The MaxxD is our favorite light from Exposure this year. It sports 4 Cree XPGs and puts out a wide beam pattern rated at 1285 lumens. When used in tandem with a helmet mounted Exposure Diablo, this is a system that will provide excellent light in a lightweight, hassle-free package.
And its craftsmanship is typical British so expect only the best machining, CNCing and laser etching. We like the ergonomics of this light except the off switch which requires a long 3 seconds of pressing the small button. If you get it wrong, you’ll fall in the dreaded flash mode.
New for 2012 is a gold-plated smart port and a rubber smart port cover. The smart port is typically used for charging but it has other nifty tricks like:
- Accepting a remote switch
- Integrating with a tail light
- Charging another light by leveling the battery levels
- Accepting a remote battery
- Charging a smart phone
Specifications:
- Price: $500.00
- Claimed Lumens: 1285 Lumens
- Light Head Weight: 276 grams
- Installed Weight: 276 grams
- Run Time: 3 Hours
- Measured MTBR Lux: 85 Lux
- Measured Lumens: 800 Lumens
Mounting:
Handlebar mounting is done with a handlebar clamp that is bolted on. It has a spring loaded pin that locks a cleat on the light unit. It’s nifty but not ideal if you take the clamp off and on the bike to move it to another. It requires a tool and a rubber sleeve to lock the clamp in place. Left to right aiming is possible but it requires positioning and locking on the cleat with an allen tool as well. This system is really better suited if the clamp just stays on the bike.
Related Links
Mtbr Lights Shootout Main Page »
2012 Bike Lights Shootout »
Backyard Beam Pattern Comparisons »
Trail Beam Pattern Comparisons »
Light Meter Measurements »
Mtbr Lights Reviews »
Mtbr Lights Forum »
