We knew it was just a matter of time until X01 spread its wings in the Downhill Racing arena. Already a favorite among many gravity oriented racers, SRAM made several improvements to make 1x stronger, quicker and more precise.
Read on see if this new drivetrain is for you.
SRAM 1X™ Technology
X-SYNC™
SRAM X-SYNC™ 1X chain rings provide the highest level of performance and durability. The SRAM X-SYNC™ tall square teeth edges engage the chain earlier than traditional triangle shaped teeth. The sharp and narrow tooth profile, as well as rounded chamfer edges, help manage a deflected chain. To provide the best possible performance in muddy conditions, the X-SYNC™ chain rings have been designed with mud-clearing recesses for the inner chain links and rollers. Engineered in Germany, X-SYNC™ rings are an integral part of the SRAM 1X™ drivetrain.
HARD CHROME™
The XX1 chain has four times the elongation (wear) resistance to our other chains. This is due to the new finishing process on the inner links and rollers. Push pin strength and ultimate strength are equivalent to our current chains. The XX1 chain lasts longer and is just as strong.
X-HORIZON™
This rear derailleur’s “straight parallelogram” design limits all movement to the horizontal axis, which makes ghost shifting impossible while also reducing shift force. For quicker, more exact shifting, the large upper pulley offset design maintains a constant chain gap across all gears.
Video: SRAM X01 DH Technology – interviews with engineers and designers.
CAGE LOCK™
With CAGE LOCK™ technology in the rear derailleur, wheel removal and installation—as well as chain installation—becomes faster and simpler. Just pushing the cage forward to create slack and lock it into place.
ROLLER BEARING CLUTCH™
ROLLER BEARING CLUTCH™ technology eliminates derailleur bounce and chain slap without sacrificing precision.
X-ACTUATION™
Developed specifically for SRAM 1X™, X-ACTUATION™ keeps shifting sharp and consistent across the entire 10- to 42-tooth cassette.
JET™
With durable JET™ black finish, the cassette looks as tough as it performs—ride after ride. JET™ finish provides a higher level of corrosion resistance.
MINI BLOCK™
Light, strong and precise, the MINI BLOCK™ X-DOME™ cassette lets you bring the right kind of power to every ride. This 7-speed cassette designed for downhill features an optimized gear range that eliminates the need for double/triple shifts to get in the gear you want.
XD™ DRIVER BODY
XD™ is a cassette driver body design that allows the use of a 10-tooth small cog and provides an improved interface with the cassette.
X-DOME™
X-DOME™ technology creates an incredibly lightweight, precise and strong cassette. The open design aids in mud clearance, giving you cleaner shifting performance and longer component life.
SRAM X01 DH 7-Speed
Every descent rewrites the laws of gravity. Every mountain pushes you further. Engineered in Germany, SRAM X01 DH delivers quicker shifting, smarter gear steps, and more precise chain management. Featuring SRAM’s 7-speed X-HORIZON™ rear derailleur and X-DOME™ MINI BLOCK™ cassette, the X-SYNC chain ring, and the X-ACTUATION™ trigger shifter, it’s the integrated SRAM 1X™ drivetrain for complete control. Made for gravity athletes. Proven by champions. And now available to every rider. X01 DH. GO BEYOND.
Video: How to install an X01 DH drivetrain.
SRAM X01 DH 7-Speed Overview:
- High performance shifting engineered for DH bikes
- Optimized gearing for DH
- Lightest crank, lightest cassette, lightest shifter, lightest group
- Better overall system durability
- All X0 DH cranks get upgraded to X01 DH cranks with X-SYNC™ rings
- Based on our SRAM 1X™ philosophy of a dedicated system, X-SYNC™, X-HORIZON™, X-ACTUATION™
- 10-tooth cog allows smaller chain rings for more ground clearance
SRAM X01 DH 7-Speed Setup:
- X01 DH X-SYNC™ Carbon Crank
- X01 DH 7-Speed MINI BLOCK™ Cassette
- X01 DH X-HORIZON™ 7-Speed RD
- X0 7-Speed Trigger Shifter
- XD™ DRIVER BODY
- PC-XX1 11-Speed Chain
New X01 DH X-SYNC™ Carbon Crank
The X01 DH crankset with X-SYNC™ technology is engineered for ultimate DH performance in the most aggressive terrain. The carbon crank combines stiffness and strength with lightest-in-class weight of under 800 grams. Proven in World Cup and World Championship racing, it’s the crankset made for relentless downhill rides.
Features/Benefits:
- Carbon DH racing crank
- Lightest in class carbon construction
- High strength alloy pedal lug
- 7075 CNC alloy single ring, 94 BCD, 30, 32, 34, 36, or 38 teeth
- Compatible with SRAM 1X™ 7- and 10-speed DH drivetrains
Technologies:
- X-SYNC™
- BB30™
- GXP™
X-SYNC™ Chain Rings
Engineered for downhill, the X-SYNC™ narrow-wide chain ring delivers complete control. Tall, square teeth, rounded chamfers and a thick-thin tooth geometry combine to engage the chain earlier—and never let it go. With multiple ring options available, you can match your gear range to your terrain, wheel size and riding style. And recesses at the base of the teeth get rid of mud so the chain remains in place no matter what conditions you’re up against.
Features/Benefits:
- X-SYNC™ tall, square tooth design provides maximum chain control
- Sharp, narrow tooth profile and rounded chamfer edges help manage a deflected chain
- 30-, 32-, 34-, 36-, or 38-tooth single ring
- X-SYNC™ technology for all 10- and 11-speed systems, as well as new 7-speed systems
- CNC machined 7075, two- tone anodize
- Mud-clearing recesses for the inner chain links and rollers
- An integral component of the SRAM 1X™ drivetrain
Technologies:
- X-SYNC™
SRAM X-SYNC™: A Developing Story
More than a decade ago, SRAM’s German engineers decided to go head-to-head with a fundamental frustration of biking—how to keep the chain on the ring. They began by looking at dual-drive solutions concocted for urban riders whose chains would disengage as they pedaled along bumpy European roads. These dual-drive models offered a simplified, focused approach that could make sense away from the city streets, too. The engineers were inspired. Ideas started to fly. Designs followed. Field tests. Frustrations. They learned lessons—for instance, that side-to-side movement (not up-and-down) was the most frequent cause of a disconnected chain.
The engineers now had a single goal in mind: to create the perfect MTB chain ring—a ring that wouldn’t drop the chain in any conditions or under any circumstances. This led to the unprecedented thick-thin tooth shape. To optimized square tooth geometry. To mud recesses that kept the chain clean and moving. All focused on the dynamic bike platform. As SRAM lead engineer Frank Schmidt puts it, “We further developed it until we reached perfect chain control.” The original narrow-wide chain ring is now the perfect MTB chain ring for riders who never compromise. X-SYNC™—ONLY BY SRAM.
NEW XG-795 X01 DH MINI BLOCK™ 7-speed Cassette
The MINI BLOCK™ X-DOME™ 7-speed cassette is engineered for the optimized gear steps that downhill riders want. Featuring 10–24 gearing with two-tooth steps, this technology eliminates the need for double/triple shifts to get in the gear you want. And because it’s so compact, it’s also light—the lightest cassette in existence. Compatible with any XD wheel, MINI BLOCK™ X-DOME™ technology integrates flawlessly with your SRAM 1X™ drivetrain. With durable JET™ black finish, the cassette looks as tough as it performs—ride after ride.
Features/Benefits:
- Larger jumps between gears eliminate the need for double/triple shifts to get in the gear you want. (10-12-14-16-18-21-24)
- Less cogs allow faster transition from starting gear to high gear. Half as many shifts to get from 24-10 versus a normal 10-speed 26-11
- Larger gear range, 10-tooth cog opens up high end and allows smaller rings for ground clearance
- Lightest cassette. Ever.
- More rear wheel clearance around spokes
- 2-tooth steps are safer in shifting than 1-tooth steps under big loads
- Currently fits any XD™ compatible wheel and driver body
Technologies:
- X-DOME™
- MINI BLOCK™
- JET™
- XD DRIVER BODY™
NEW X01 DH X-HORIZON™ Rear Derailleur
The 7-speed X-HORIZON™ rear derailleur makes shifting smooth and reliable no matter where you ride. Engineered to maintain consistent chain gap across all seven gears, X-HORIZON™ eliminates vertical movement for faster shifting, reduced shift force and an end to ghost shifting. ROLLER BEARING CLUTCH™ technology and the 12-tooth X-SYNC™ pulley wheels hold the chain in place, reducing bounce and chain slap. And CAGE LOCK™ technology makes wheel removal and installation easier than ever. Paired with the X01 DH 7-speed shifter, X-HORIZON™ forms the backbone of X-ACTUATION™ technology—and that means completely smooth shifting action.
Features/Benefits:
- X-HORIZON™ technology provides more responsive shifting and eliminates ghost shifting, a common problem on DH bikes
- X-ACTUATION™ with more cable pull delivers optimized system performance and durability
- Two cage lengths for various applications, including abnormally long chain stay growth
- EXACT ACTUATION™ (MTB 10-speed) variant allows upgrades to existing bikes in the aftermarket
- ROLLER BEARING CLUTCH™ with CAGE LOCK™ sets the industry standard
Technology:
- X-HORIZON™
- X-ACTUATION™ (7-SPEED)
- EXACT ACTUATION™ (10-SPEED)
- X-SYNC™
- CAGE LOCK™
NEW X01 7-Speed Trigger Shifter
Harnessing SRAM’s 1X™ X-ACTUATION™ technology, the X01 DH trigger shifter delivers precise and dependable 7-speed performance. With ZERO LOSS™, the cable engages instantly so you shift faster. And with multi-adjustable triggers, you shift from whatever position fits perfectly with the way your ride. The shifter’s aluminum cover and adjustable forged aluminum pull lever bring the strength and durability you need to conquer the toughest terrain.
Features/Benefits:
- SRAM 1X™ X-ACTUATION™ for precise and dependable 7-speed performance
- Multi-adjustable trigger shifter
- MatchMaker™ X compatible
- ZERO LOSS™ Engagement for fastest shifting
- Aluminum cover and adjustable forged aluminum pull lever
- Includes discrete clamp
Technologies:
- X-ACTUATION™
- ZERO LOSS™
- MatchMaker™ X Integrated
PC-XX1 Chain
Go further with the XX1 chain that’s engineered to endure the toughest rides. Built with SRAM’s HARD CHROME™ technology, the XX1 chain includes a wear-resistant finishing process on the inner links and rollers that brings maximum strength and wear resistance so that you can conquer any terrain.
Features/Benefits:
- 1X™ specific chain
- HARD CHROME™ finish provides maximum strength and wear resistance for improved chain life
- 11-speed power lock
Technologies:
- X-SYNC™
- HARD CHROME™
XD™ Driver Body
The XD™ driver body lets you take full advantage of the power and range of your SRAM cassette. The improved interface offers a tighter cassette-to-driver-body fit. With the XD™ driver body, SRAM has established a single universal mounting system for cogs with less than 11 teeth.
Features/Benefits:
- Driver body design that lets riders tap into the power and range of the SRAM cassette with a 10-tooth small cog
- Provides a more stable hub connection
- XD™ driver body is 6-8g lighter
SRAM X01 DH 10-Speed
SRAM X01 DH 10-Speed Setup:
- Based on our 1X™ philosophy of a dedicated system, X-SYNC™, X-HORIZON™, X-ACTUATION™
- 10-tooth cog allows smaller rings for more ground clearance
Components:
- SRAM xg-1070 10-Speed Cassette
- X01 DH X-HORIZON™ 10-Speed RD
- X0 10-Speed Trigger Shifter
- X0 10-Speed Grip Shift
- SRAM pc-1091 10-Speed Chain
X0 10-speed Trigger Shifter
Pair the X0 trigger with the MatchMaker™ X clamp to streamline your handlebar setup. The X0 trigger maintains the legacy of X0 shifting with features and technologies optimized for SRAM EXACT ACTUATION™.
Features/Benefits:
- New smaller design with adjustable pull lever
- SRAM’s EXACT ACTUATION™ for precise and dependable 10-speed performance
- The first patented multi- adjustable trigger shifter which allows for precise rider fit
- Colors: Silver, Black and Red
- Weight: 232g (per pair)
Technologies:
- EXACT ACTUATION™
- ZERO LOSS™
Grip Shift by SRAM. 10-speed. Three rows of ball bearings for smooth shifting action. Full-metal shift indexing. Integrated lock-on grip design. Unrivaled.
Features/Benefits:
- EXACT ACTUATION™ for precise and dependable 10-speed performance
- SPEED METAL™ shift indexing
- ROLLING THUNDER™ ball bearings
- JAWS™ lock-on grip technology
- Includes lock-on grips
- Colors: Silver and Red
- Weight: 287g (clamps, cables, and JAWS™ lock-on grips)
Technologies:
- JAWS™
- ROLLING THUNDER™
- SPEED METAL™
- EXACT ACTUATION™
SRAM PG-1070 10-Speed Cassette
The PG-1070 cassette’s semi-spidered design maintains a high level of shifting performance. Our cog set features a semi-spidered construction for a maximum stiffness to weight ratio and is available in twelve optimized configurations to best match a wide variety of uses. To help you in the toughest climbs it is now available in the 12-36 ratio.
Features/Benefits:
- Semi-spidered design maintains a high level of shifting performance
- Twelve optimized configurations to best match a wide variety of uses
- Weight – 359g (12-36)
- Gear Ratios – 11-23, 11-25, 11-26
- Speeds – 10
- Recommended chain – PC-1090R, PC-1090, PC-1070, PC-1050, PC-1030
Technologies:
- PowerGlide II™
SRAM PC-1091 10-Speed Chain
The PC-1091 chain offers more heavily chamfered outer plates for improved shifting and quieter running. Other advancements include an inner plate finish plus chrome hardened pin construction, both for longer chain life.
Features/Benefits:
- Heavily chamfered outer plates for improved shifting and quieter running
- Inner plate finish plus chrome hardened pin construction
X01 DH 7-Speed Specifications
X01 DH Carbon Crankset
- Variants: BB30 and GXP: 30, 32, 34, 36, 38
- Weights: 740g with BB
- Technologies: BB30, GXP and X-SYNC™
- Speeds: SRAM 1X™
- Compatibility: 11-, 7- and 10-speed X-SYNC™
- Materials: Carbon composite/ aluminum spider; AL-7075-T651 rings
- Hardware: AL-7075-T6; TORX® T25 and 6mm hex bolts
- Features: Carbon guard available
- Options: 165, 170 and 175mm arm lengths; Red and Black
- MSRP: GXP: $315, € 280 / BB30: $347, € 310
- Variants: Horizontal Parallelogram design
- Weights: Med cage RD – 263g / Short cage RD – 257g
- Technologies: X-ACTUATION™, X-HORIZON™, X-SYNC™, ROLLER BEARING CLUTCH™, and CAGE LOCK™
- Speeds: 1X7
- Compatibility: X-ACTUATION™
- Materials: Aluminum outer cage
- Hardware: Stainless steel
- Features: Cartridge bearings
- Options: Red and Black
- MSRP: $277, € 245
X01 DH Trigger Shifter
- Variants: 7-speed
- Weights: 91g
- Technologies: X-ACTUATION™, ZERO LOSS™ and Matchmaker™ X Integrated
- Speeds: 7-speed
- Materials: Aluminum cover, adjustable forged aluminum pull lever
- Hardware: Aluminum, stainless
- Features: MMX Compatible
- Options: MatchMaker™ X; Red and Black
- MSRP: $143 , € 125
- Variants: 10-24
- Weights: 136g
- Technologies: X-DOME™ and XD™ driver body
- Speeds: 7-speed
- Compatibility: PC-XX1 chain and XD™ driver body
- Materials: Machined steel with JET™ finish, alloy spoke protector
- Features: XD™ driver body
- MSRP: $303, € 269
PC-XX1 Chain
- Variants: 11-speed
- Weights: 252g
- Technologies: X-SYNC™ and HARD CHROME™
- Speeds: 11-speed
- Compatibility: X-SYNC™ and 1X11 X-ACTUATION™
- Features: 11-speed power lock
- MSRP: $63, € 57
X01 DH 10-Speed Specifications
- Speeds: SRAM 1X™
- Weights: 263g (mid cage)
- Technologies: EXACT ACTUATION™, X-HORIZON™, X-SYNC™, ROLLER BEARING CLUTCH™, and CAGE LOCK™
- Speeds: 1X10
- Compatibility: EXACT-ACTUATION™
- MSRP: $277
For more information visit http://www.sram.com/.
Finally, parts not for ENDURO!! But just wait cuase Enduro weight weenies will be wanting in on it too!
And so it begins…back to 7 gears sold to us at insane prices.
Don’t get me wrong, I would kill for this with a more all-round spread, but not for this costs.
