e*thirteen TRS+ 9-46T 11-speed cassette review
Wider range, less weight, and lower cost than SRAM Eagle
Components
e*thirteen TRS+ Cassette 2018
Lusting after an 11-speed drivetrain? E*thirteen’s newest cassette provides SRAM Eagle like range at a reasonable cost.
What is it?
SRAM’s original 11-speed 1x drivetrain delivered a massive 420% gear range. Coupled with a narrow-wide chainring, this technology was enough to convince most mountain bikers (and brands) to kiss the front derailleur goodbye.
E*thirteen’s latest versus SRAM Eagle.
While this range worked for most riders, there are still places in the world where more was needed. To answer those doubters, SRAM debuted their new Eagle 12-speed drivetrain. That cassette has a 10-50t spread, which translates to a 500% range.
That’s great news for anyone buying a new bike, but some us have 11-speed drivetrains that are still going strong. If you’re intrigued by Eagle’s range but don’t want to upgrade your entire drivetrain, e*thirteen’s 11-speed cassettes boasts Eagle-like performance at a fraction of the cost.
Learn more about the e*thirteen TRSr cassette in the Mtbr first look here.
The cassettes are available at two price points. The TRSr is the premium model. When it debuted last year, it tipped our scales at 303g and boasted an impressive 9-46T range. For anyone that’s counting, that’s a 511% spread, which is actually wider than Eagle. It’s also ~50g lighter than the fanciest Eagle cassette. The only problem was the price. Retail was $350.
Just below the TRSr level is the TRS plus. Previously, this cassette offered a solid 9-44T range. The cassette now delivers the same range as its pricier counterpart, but retails for a $100 less. If you’re okay pushing an extra ~36g uphill (339g vs 303g), that seems like a deal.
The two halves of the cassette lock together.
In addition to gearing updates, the entire unit has been redesigned. The previous version consisted of three different components. The upper cogs were alloy, while the remaining steel clusters fastened together. The newest iteration uses a two-piece system. The three big rings are still alloy and mount to an XD driver via a lockring. The remaining cogs are steel and fix onto the alloy rings with a little help from your standard chain whip.
Install is a little trickier than your standard cassette and requires a special tool, which is included with purchase.
The advantage to this system is that if you wear one half of the cassette before the other, you can replace it. The design also eliminates the standard lockring, so the cassette can go down to a 9T rather than just 10.
Pros
  • 511% range, 11% wider than Eagle cassette
  • 17g lighter than X01 Eagle cassette
  • Ships with required install tool (a 45mm or 1 3/4” 12-point deep socket works, too)
  • Two-piece design allows replacement as cogs wear out
  • Replacement parts readily available through shops or online retailers
  • No modification required
  • Creak free
  • Predictable jumps
  • Compatible with SRAM, Shimano, and Box drivetrains
Cons
  • Doesn’t shift as well as SRAM or Shimano, especially under load
  • Requires a special tool for install
  • Still expensive at $249 with no lower-cost versions
  • Wears faster than SRAM or Shimano equivalents
Mtbr’s Take
We’ve been running the e*thirteen TRSr version of this cassette for eight months with zero issues. The TRS+ is essentially the same design. It uses the same two-piece construction, installation process, shift pattern, and gearing. The only difference is the amount of machining. Think of it as the difference between Shimano XT and XTR. Both components deliver virtually the same performance; the main difference is weight and price.
After eight months on the TRSr cassette, we’ve had zero issues.
If you’re looking for the absolute lightest cassette, the TRSr is the way to go. If you’d rather save $100, the TRS+ is the better option. For $250, it delivers reliable shifting. It’s not quite as crisp as the Shimano or SRAM equivalent, but it’s something you can overlook if you need the range. However, the performance under load leaves something to be desired. Shifts were noticeably harsher than with the OEM cassette on both our SRAM and Box drivetrains. This problem seemed to worsen on the TRSr as the mileage increased.
The TRS cassettes tooth count is 9-10-12-14-17-20-24-28-33-39-46t. The previous version had a 32-38-44.
While you may feel that either the 9T or 46T is overkill, you have to ride to appreciate it. With this gearing, you can actually reduce your chainring size while maintaining top end speed and expanding low end torque. And because e*thirteen compensated for the increase in gearing by adjusting tooth count (rather than just slapping on a bigger ring) the drivetrain jumps feel predictable and consistent. The gaps towards the 46T are on the wider side, but again, it’s a compromise we’re willing to live with for the added range.
With the previous version of this cassette, there were some complaints regarding creaking. The issue stemmed from tolerances on various XD drivers. With some designs, the inside of the steel cluster would make contact with the edge of the driver, which caused a creak. The simple solution was applying grease, but to eliminate the issue entirely, e*thirteen incorporated a Teflon bushing into the steel cluster. We’ve run the cassette on both DT Swiss and e*thirteen wheels without any problems (or noise).
The e*thirteen cassettes stack up well against competitors.
If you’re trying to compare the TRS cassettes to the competition, here’s what you need to know. A standard 11-speed replacement from SRAM has less range, weighs a touch more, but shifts better. Shimano cassettes are far heavier and have less range (although you can fix the range issue with a Shark kit from OneUp). Wolf Tooth also offers a 49T option, but you have to modify your derailleur. With the TRS Cassette, you save weight, you don’t have to modify your drivetrain, and you get range that’s on par with SRAM’s latest.
Overall, the new TRS+ cassette is a major improvement over its predecessor. It’s easier to install, has a wider range, and costs less. If you’re in the market for a new cassette and envious of Eagle’s 10-50t range, this product offers a real solution. It may not shift quite as crisply, but your legs will thank you on the next climb.
Rating: 4 out of 5 4 Flamin' Chili Peppers
MSRP: $249
More info: bythehive.com
Wordpress Comments:
  • teleken says:
    Sure you get the gear range but holy large cadence jumps Batman.
    • zipp23 says:
      sometimes when a 17 is too small and a 18 too big I wish I had a 17,5 teeth cog…I really like to pick my cadence ;-D
  • Tony Lapinskas says:
    Different strokes for different folks, but for me and the way I ride, a $50.00 plus 11-46 Sunrace cassette is all I need. Shifts great, going on second year, no problems. Guess that’s why some buy Rolex’s other Timex.
  • Chris says:
    “Shimano cassettes are far heavier”….. XTR weighs 328 grams, in between the two cassettes reviewed here. Smaller range, yes.
    If you’re an XC racer maybe you need the range… but if you’re riding AM or enduro, and you’re in shape, 11-40 should be enough.
  • per eide says:
    i have shmno xt 10-42
    can i put on a 9-46 on the same hub?
  • Ratt says:
    Got the TRS+ when it first came out and loved it, Its what Sram promised but did not deliver in 11sp. First I’ve had 3 different TRS+ on my bike and they all fit differently (ie inconsistent tolerances). I find the steel gears to actually wear better than Sram xo1, the alloy bit not so much. Shifting is great, just slower in the middle where the bigger jump is, but the creaking is driving me nuts, that telfon washer only lasts me 3 months. Was really going to get a TRSr till now, just ordered a Eagle xo1/gx mix, the creaking is just too much.
  • AC says:
    The “pro” information that this has 11% more range than the Eagle is wrong and misleading. An increase of 11 percentage points on 500% means this cassette provides only an increase of 2% in range over the Eagle.
  • BlackBean says:
    The reason 10-42 didn’t work for some people is because it did not have enough low-end range. Going down to 9t does not fix that. Sunrace has a new 11-speed cassette that matches Eagle (10-50) which addresses the bigger range issue (for the non-racing community).
  • Jose says:
    what is the difference between a RACE and a PLUS cassette?
    • Gino says:
      The parts are lighter on R, 30 g. No other difference than a more hollow body. Not worth it I would say, unless money is no issue. I think you could get more grams/$ somewhere else than the 100 USD for 30 g here. I would put the 100 extra USD on the rims.
  • Gino says:
    I have this. It is really the best thing I have upgraded on my bike ever. It shifts even better than my original SRAM-cassette and I did not even change any setting, just ran perfect direct. So it is lighter, gives more range than Eagle and is super easy installation (it makes no sense saying a special tool needed as the socket is included). So I can’t agree with any of the cons above except may the price, it could be cheaper, but still the most sensible upgrade you can do if you want more gear ratio and already have 1×11. XTR with e13 I would probably say would be my dream combo, even better than Eagle.
  • Tomfish says:
    I swapped out my xt cassette and shimano driver to the XD driver and the trs+ cassette running on Hope pro4 hubs and XTR der/shifter/kmc chain. It is lighter than the shimano setup, has more range, and shifts the same as the shimano did imho? definatly more money but that 46t sure is nice on the soul crushing climbs. I guess the only thing left to see is how long it lasts me. I run a 32t oval chainring on my pivot 429 trail.
  • ttf says:
    the new pinch bolt version of the TRSr cassette (2018) is only held onto the freehub by a pinch bolt that clamps the larger 1/2 of the cassette around the smooth part of the XD driver, held on only by friction. this clamping surface is only about 4mm wide where it actually clamps around the freehub body. it does not have a lockring to permanently and securely lock it onto the freehub, unlike almost every other cassette out there. installed perfectly according to e13 tech doc, but the cassette slid laterally on the freehub body to the drive side hitting the carbon frame taking a chunk out of it. e13 offered NO help and said thats no possible to avoid liability for damaged frame.
    BTW this was on a brand new bike, new cassette, new ethirteen plus wheelset. put the cassette on a brand new x0 hub and the same thing occurred. Even if this is a one-off manufacturing defect it is a TERRIBLE design.
    BTW i have the lockring verson (trs +) and it works perfectly. avoid this new pinch bolt version AT ALL COST
