Fox 34 Float 29 Front Fork & Float RP23 Rear Shock Review
Components Forks Video
Fox 34 Float 29erĀ Impressions
Suspensionwerx of North Vancouver helped me set up the fork. Initial settings for sag of 25% were 60 PSI, LSC 4 clicks in. I’d have to conclude that Fox’s recommended settings were a tad high (my recommended setting is 75psi) but its pretty easy to check for yourself. Here’s some observations on performance:
  • The F34 feels decently smooth out of the box. As does most suspension, it does need some break-in so check your air pressure against your sag after say six or so rides. I couldn’t say whether the fork was smoother after it broke in – all I can say is that I added a bit more air (5psi) to get the fork to stay at 25% sag so it must have overcome some initial pre-breakin stiction.
  • I took the fork apart when it arrived and it came with the correct amount of oil in the lowers so QC from my single sample size passes. After approximately 50 rides I took the lowers off again, checked oil and noted no discolouration characteristic of contamination. I’d have to conclude that the SKF seals are doing their job of keeping out mud and muck
  • Further to that note, the Kashima coating is undamaged and still looks beeeyooutiful. I’ll note that my older Kashima coated Fox forks with 100+ rides also look pristine so longevity of the coating also gets a pass.
  • The FIT cartridge damping on the F34 chassis is much improved over the lamentably underdamped 2011 Fox FIT which blew through travel mid-stroke (my experiences were with the 2011 F32 Talas 150 and F36 Talas 160). With the 2012 FIT, it’s possible to set up the F34 Float so that travel is as it should be; supple at the start of the stroke and progressively more supportive towards the middle and end of the stroke.
  • Having said that, low-speed compression settings don’t seem to do too much. My preference is to run as wide open as possible with just a touch of low speed compression. To achieve this I have to wind in halfway through the LSC dials. I’ll contrast this (unfavourably) with almost all other brands where the compression settings generally make meaningful differences.
The last comment is to fork stiffness and is a point which has been interminably debated on MTBR .On this topic, TO ME (emphasis deliberate) the F34 is not noticeably -significantly- stiffer than the F32. By this I mean that the F32 I have on the Tallboy feels nicely stiff but so does the F34 that I have on the Bandit 29. Neither fork feels remarkably stiff in the same way that say a Fox 36 160 with 20mm thru-axle feels.
Note that I am 160lbs. Heavier riders have different opinions. I have no doubt that other riders who are the same weight as myself may feel that the F34 is stiffer than the F32. This comment then segues into another point which will be more than a little bit of rambling. WHY OH WHY FOX DID YOU NOT PUT A 20MM THROUGH-AXLE ON THIS FORK?
Deep breath and let me explain further. The F34 is the long-awaited long travel 29er fork from one of the major bicycle fork companies on the planet built for a category of bikes (long-travel 29ers) that is still small. These bikes should be ridden hard. They should not be poncy little weight-weenie gram-shaving bikes and if they are the owners perhaps should explain themselves. Where I am coming from is that it would have been nice (and IMO logical) of Fox to spec the F34 with a 20mm Maxle front end to take the stiffness of the fork to its logical conclusion. Not the 15mm thru-axle which allows for radial slop between axle and sliders (the axle just applies a strong clamping force so there’s always some play). Maxle not only applies axle clamping force but also expands radially between the sliders so movement is minimal. While I’m on my Gedankenexperiment rant why didn’t Fox also spec 36mm lowers on this fork. Just how much weight would have it added anyway? Why not go with Maxle and 36 and shoot for the moon with this long-travel 29er fork. Why go halfway?
At this point I am probably inviting (and probably deserve) rebuttals that this fork is plenty stiff and that I am just indulging in useless speculation and that if I didn’t notice the stiffness difference between a F34 with 15mm thru-axle and equivalent F32 then how on earth would I notice the difference with my hypothetical uber-fork (read this fascinating piece on Weber’s Law of Just Noticeable Differences for more on whether bike components are all in the head) I leave you with the thought that I really really like the Fox F34 Float 29 FIT RLC; am.a Fox fanboy and own a ton of Fox suspension on my bikes. The fork performs well, it can be tuned, and its spring rate is nicely progressive but I can’t help wanting for more. I wanted to be blown away, like I was the first time I rode a bike with a Fox fork with 36mm stanchions and the 20mm axle and beefy crown. The F34 29er is like vanilla ice-cream without dark chocolate sprinkles and topping – oh so close but just those few vital bits missing.
Fox Float RP23 Impressions
I set the RP23 at body weight for the Bandit 29er and either ran the Propedal wide open or engaged if I was climbing (note that rear shock settings may be different for different bikes). There’s really not that much to say about the RP23 except that it quite boringly and seamlessly works. It works well uphill. It works well downhill. It works well on the flats. As with the front suspension I notice compression adjustments with the Propedal switch only when making big changes (eg flipping the lever from climb mode to wide open mode) but perhaps that is just me.
I have one minor nitpick but this relates more to the fact that I am able to bottom out the rear shock on the Bandit 29er when I drop to flat from anywhere more than 3 feet (approx 1 meter). One might reasonably note that drops to flat are passe and that I should quit doing that. One might more reasonably note that the Bandit 29er’s suspension is of the type that requires a bit more support at the end of the stroke (perhaps a custom tune or Boost Valve pressure?). To do so one must avail themselves of the services of a suspension tuner; the Float RP23′s settings are relatively fixed to ranges of tune. I have Suspensionwerx in my neighbourhood but not everyone is so fortunate and may have to mail in their suspension to PUSH or to FOX itself. It would be nice if the RP23 was user-tuneable to a greater degree..
Finally, because this is comically quasi-scientific data but ultimately useless I’ll throw up some random data points. Suspensionwerx’s sample size is approx 350+ people over a year who came in with RP23s to service and tune. They checked through logs to whittle this down to riders who were switching from non-Kashima to Kashima-coated RP23s. Being pretty busy at this time of the year I didn’t press them for exact numbers of this sample size but I am told it was probably around a hundred.
Of this hundred approximately 70% of riders added pressure to Kashima-coated rear shocks to achieve desired sag as compared their non-Kashima shocks. Riders added 5 to 10 PSI (ranges varied). Assuming that the RP23s were set up for body weight and assuming a 180lb rider this is between 2.7 to 5.4% more air pressure. Now this is hardly experimentation of the German Bike magazine standard. Error sources include, without limitation:
  • the fact that many of these riders were coming in to get suspension tuneups so their older suspension might not have been set up correctly
  • the fact that the riders were also coming in to get old suspension worked on so the old suspension might have been performing sub-par
  • the fact that some riders were changing bikes of different designs and thus the rear shock pressures could have varied due to the different design
Unfortunately my data point therefore has a ton of caveats and is unfortunately basically useless. It also ignores the question of whether or not riders would have even noticed if they had not added more pressure to their new Kashima shocks (as compared to their non-Kashima shocks); accordingly had more sag and then noticed whether or not they had more sag! Another data point is that I played around a bit with an empty RP23 upper shell and moved a Kashima coated lower shaft and non-Kashima coated lower shaft up and down the upper shell; the Kashima coated shaft felt smoother. This also ignores whether or not I would notice the difference in smoothness when riding (see treatise on the psychophysics of Just Noticeable Differences above)
In conclusion, there’s really not much to say or find fault about the RP23. It does the job without fuss. It’s a part that rarely fails and works without getting in the way. All bike parts should be this good.
Fox 34 Float 29 & Float RP23 Gallery
About the author: Lee Lau
Lee Lau calls North Vancouver and Whistler BC home. He's had over 15 years experience riding bikes mainly in western North America and in Europe. Unlike many people who learned to ride bikes on North Shore trails, he actually enjoys riding (and sometimes bushwhacking) uphill.
Wordpress Comments:
  • Greg says:
    “Why not go with Maxle and 36 and shoot for the moon with this long-travel 29er fork. Why go halfway?” I’m guessing so they can do one or both next year, create new excitement (envy?) and keep selling new forks. I too am running this fork on my Bandit 29. Love it (and the bike), but I definitely questioned the decision to use a 15 mm axle too. Lee, Thanks for taking the time to post this review!
  • G says:
    Let’s say you were shopping for a fork for your tallboy…would you put the 34mm 140mm on that guy or a 120mm?
    • leel says:
      G- I would stick that 34 on there and step it down to 110mm just so the Tallboy would get too tall. Reason is that I’d want the stiffest fork possible on there to match the stiffness of the Tallboy rear-end. And also, what if I had the itch to get a Tallboy LT? Or some other longer travel 29er?
  • duder says:
    Meh, its Fox. They feel entitled to do what they want, cuz people are fanboys, even if its not the best decision. 15mm should never be used over a 20mm, it offers no benefit.
    Havent ridden an RP23 yet that compares to the current RS/XF options. Maybe in 2013…
  • leel says:
    duder – I’ve ridden an XFusion RCX and the Monarch. They are more tuneable but IMO not that much different than the RP23. In what way are those shocks better?
    Couldn’t agree more wrt to 15mm but the weight weenies and more importantly Shimano dictates Fox’s decisions even though no-one will say that
  • duder says:
    found that the changes in rebound and compression settings made a much more noticeable difference vs the rp23 from one end to the other…mid stroke wallow has plagued the RP23′s I’ve owned/demoed and haven’t had that issue with the Monarch & O2
  • Ruder says:
    @leel
    Thanx for the honest review. :-)
    I TOTALLY agree with you that Fox should have went with 20mm on the axle. I weigh around 210 pds and I DEFINITELY can tell the difference between the Float 29″ 32mm and the Float 29″ 34mm forks. I own a Tallboy w/a 120 mm travel / 32mm stantion fork and I’m going to do just what you suggested and get the 34 and lower the travel to 110/120 mm.
  • Craw says:
    This fork is a step in the right direction. If 29ers are great for taller riders why not build a fork that might actually survive under an aggressive taller/heavier rider? 29er proponents keep talking about how good 29ers are at so many things but the forks thus far are really only good for lighter XC whips.
  • Pasang Sherpa says:
    awesome. get more stye-lest and attractive.
