Eurobike 2015: Lezyne offers higher powered lights and updates on pump head
Lezyne's most popular lights get an upgrade and more power!
Eurobike Lights
Eurobike Mtbr
The Lezyne Zecto Auto rear light featuers three LEDs and six modes.
The Lezyne Zecto Auto rear light featuers three LEDs and six modes (click to enlarge).
Worried about forgetting to turn off your rear light? The Lezyne Zecto Auto switches off automatically after three minutes of non activity – to turn itself back on when it senses motion again. Chargeable via micro USB cable, it has a CNC frased alumuminum body and composite matrix parts. Added side visibility and possibilities to mount by means of a very durable elastic strap or with the built in Clip-On system. The light has three LEDs and offers six modes – one being a super bright Daytime Flash Mode for more visibility, even when the sun is shining.
The Lezyne Hecto Drive XL front light with new housing to accommodate the larger rechargeable battery.
The Lezyne Hecto Drive XL front light with new housing to accommodate the larger rechargeable battery (click to enlarge).
More light, different housings and changed charging docks
The Hecto, Micro, Macro, Power and Super Drive all got different housings, to accommodate the larger rechargeable battery which is needed to get more power output. The battery is integrated in the housing. The Hecto and Micro Drive get a USB stick-like charging dock, while the Macro, Power and Super Drive have their charging connection through an USB cable. The Hectro Drive has 1 LED, the Macro, Micro and Power Drive have 2 LEDS. The powerhouse Super Drive will have 3 LEDs and gets a fin like structure on the housing to dissipate heat generated by the powerful LEDs. The mentioned lights are sold as sets with two plastic handle bar mounts and universal helmet mount for the Hecto, Micro, Macro and Power Drive. Because of its weight, the Super Drive will get an alloy bar mount, as well as a different – more stable – helmet mount. All mentioned lights have increased side visibility and by shortly pushing the on/off button one time, you can read the battery level that is displayed through three different color codes (green – orange – red).
Super Drive XXL (left) and Deca Drive XXL (right) front lights.
Super Drive XXL (left) and Deca Drive XXL (right) front lights (click to enlarge).
More power means:
  • Hecto Drive: 150 → 300 Lumen
  • Micro Drive: 300 → 400 Lumen
  • Macro Drive: 400 → 600 Lumen
  • Power Drive: 700 → 900 Lumen
  • Super Drive: 1000 → 1200 Lumen
Powerful Deca Drive
The Deca Drive light has 3 LEDs which generate 1500 Lumen. Through a special lens, the beam is not too concentrated, so you have a better periferal vision at night. The light has high speed 2 Amp USB charging capabilities through a compatible wall adapter.
Continue to page 2 for more new Lezyne products »
About the author: Jeroen Tiggelman
Jeroen is a contributor based in Belgium. He is expert in the field of photography and a fan of local beer.
Wordpress Comments:
  • sgerecke says:
    It’s nice to know that Lezyne has introduced a pump head to replace the one that is total garbage that came on two pumps I have now. It’s also nice to know that I can buy that for $17.99 each. What was wrong with the flip lever pump head that every pump I’ve ever had came with?
    • CycleCross Madman says:
      Looks like Lezyne is knocking of Birzman now. Nice pump head guys. Really, couldn’t come up with something original yourselves?
