Dynaplug Air review
Essential tool for anyone racing or riding on tubeless tires
Gear
Dynaplug Air
Purchase a Dynaplug Air and you’ll receive four plugs (one already inserted in the tool), the tool, two CO2 cartridges, and an accessory air hose attachment (not shown) that provides the ability to inflate via the valve.
What is it
Dynaplug’s Air tool takes plug kits to the next level with integrated inflation. With tubeless plug kits such as this, riders can fix a cut and retain a tubeless setup for the remainder of the ride. In some cases, a plug will last through the remainder of the tire’s life.
Dynaplug Air
Shown ready for action, the Dynaplug Air may save your next ride or race aboard tubeless tires.
With Dynaplug’s Air tool you get both a plug kit but also the ability to inflate tire quickly, saving precious fluid and time. The inflation takes place via the plug insertion tool and bypasses the use of the valve entirely.
Pros
  • Tubeless repair in a small package
  • No need for separate inflation and plug kits
  • Made in U.S.A.
Cons
  • Inflation holes require fairly deep penetration of the tool, risking tubeless rim strips, especially on smaller tires like those used in gravel
Mtbr’s Take
Tubeless tires are one of the greatest technological leaps forward for bicycles ridden on dirt. But no system is perfect. The solution to a large sidewall or tread cut used to be the use of a boot and installation of an inner tube. This often robbed the rider of fun for the rest of ride back to the car, as you need to be far more cautious when running a tube.
Dynaplug Air
A close-up look at the Air tool reveals a pair of small holes on either side of the tube that deliver CO2 into the tire, inflating it while also installing the plug.
Tire plugs have saved a few rides for my friends and myself in recent mountain biking seasons, and Dynaplug’s Air tool saved an entire weekend of riding, and months of preparation, for me at the iconic Trans Iowa gravel race in late April. As a passing truck kicked up dust and obscured my view of the road hazards ahead, a descent started. Nearing maximum velocity I heard the dreaded hiss. I soft pedaled my way to the top of the next rise and then examined the damage.
Dynaplug Air
Here’s the plug that saved my Trans Iowa. Despite its location, it held for hundreds of gravel miles.
There was a good sized cut right at the edge of the tire’s tread that sealant alone wasn’t going to fix. Out came the Dynaplug Air. I figured I’d give it a go despite some doubt over the plug’s ability to seal a sidewall cut. Inserted, I twisted the CO2 cartridge to inflate the tire. Here’s where I ran into a small issue.
Dynaplug Air
Excess plug can be trimmed but I had tire clearance and left the plug as it was for the remainder of the tire’s life.
While the Air is clearly designed for mountain bike tires, I was on a gravel bike with a 32mm tire. If I inserted the Air tool far enough to position the inflation holes inside the tire I risked puncturing the rim strip with the tip of the plug. It took some careful maneuvering to get it all situated nicely but the Air kit did the job. On larger volume tires I don’t think this will be any concern.
I added a bit more pressure from my mini-pump and took off for more miles of gravel. Amazingly, the plug and remaining sealant held air for the rest of that day, all of the following night, and all the way to the finish line the next afternoon. When I pulled the wheel out after traveling home, it still held air.
Dynaplug Air
The Air tool, two CO2 cartridges, and spare plugs easily fit inside the included zippered neoprene pouch.
Dynaplug’s Air kit is now a must-have for me in both my mountain bike pack as well as my gravel kit. While there are cheaper plug kits on the market, none pair inflation through the tire puncture and few are made as well as Dynaplug’s.
Rating: 5 out of 5 5 Flamin' Chili Peppers
Price: $75
More Info: www.dynaplug.com
About the author: Nick Legan
Nick Legan is happiest with some grease under his nails and a long dirt climb ahead. As a former WorldTour team mechanic, Legan plied his trade at all the Grand Tours, Spring Classics, World Championships and even the 2008 Beijing Olympics. In recent years, gravel and ultra-distance racing has a firm grip on Legan’s attention, but his love of mountain biking and long road rides hasn’t diminished. Originally a Hoosier, Legan settled in Boulder, Colorado, 14 years ago after finishing his time at Indiana University studying French and journalism. He served as the technical editor at VeloNews for two years and now contributes to Adventure Cyclist, Mtbr and RoadBikeReview. To follow along on Legan’s cycling adventures, find him on Instagram at @nlegan and be sure to check out his new book Gravel Cycling: The Complete Guide to Gravel Racing and Adventure Bikepacking.
Wordpress Comments:
  • Fleas says:
    If you already have the dynaplug in your tire, is the brass pointy thing still in there too? If you were unlucky enough to flat your tire a 2nd time, the brass pointy thing would do some damage, right?
  • Brian says:
    User of the regular dynaplugs. They are great and come in convenient, if pricy, packages. Bigger holes/sidewall tears will need multiple or there “mega” plug. A single plug has been effective 50% of the time. I have not had to put a tube in in 2 years because of these.
    I use bullet shaped plugs
    Has not been an issue with repeat flat.
    I do not change my tire if they work and have put several hundred miles on them
    **If you need to put in a tube you need to take out a spike, friend forgot and punctured tube from spike.
    Yes there are cheaper options that may work as well, but I am happy to pay for such a well designed life saver. The metal case keeps it all together well.
  • Frank says:
    Note that there is the less expensive Racer model and more complete Micro model, just BYOCO2.
