound damping and it's off to shred trails!
Dropout
15mm dropout.
DT Swiss 27.5 with One Piece Mag Lower
he new One Piece Mag lowers, these XMM forks are built on a superlight platform available in 26”, 27.5” and 29”. Adjust air pressure and rebound damping and it’s off to shred trails!
DT Swiss 2013 Interbike Booth
