With a growing trend toward longer travel e-mountain bikes, Haibike has delivered with its new 200mm DWNHLL model. They've also improved the performance and extended the range of the XDURO and SDURO. Press play to get more details from Haibike USA's Ken Miner.
Video: Haibike DWNHLL, XDURO and SDURO
No chairlifts in your neck of the woods? No problem with the new Haibike DWNHLL, a 200mm trail crushing e-mountain bike that's ready for multiple laps on the gnarliest of gnar. Component highlights include a Kashima-coated Fox 40 dual crown DH fork, and the industry-leading Bosch drive system with 500 Wh battery. The top of the line model comes in at $7000.
See More Photos »
For more trail bike-oriented adventures, check out the updated 27.5 XDURO, which won a 2017 Interbike Innovation of the Year award and comes with the new Yamaha PW-X motor that delivers more torque and improved cadence compliance, meaning you can spin up to 120rpm no problem. This $5000 e-rig rolls on plus-size tires and has 150mm of bump taming suspension. Typical range with the Yamaha 500 Wh battery is in the 40-100 mile range depending on mode use.
Finally, the latest 27.5 Haibike SDURO features Bosch's new internally-stored battery, which resides inside the downtube and can be charged onboard or off. This frees up space in the main triangle for a water bottle cage. You can also add a lock, tool bag, or even secure an extra battery, upping range to a whopping 1000 Wh. This bike has 120mm of suspension and sells for $5400.
Gallery: Haibike DWNHLL, XDURO and SDURO
[slider_pro id="1"]
For more info visit www.haibike.com
See More Photos »
[slider_pro id="1"]
