Jeff Stoudt shows us the Formula RX, R1, R1 Racing, T1, RO and Limited release T1 25th anniversary edition brake with physical vapor deposition coating. All Formula disc brake calipers now include ECT Enhanced caliper technology.
Robert Davis discusses Formula’s fork product lineup with the ThirtyThree and the new for 2013 650b and 29″ forks. The ThirtyThree XC fork features 80-120mm travel, 33mm stanchion tubes, closed cartridge unit, dual coil, polymer bushings and lubricating oil, air spring, high volume and low pressure. It is available in tapered, QR9 or QR15 steerer. New for 2013 is the the 650b and 29″ forks. The 650b has 35mm stanchions, magnesium lowers, hard anodized aluminum uppers and is available in thru axle 15 and tapered only. The 29″ features 100-140mm travel, 35mm stanchions and tapered steerer.
Robert Davis also shows us the Volo All-Mountain Light wheel with scandium rim, 2mm internal and formula hub with 6 degrees of engagement, that’s great for the Enduro, All-Mountain rider.
×Formula T1 25th Year Anniversary Disc Brake
1987…the year of floppy discs, the Supernova, the introduction of the Ferrari F40 and good times! It was also the time when Andrea Becocci and Daniela Frati made the decision to kick start their company – Formula Italy. Formula is proud to feature the 25th Anniversary t1, Limited Edition. Known for its extraordinary performance, the T1 brake has now experienced a “makeover” in honor of this momentous milestone. The T1 25th edition combining in its special version a unique and special chromating finishing that makes the surface of the brake extremely shiny amd a 25th anniversary special laser etched logo on both caliper & mastercylinder. With a limited number of 600 sets produced you will want to place your orders today! Brake will be available starting from December 2012- PVD coating
- Environmental friendly
- 600 sets world wide available
×Formula T1
Weighing in at 335 grams, the incredible braking power and precise modulation of T1 has earned an excellent reputation worldwide and has resulted in numerous test wins. T1 sets the benchmark for AM/EN riding. New for 2013: Enhanced Caliper Technology (ECT) for higher rollback and easy installation.- Lever Blade: Carbon – 6g less than aluminium
- 1-piece rotor 6 bolt IS or Center Lock: 160mm / 180mm / 203mm
- 2-piece rotor 6 bolt IS: Red or black – 140mm / 160mm / 180mm / 203mm
- 2-piece rotor center lock: Red or black – 160mm / 180mm
- Hardware: Titanium caliper and rotor bolts – 10g less than steel
- Adapters: IS and PM: 140mm / 160mm / 180mm / 203mm
- MixMaster : Custom shifter mounting perch
- SpeedLock: Hose quick connect – mount to caliper, master cylinder, or inline – red, black and gold
- PM including 850mm hose, 160 mm rotor, complete hardware: 336 g
×Formula RO
The RO’s oval caliper technology combines top brake performance with outstanding modulation. Its incredible brake power has been confirmed by several wins during the 2012 World Cup series. With just 360 grams the RO sets the benchmark for brake power and performance at a XC brakes weight. New for 2013: Enhanced Caliper Technology (ECT) for higher rollback and easy installation.- Lever Blade: Carbon – 6g less than aluminium
- MixMaster: Custom shifter mounting perch
- PM including 850mm hose, 160 mm rotor, complete hardware: 361g
×Formula R1
Great performance and a feathery weight make the R1 the premier XC race brake on today’s market. Still, the R1 generates more than enough power and performance for an All Mountain or Enduro use. The forged master cylinder body and caliper provide increased modulation, braking power and durability, while the R1’s patented caliper piston system increases fluid capacity in the caliper providing stability and fade resistance even on the longest descents. New for 2013: Enhanced Caliper Technology (ECT) for higher rollback and easy installation.- Lever Blade: Carbon – 6g less than aluminium
- FCS Feeling Control System: Available in red, black and gold
- PM including 850mm hose, 160 mm rotor, complete hardware: 270g
×Formula R1 Racing
Formula’s Race version of the R1 features a carbon lever blade, titanium hardware and Kevlar hoses. This drops the weight to just 264 grams and makes it the best choice for every XC-race oriented rider. New for 2013: Enhanced Caliper Technology (ECT) for higher rollback and easy installation.- 1-piece rotor 6 bolt IS or Center Lock: 160mm / 180mm / 203mm
- FCS: Feeling Control System. Available in red, black and gold
×Formula RX
Featuring the same technology as all Formula brakes the RX comes with a very value driven price tag. As the perfect brake for any XC or All Mountain / Enduro application, the RX features a radial master cylinder that combines with a one-piece caliper equipped with 22 mm diameter pistons. This translates into lots of power and modulation while leading its category at a low 337 grams. New for 2013: Enhanced Caliper Technology (ECT) for higher rollback and easy installation.- 1-piece rotor 6 bolt IS or Center Lock: 160mm / 180mm / 203mm
- TFRA: Tool Free Reach Adjust – Forged aluminium lever blade w/ integrated red dial
- PM including 850mm hose, 160 mm rotor, complete hardware: 341g
×Formula 35 650B Fork
×Formula 35 29" Fork
The 29" features 100-140mm travel, 35mm stanchions and tapered steerer.
×Formula 33 Fork
Formula's ThirtyThree line of suspension forks was developed with World Championship experience on the roughest and fastest XC courses on the globe. The ThirtyThree forks feature custom developed low-friction polymeric bushings to ensure buttery smooth function and minimize the impact of excessive seal friction found in many air sprung forks. Compression and rebound damping adjustments allow for precise setup and a unique lockout with integrated blow-off threshold adjustment allows you to choose just how rigid or soft you want your fork to be. Features:- 33mm hard anodized 7000 aluminum stanchions
- Magnesium lowers w/ PM6 brake mount
- Formula control closed cartridge damping 7 adjustments + 2 lockout settings
- Formula rebound - 18 adjustments
- Air spring w/ Dual Coil Technology
- HPV (high-pressure valve): blow off valve prevents damage when fork is locked out
- Polymeric bushings offer low weight and less friction
- Lock out: crown mounted or remote
- Travel: 26" 85-120mm
- Colors: Black or White
- Weight: Straight 1 1/8 1443g / Tapered 1 1/8 1.5" 1477g
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula 33 Fork
×Formula Volo Wheel
With the Volo All-Mountain Light, Formula completes its product range of light weight competition wheel sets. The front wheel is equipped with a 3D forged oversized hub and "Formula Triple Axle Technology" that easily adjusts to all different standards - OR9, 15TA and 20TA. The rear wheels features X12 axle and external bearing technology for exceptional strength. With just 1657 grams these wheels easily clim and tackle any obstacle on the way down. Features:- 24 straight pull double butted spokes laced 2 cross with brass nipples
- 21mm Scandium rim
- 3D forged oversized hub with Formula Triple Axle Technology and hard anodized 4-pawl freehub body
- External Bearing Technology: Rear hub's load carrying cartridge bearing located outboard of freehub
- Front axle options: QR9/12x142mm
- QR9 Skewers: Titanium front 32g / rear 34g
- Recommended tire size: 1.5"-2.5"
×Formula Volo Wheel
- 21mm Scandium rim
×Formula Volo Wheel
- 21mm Scandium rim
Thats one high tech, lovely-lookin’ fork.
That quick disconnect is the coolest thing I have ever seen! Is Formula the only one that does that? That would make it so much easier to ship my bike when I travel. Great idea. Does it come in gold???
When will the new ECT equipped 2013 brakes be available?
