Fezzari Signal Peak bridges XC-trail gap
Budget friendly 120mm do-it-all bike with 68-degree head angle
27.5 29er All Mountain Trail Cross Country News Plus
Signal Peak
Fezzari’s top-of-the-line Signal Peak Pro sells for $6199 with a SRAM Eagle XX1 drivetrain.
The lines of cross country and trail are more and more blurred. Indeed, modern XC race bikes are more fun than ever. Slack head tubes, longer travel, and better handling are all part of the new normal.
Take the new Fezzari Signal Peak, which artfully blends speed and fun. It’s fast on technical terrain, drops, and rock gardens, and climbs like a mountain goat.
Key Highlights
  • 120mm travel for the aggressive XC trail rider
  • 2000 gram frame weight (Size Medium)
  • 68° head angle and short 430mm chainstays
  • 75° seat angle-for more efficient pedaling
  • GA Link to optimize geometry for 29 or 27.5+ wheels
  • 27.5×2.8 or 29×2.2-2.6 tire clearance
  • Custom designed rattle-free cable routing
  • Two water bottle mounts inside the front triangle on all sizes
  • Custom-molded downtube and chainstay protector
  • English threaded bottom bracket for easy maintenance
Signal Concept
The primary design goal was to create a fun do-it-all bike that could also carry two water bottles.
“Just as the sport has evolved, so too have the bikes we design,” Fezzari explained. “The all-new Signal Peak was designed to take you to the top of the climb first, with a powerful pedaling platform, advanced tube shaping and carbon construction for maximum power transfer. But it can also charge through technical rock gardens, drops, and root sections with ease because of the progressive suspension design and trail capable geometry. The Signal Peak just begs to be ridden fast.”
Verify
Every detail was poured over to create a frame that will stand up to modern cross country abuse.
The Fezzari Racing Design Tetra-link suspension has been optimized for the Signal Peak to deliver a pedaling platform that’s efficient, while the 120mm of travel eats up the technical sections of the modern XC race or ride. The progressive nature of the Tetra-Link suspension gives the Signal Peak a plush ride for all-day adventures and marathon XC racing.
Signal Peak Launch 3D
A 3D printed prototype was used to make sure everything was up to tolerance before moving forward.
Signal Peak Pro – $6199
  • Fox 34 Step-Cast 120mm Factory
  • Fox Float DPS Factory
  • SRAM XX1 drivetrain
  • SRAM Level Ultimate Brakes
  • Fox Transfer Factory Dropper Post
  • RaceFace Next R Carbon Bar/Turbine R Stem
  • Reynolds TR249S
  • Maxxis Rekon 29×2.25 EXO/TR Tires
  • Available May 1st, 2018
Signal Peak Elite – $3999
  • Fox 34 Step-Cast 120mm Performance-Elite
  • Fox Float DPS
  • SRAM GX Eagle Drivetrain
  • SRAM Level TL brakes
  • Xfusion Manic Dropper Post
  • Raceface Turbine R Bar and Stem
  • Stan’s Arch Mk3 Wheelset
  • Maxxis Forekaster 29×2.3 EXO/TR tires
  • Available May 1, 2018
Fezzari Signal Peak Elite
Fezzari’s Signal Peak Comp retails for $2999. The bike will accommodate tires up to 27.5×2.8 or 29×2.6.
Signal Peak Comp – $2999
  • RockShox Reba RL 120mm/8
  • RockShox Monarch RT3
  • SRAM Eagle Drivetrain
  • SRAM Level T Brakes
  • Fezzari Carbon Seatpost
  • Fezzari 35mm bar and stem
  • WTB I25 Wheels
  • Available June 11th, 2018
Ride Testing
The Fezzari Signal Peak with 27.5+ wheels is ready to shred.
For more info head to www.fezzari.com.
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
