Eriksen Sweetpost Review
Pro Reviews
Here are the basic parts of the Sweetpost: a titanium tube with a welded on top tube with notches, an aluminum inside plate set with notches and a slot for saddle rails, an aluminum outside plate set with a slot for rail, and a bolt. The plates (aka caps) notches mesh into the top tube notches’, giving rise to a micro adjustment system. If you play with the system a lot the soft aluminum parts can wear a bit against the harder titanium, so you may need to replace the caps at some point in time?
Installing the Sweetpost is incredibly easy, and can be done in a very short period of time. Start to perfect finish in perhaps 30 seconds, give or take. Rotating and sliding the saddle is done with a simple 5mm hex key on one side of the seatpost clamp, and small angle adjustments can be done due to the ingenious micro notch system.
Just attach the inside plates’ with the notches inward, meshing with the seatpost notches, and align the plate’s slots, with the slots on the top. Slide the saddle rails into the slots starting from the rear of the saddle, and push the saddle backward to a rough desired location.
Roughly center the saddle in the slots, both in rail and angle positions. Attach the outside plates with the slots inwards onto the rails, aligning them together.
Insert the bolt into the proper outside plate hole, and slightly tighten with a 5mm hex key. Slide the rail into position (fore or aft), and rotate the saddle to the desired angle, and then tighten the bolt to 12-15 NM of torque. Done! If any minor adjustments are required, just loosen the bolt and move the saddle as needed, the micro notches keep things stable so that the saddle won’t flop around while adjusting or tightening.
Next » Impressions
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Scoty in Salida says:
    I’ve been riding several Sweetposts since 2006 and have Zero problems.
    Light, supple, strong, simple, elegant, bomb proof.
  • Mike says:
    Never having ridden one, I shouldn’t judge, but this doesn’t appear to be a very robust design. Without question there are other much worse seatpost designs, but for the price of this one, it ought to be bombproof and warranted forever.
    Angle of the seat relies on aluminum teeth. As mentioned in the article, these teeth wear. (Bad material selection!) So the rider may be forced to overtorque the binder bolts, which may lead to damage to the seat rails.
    But wait, there’s more: a single bolt holds it all together. No big deal, lots of posts use only one bolt, right? — Yes, but those other posts have a bracket underneath the saddle rails that supports the mass/load from the rider. The binder bolts just keep those saddles held down. On this design, the bolt is partially loaded in bending and in shear. Worse, the bolt is threaded into an aluminum end cap. What do we know about overtorquing aluminum threads?
    Needless to say, I’m not sold by the beautiful craftsmanship. I’m going to keep riding my Thomson until i die — it will outlast me, because it’s designed right!
  • Dave says:
    This is the best seatpost I’ve ever used and the only post I prefer over a Thomson. I’ve had mine for a little over a year and have zero complaints and zero problems. As stated in the article the adjustment is easy (better than Thomson) and the craftsmanship is outstanding. I can’t comment too much on the ride quality as this is the only post I’ve had in my Eriksen frame, but it is quite nice. I would have no reservations purchasing one for my other bikes.
  • Paul says:
    I’d love on of these- but alas i run a gravity dropper- which is way better for trails :D
  • Ruger says:
    I cant imagine an improvement over my Thomson Masterpiece.
    I also just got a gravity dropper 3″ drop and a one inch increment. Way fun but heavy.
    Fortunately one can use both, mounted a WTB Vigo on each depending on what I’m doing I decide which to use.
    Found I use the GD more and more weight be damned its just too cool!
  • norcal rider says:
    I was surprised at the reported weight — quite a bit heavier than a thomson masterpiece post. Although the Eriksen has the anodized cap ‘bling’ factor, I’d rather spend a lot less money and get the trusted reliability of the Thomson Masterpiece (or the Elite, which is cheaper still).
    At least with the Lynkskey Ti post you’re getting a light weight post.
  • pastajet says:
    My observations were that the cap’s aluminum notches ‘may wear prematurely if adjustments are made frequently’, during all of my saddle swap outs and minor adjustments over my 1 year time with the post everything was still fine, and no slippage has occurred. My job as a reviewer is to nit pick anything no matter how minor.
    In regard to the robustness of the design, I had no issues during my testing, that single bolt is pretty darn large and beefy and the caps are not that thin. This weekend at a bike show in Colorado, Eriksen showed me a slightly beefed up cap system to alleviate any small concerns that anyone might have had.
    The Thomson is a fine post, but it has none of the properties of titanium. One ride on titanium will seal the deal for feel, nothing comes close. The issue with titanium comes down to tube sizes, which are usually 27.2, Eriksen recently added the 30.9.
    The Lynskey Titanium Seatpost weighs in at 214.2 grams (400mm), and uses the less robust and difficult to use yoke system. I am currently testing it also. It is a major chore to adjust and swap out saddles in comparison to the Eriksen (10-15 seconds).
    I have used more than my fair share of seatposts with multiple clamp systems, and the Eriksen is fine. Is their system perfect? No, nothing is, but theirs is elegant (thks Scoty) and simple.
  • Kosmo says:
    Great post on a racing hardtail. Adds just a little “cush” for long rides. Being a bigger guy (195), I’ve had some slippage issues. Three times in two seasons, never during a race thank goodness, and overtightening the bolt a bit seemed to cure this.
    Maybe I’ll check in with Kent next week and ask about the tougher clamp.
  • Vince says:
    I’ve been using Thomson posts on my hardtails and FS bikes for several years without any problems. After riding a Moots layback post on one of my hardtails, I realized there’s a significant difference in ride quality between Ti and Aluminum posts. So as soon as I could afford it, I swapped out my Thomson post for an Eriksen on my IF Ti SS earlier this year. I’ve done numerous 50 mile rides and XC races on the Eriksen post and not one issue. The Eriksen post is easier to adjust, smooths out small trail chatter, and just looks damn sexy.
    Thank you, Kent, for not settling for “good enough”.
  • kurti_sc says:
    @Mike – you do bring up a good point about the serrated teeth on aluminum. It would probably work better without them anyway. However, I think you need to check your analysis of the loading condition of the bolt. I believe it would be only under compression / tension. And I believe that the tension load would cycle MUCH less than what you see in the more traditional posts that have brackets under the saddle. Those will be cycled with every single bump; and on some designs, with a good bit of leverage to boot.
    If this single bolt is tightened corretly, the load would have to overcome the compressive forces of the bolt and the friction between the ti surfaces and aluminum caps. then it could be a shear load – but then also notice that there is a ring inside of those caps that goes INSIDE the diameter of the ti piece. These would be effective load bearing surfaces – not the bolt.
    Just my opinion, but i’m pretty sure of that. Look at it again and see if you agree. Personally, I think these things are pretty cool looking. If I can get one with my spelling on it (“Erikkson”) and some fine looking Norwegian colors, I’m sold!
  • mark dunn says:
    Even better – I have been using same the Synchros Ti post since 1995 – on a hard tail frames only! I will take it to the grave with me.
  • Greg P says:
    I love this post too, but I love the original design by Albert Bold of Eastern PA a lot better. because it is HIS design.
  • Piers says:
    I got one because Tompson didn’t do one long enough, although 2 of my other bikes have Tompson posts, and I didn’t trust my RooX post (diameter was just too narrow for the seat tube, indicating quality control issues, and I managed to deform the top plate of the cradle – I did have an older RooX that was perfect for 7 years of hard XC riding).
    The design is similar to the Bold cradle but the cost is more reasonable.
  • Anonymous says:
    In regards to “I love this post too, but I love the original design by Albert Bold of Eastern PA a lot better. because it is HIS design.”
    I spoke with Eriksen, and they said…
    “Actually no, it is not a copy of anyone’s design, but it is showing up everywhere now, even Bontrager has come out with a similar design. We have sold the hardware to plenty of designers, and we have actually had the hardware in-house for about 5 years”.
    I would assume that when you start to poke around with a simple seatpost clamp design, you start to come to something like the same generic design. The current Bold design is also slightly different in its approach.
  • don says:
    I have had one now for 3.5 years on two scandium hardtails. First one was geared, the 2nd a SS. For a hardtail it is just the ticket. You get the compliance of carbon without the scoring and subsequent failure potential. I don’t use it on the fully, nor see the point of doing so. My typical rides range from 3 to 24 hour rides, sometimes with up to 30lbs on my back. On these longer rides with a bit of a load on the body, I have found that I don’t unweight the seat as often as required due to accumulated fatugue. Therefore it takes some less than desireable weighted hits. Unfortunately, so does the posterior. I have never had the post so much as snivel, period. I have used Thompson, as well as many other designs out there. Thompsons are great, but not made of Ti, thus do not give the compliance on a hardtail. It the distances I ride, there is no room for problems. If gear does not work, it is replaced immediately. I will keep this post for life.
    One final comment. There is a lot of supposition in some of the previous posts based up assumptions. While I can understand some of the concerns, especially with an Industrial Design background, they should be taked for what they are…preconcieved notions. There are plenty of satisfied riders who have actually tried the product.
