GoPro HERO3 POV Camera
Cameras
Built-in Wi-Fi (Wi-Fi Remote Included)
The HERO3 Black Edition features built-in Wi-Fi and includes GoPro’s Wi-Fi Remote accessory. The Wi-Fi Remote is normally available as a $79.99 accessory but is included with the HERO3: Black Edition. The Wi-Fi Remote is waterproof, wearable and can control up to 50 Wi-Fi-enabled GoPros at a time from a range of 600′. The HERO3′s built in Wi-Fi means it can also be controlled by iOS or Android smartphones and tablets running the GoPro App. The GoPro App enables full camera control and live scene preview on any compatible iOS or Android smartphone or tablet.
The HERO3: Black Edition is compatible with all GoPro mounting accessories and older generation BacPacs™ along with the newer generation LCD Touch BacPac and 2nd generation Battery BacPac. However, as all HERO3 cameras have a new size and shape they require HERO3-specific Wrist, Skeleton and 3D housings so be sure to check for HERO3 compatibility when purchasing any new housing
What’s Included
  • HERO3: Black Edition Camera
  • 197’/ 60m Waterproof Housing*
  • Wi-Fi Remote + Key Ring
  • Remote Charging Cable
  • Rechargeable Li-ion Battery
  • QR Buckle
  • J-Hook Buckle
  • 3-Way Pivot
  • 1 Curved Adhesive Mount
  • 1 Flat Adhesive Mount
  • Assorted Mounts and Hardware
  • USB Charging Cable
<======= HERO3 – New Accessories =======>
The Frame
The Frame mount is the smallest, lightest way to mount your HERO3 camera. For use with the HERO 3 cameras only. Retails for $39.99.
  • Sleek frame design for low profile, compact mounting
  • Lens cap protects camera lens
  • Engineered for optimal sound at speed
  • Compatible with LCD Touch BacPac™ and second generation Battery BacPac™
Note: The Frame mount is NOT waterproof and not optimized for use in extreme conditions where dirt and sharp objects can damage the camera lens.
What’s Included:
  • Standard Frame
  • BacPac Frame
  • Lens Cover
  • Assorted Mounting Hardware
LCD Touch BacPac
The LCD Touch BacPac is a removable LCD touch screen for GoPro cameras*. As a removable accessory, the LCD BacPac keeps your camera as small and light as possible, yet provides the convenience of an LCD screen when attached. Retails for $79.99.
  • Seamlessly attaches to the back of GoPro cameras
  • LCD touch screen allows for easy visual control of camera (frame your perfect shot) and settings
  • Preview + playback photos and videos including instant slow motion playback
  • Integrated speaker with volume control
  • 3.5 mm headphone jack
*Limited compatibility with original HD HERO and HD HERO2 cameras, requires firmware update.
What’s Included:
  • LCD Touch BacPac™
  • Touch backdoor
  • Standard backdoor
  • Skeleton backdoor
  • Protective Case
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
