Fezzari Cascade Peak Pro review
Capable — and affordable — 130mm 29er trail bike
29er
The Fezzari Cascade Peak Pro delivers a lot of bike for $3499.
What is it
The Fezzari Cascade Peak Pro is a versatile all-mountain machine. Built around their AT529 frame design, it has adjustable GA-Link geometry to keep a consistent BB height when changing between 29er and 27.5+ set-ups. The Tetralink AT529 suspension delivers 130mm of travel and is said to improve pedaling efficiency and add a more progressive curve for a bottomless feeling. Like all Fezzari bikes, the Cascade Peak Pro is sold consumer direct and delivered direct to your door.
Pros
  • Easy out-of-the-box build
  • Fits 29er and 27.5+ wheels
  • 27.5×2.8 or 29×2.5 tire clearance
  • Painless wheel swapping
  • Tapered headtube for added strength and stiffness
  • English threaded bottom bracket for easy maintenance
  • Oversized hydroformed alloy tubing with single pass smooth welding
  • Shorter seat tube for improved standover and dropper post clearance
  • Attractive price
Cons
  • Dropper post setup can be complicated for new users
  • Oversized bars limit stem options
  • Low bottom bracket in 27+ configuration can cause pedal strikes
  • Limited color options
This build includes a Fox Transfer dropper post in 100mm, 125mm, or 150mm travel lengths based on customer setup preference.
Spec Highlights
  • Fox Float 34, 29er fork, Performance Elite 3-Mode Fit4 damper, 140mm travel
  • Custom tuned Fox Float 3-Mode EVOL rear shock
  • SRAM GX Eagle 1×12 drivetrain with 10-50t cassette
  • SRAM X-SYNC 2 Eagle 32t chainring
  • WTB Volt Comp saddle
  • Truvativ Descendant 6K Aluminum Eagle Crankset
  • SRAM Level T brakes with Centerline 180mm/160mm rotors
  • Stan’s Flow MK3 tubeless ready wheelset with Stan’s Neo Durasync hub
  • Maxxis Minion DHF and DHR 29×2.3 tubeless ready tires
  • Fox Transfer dropper post – 100mm, 125mm, or 150mm based on custom setup
  • Fezzari Charger 35mm alloy bar and stem
  • Fezzari lock-on grips
  • Tubeless setup available after adding bike to cart
Mtbr’s Take
Fezzari was founded on the ethos of “building the best quality bikes in their class while still delivering exceptional value and experience to its customers.” The Utah-based company is a direct-to-consumer seller, meaning most buyers do not have the chance to test ride their bikes before purchasing. But Fezzari addresses that issue head on, taking key body measurements via their 23-point fit system to ensure a ready-to-ride experience with every bike they sell.
Building up your new Fezzari Cascade Peak Pro is as simple as following these basic instructions.
After completing your purchase on-line, your Fezzari bike arrives pre-built and fit to your specific measurements and riding style. Minutes after opening and cutting a few zip ties, the Cascade Peak is nearly dialed. All tools required for assembly are included, plus there’s an easy-to-follow instruction sheet. Within 15 minutes the bike is assembled (fork and shock were set up to my weight before shipping).
Mtbr’s first test rides on the Fezzari Cascade Peak Pro were on snow-covered Pennsylvania singletrack. Later, we got out on hard packed trails in sunny West Virginia. It all added up to a 6-month test period with hundreds of trail miles logged. To say we put this bike through its paces would be an understatement.
Chainstays are a snappy 432mm on the Fezzari Cascade Peak Pro.
The Fezzari Cascade Peak Pro alloy AT529 frame features all internal cable routing and has a clean look. The frame is boost-spaced with a 12mm thru-axles for stiffness, and a threaded bottom bracket for reliable and quiet operation. Fezzari uses oversized bearings for the primary linkage to further maximize durability.
A 66.9-degree headtube angle and shorter wheelbase (compared to the average all-mountain rig) gives the Cascade Peak Pro a playful ride. The low bottom bracket keeps it grounded while descending. However, some pedal strikes occurred in pedal-heavy sections of trail, but only when the bike was set up in the 27.5+ configuration.
This custom tuned Fox Float 3-Mode EVOL rear shock delivers 130mm of trail taming suspension.
Fezzari kept the chainstays short at 432mm, which helps the Cascade Peak Pro nimbly navigate tight twisty singletrack and flowy berms. And the top of the seat tube on the latest version of the Cascade Peak Pro is lowered to reduce standover height and allow longer travel dropper posts.
With a price of $3500, the build and components are top-notch, including an 140mm Fox 34 Performance Elite fork, Fox Reverb dropper post, Fox Float DPS shock with 3-position adjustment, and full SRAM GX Eagle 12-speed drivetrain. Available sizes are S, M (tested) L and XL.
There’s a threaded bottom bracket down there. Well done Fezzari.
Bottom line, the Fezzari Cascade Peak Pro, whether in 29er or 27.5+ mode, eats rock gardens and roots for breakfast. I never worried when confronted with a steep punch or long climb, as the suspension provided a super stable pedaling platform, with zero bounce during hard out-of-the-saddle efforts. Indeed, the Fezzari Cascade Peak Pro is a heck of a deal for anyone looking to spread a single bike over several different riding styles. It is equally comfortable on cross-country hammer fests and all day enduro epics. And though the 29er set-up fits my riding style better, the 27+ set up came in handy for snow days.
Rating: 4.5 out of 5.0
Price: $3499
More info: www.fezzari.com
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
Wordpress Comments:
  • shawn says:
    You really put ‘limited color choices’ as a negative? You could put this for ALL bikes, short of custom build project bikes that allow for custom paint jobs. Why even bother to put this in the review?
  • bobsyouruncle says:
    I was primed to buy fezzari’s new signal peak (even nicer bike than this one), but alas, no 2x option. 1x sucks, it just does…
