Fox Shox Interbike 2013
Interbike Sponsored post
Mark Jordan with Fox shows us the new offerings for 2014 that include the 34 Talas 160 fork, the Float X CTD shock, the 40 Float RC2 dowhill fork, the DHX RC4 shock, as well as a couple of prototype shocks in the works.
The 34 Talas 160 fork features a new Talas system which is the same as the Float Air system with the Talas travel adjuster on top. It allows you to adjust the travel on the fly and adjust total travel internally. It also has the CTD travel adjust damper that features 3 on the fly low speed compression settings and 2 micro adjustments for the middle setting, 15 QR and is a great lightweight, all around Enduro fork.
The Float X CTD is a new Enduro, All Mountain specific shock that has the CTD adjuster with 3 on the fly low speed compression settings and 2 micro adjustments for the trail setting, 2 damping circuits, Kashima coating and an extra reservoir for dual damping circuits.
The 2014 40 Float RC2 is their first air downhill fork that features air spring with Ti negative spring, a compression adjuster to move the piston up and down, RC2 damper with adjustable high and low speed compression on the top and adjustable rebound on the bottom. For 2014 it has a complete new chassis with a redesigned crown for weight reduction, while keeping the same strength as the previous model.
The RC4 damper is a little more sensitive and reactive with a smaller shaft diameter. It also features adjustable high and low speed compression, air assist and coil spring to adjust the bike to your weight and get the proper sag.
Finally, Mark gives us a sneak peak of 2 prototype shocks, the Fox Float Air DH Prototype Shock that Mick Hannah won 2nd place at the Championships on and the Fox Prototype Coil Shock that Greg Minnaar won the World Championships on.
For more information visit www.ridefox.com.
Fox Shox Interbike 2013 Gallery
of
Fox 34 Talas 160 Fork
  • New for 2014
  • Updated damping tunes for even greater control
  • Improved air spring curve
  • Low friction
  • Crisp actuation with precise internal travel range
  • 15QR thru axle system, post style disc brake mounting
  • 4.33 lb / 1.97 kg Weight
  • 1.5" taper aluminum Steerer
  • Trail, All-mountain Riding Style
  • Air Spring
  • Climb/Trail/Descend (3 positions), Trail adjust tuning range (1, 2, 3), Rebound, Air spring pressure, Talas 2 position travel Adjustments
Fox 40 Float Fork
Fox 40 Float Fork
  • New for 2014
  • New air spring - 152g weight savings vs. Ti spring
  • New chassis (crowns, upper tubes, lower legs) - 307g lighter
  • New RC2 damper - lighter weight and revalved
  • Total Weight Savings - 1.16lb / 526g
  • Crowns reshaped for increased downtube clearance
  • Details: air bleed system, mudflap mounting bosses, replaceable pinch bolt hardware
Fox DHX RC4 Shock
Fox DHX RC4 Shock
  • New for 2014
  • Improved damping control, delivering more usable travel
  • Reduced ending rate compression damping performs better with modern linkage designs
  • Lower internal pressures for better small bump sensitivity and lower friction overall
  • Better damping control at high temperatures
  • New Air Assist
  • New Air Assist Volume
  • Coil Spring
  • 0.99 lbs / 447 g Weight
  • All-mountain, Freeride, Downhill Riding Style
  • Rebound, Low-speed compression, High-speed compression, Spring preload, Bottom out progressivness and Bottom out force adjust Adjustments
Fox Float X CTD Shock
  • New for 2014
  • New piggyback air shock for aggressive All-mountain riding
  • Wide CTD compression damping range and remote capability
  • Shares damping features and improvements made to DHX coil shocks
  • Easy maintenance air sleeve
  • 70g lighter than DHX Air - 8.5 x 2.5" = 365g
  • New and improved remote
  • Rebound, Climb/Trail/Descend (3 positions), Air spring pressure Adjustments
  • Spring Air
  • 0.8 lbs / 365 g Weight
  • All-mountain Riding Style
Mick Hannah was 2nd place at the Championships on this prototype shock.
Greg Minnaar won the World Championships on this prototype shock.
Ford Raptor Comes Equipped With Fox Suspension
Rallying The Fox-Equipped Ford Raptor At Outdoor Demo
Fox-Equipped Ford Raptor At The Interbike Outdoor Demo
Fox Suspension Booth At Interbike 2013
Wordpress Comments:
