GoPro Helmet HERO Wide Video Camera Review
Pro Reviews
I needed a few experimental video sessions to get the camera angle set properly. You want a tad of the front wheel in the shot with an occasional glimpse of the handlebars, and not to much of the distant trail. To adjust the camera angle, a firm push will usually rotate the housing, else you can loosen the swivel bolt, and adjust as needed. It might be nice to have some markings or indentations on the swivels so that you could replicate the same settings if you ever change or adjust an angle. If you attach the unit elsewhere you will need to adjust the camera angle to gather the shots that you might want. When using the additional mounts that have more swivels I found it difficult to get enough torque on the tightening bolts to keep the unit from moving around while riding.
Optional seatpost mount
You can turn the camera upside down, and then using the settings on the camera, record that footage downside up. I of course made a test once doing just that, and forgot to set it back to the normal mode so all my video was upside down!
Frame mount
Optional handlebar mount
Continued on next page
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Reginhild says:
    I was waiting for one of the mountable light video cameras to accept a 4GB SD card. Even the higher end ones right now are limited to 2GB.
    The next step would be 8GB capability but it would require going to two AA vs. AAA to last longer than 2hrs… or the video resolution/frame rate could be pumped up.
  • Reginhild says:
    I was waiting for a light mountable camera to move up to 4GB SD cards. Even the high end ones seem to still be stuck at only accepting 2GB cards.
    Next step is 8GB and higher frame rate or resolution to still fit in the 2hr battery limitation…or they could redesign for AA batteries.
  • Adrian says:
    Hi. Could you tell me where you got that update for the camera. So that I can have a 4gb memory card. Thanks.
  • pastajet says:
    GoPro should be releasing a 4GB firmware upgrade shortly for the HERO camera, I do not have a time frame for the release. It will also be nice when they have the 8GB firmware.
  • oneye says:
    Good to excellent quality video ( for the price ) . Doesn’t take a genius to figure it out. Make sure to use lithium batteries in cold temps. Oh yeah, the sticky mounts are good to 140 mph, I can vouch for that!
  • Amrish says:
    Can it be directly hooked up to a PC to be used as a web cam.
    Need to transmit images in real time.
  • pastajet says:
    It appears as a removable device/disk when hooked up to PC, so it won’t work as a web cam as far as I know. I can try it sometime at home, but I doubt it would work in that manner.
  • George Henry Poppycock says:
    Nice videos Brian! I have a Hero 5 as well, I had some faulty quick release buckles that snapped when removing from mounts, I contacted GOPro and they informed me that I had received a kit that had been made with brittle resin – and sent me new clips and parts the next day… I believe the reason for the sun being blacked out is that it is programed to do so, to prevent over exposure of the video. If the sensor metering off of the sun and changes the aperture and or exposure to the correct exposure for the sun every thing else is extremely dark… I think it looks kinda cool too. I want to get the handlebar/seat post mount. When my buckles were broken I used the head strap mount as a shoulder/chest/crotch cam.
  • mufn8r says:
    Arrrgh! When is the firmware going to be released?! Also, will the firmware improve the video quality of the older versions? I mean when I connect my GoPro to my motorcycle, no matter how secure the camera is the video misses frames and looks “liquified”.
  • Edo says:
    I’m thinking about buying this camera. Where can I find some sample video files to download to my PC to check them and to play around with my video editing software?
  • LeeL says:
    Edo – myself and several others have posted some GoPro footage to the MTBR Video forums. You need a vimeo login but once you have one you can download the footage to play with editing
  • John says:
    What are the recording times using using the recommended rechargable batteries?
  • 8664 says:
    hi since they have the wide i am a big fan and with the chest mount it is the best solution without shutter!!! best cam for money!
