New Product: 2015 Shimano XTR 11-speed
Flagship mountain group revamped around 11-speed 11-40 cassette with 1x, 2x and 3x configurations
Brakes Components News Pedals Wheels
Shimano officially announced the long-anticipated release of a new 11-speed XTR mountain bike component group today in both Race and Trail tuned versions. The new XTR M9000 component group includes options for 1x, 2x and 3x front chainring combinations, a new cassette, brakes, front and rear derailleur, shifters, a chain, pedals and wheelsets.
Rhythmic, new 11-40 tooth 11-speed cassette
The new, mountain-specific 11-speed cassette is available in a single configuration Shimano calls a “rhythm step” progression of 11-13-15-17-19-21-24-27-31-35-40 tooth cogs. Depending on the size, the cogs are crafted from aluminum, titanium or steel and employ a carbon fiber gear carrier. Unlike the company’s 11-speed road cassettes, the mountain 11-speed works on existing Shimano 10-speed cassette bodies.
Shimano is putting a lot of faith in people wrapping their heads around the rhythm step concept, which essentially refers to selecting tooth counts that result in smooth groupings of gears within so-called power bands of pedaling cadence and effort that are about 30 rpms wide. Some of the gears work well for smooth pedaling—“driving gears” as Shimano calls them—while others make good climbing gears, either for steep pitches or technical ascents.
Complicit in making the system work are the front chainring tooth counts which have significantly changed from prior 2x and 3x versions to create adjacent and accessible gears within these usage bands. And while the math pencils out—and we think the logic of it will likely become intuitive on the trail—it does seem to bias the use of a front derailleur system over a 1x option.
1x, 2x and 3x chainring options
Shimano’s new crankset is modular and designed to accommodate 1x, 2x or 3x chainring configurations interchangeably. Essentially, you can go back-and-forth between the chainring configurations without buying new crank arms, though, obviously, shifter, derailleur and possibly chain changes are necessary.
Their long-awaited 1x option comes with 30-, 32-, 34- or 36-teeth, but unlike rival SRAM and other aftermarket manufacturers it does not use a narrow/wide tooth configuration. Instead, Shimano has opted for a new tooth profile that is uniformly wider and taller than on previous chainrings, and has a slightly hooked leading edge. The company claims the profile—when used with its Shadow Plus clutch derailleur—is at least as good as narrow/wide in terms of chain retention in rough terrain.
In an effort to make a more useable combination of gears, Shimano has changed their 2x and 3x tooth counts to better work with the rhythm step gearing. XTR trail uses a 36/26t combo, while XTR Race goes with 38/28t—a departure from the wider spreads of old. Shimano says the 10-tooth jumps makes for better front shifting as well as a more logical spread of gearing ratios. In 3x, Shimano goes to a 40/30/22t from a 42/32/24t combo on the old M985 set.
Cranking it up
Combining metals and carbon fiber ranks highly on the competency scale for Shimano and perhaps nowhere is it more advanced than on the company’s high-end HollowGlide chainrings which combine long-wearing titanium teeth with a lightweight carbon fiber and alloy structure.
The new chainrings mate only with the new XTR FC-M9000 Race and XTR FC-M9020 Trail Hollowtech II crank arms which have revised bolt patterns Shimano says makes for stiffer interface and more efficient power transfer. This also means old chainrings don’t work with the new crankset and vice-versa.
The Race and Trail cranksets are each tuned to their specific usage with the former being lighter and stiffer, and the latter spec’d to be a bit tougher. The Race version sports a narrow 158mm Q-factor and uses a 3D hollow bonded structure on the non-drive arm while the Trail cranks are cold forged for greater durability and have a standard 168mm Q-factor.
Back on the chain gang
More gears necessitate a narrower chain and Shimano has introduced the CN-HG900-11 to handle the duties. The chain works in all XTR chainring configurations and features the company’s HG-X11 asymmetric plate design. This design, in combination with an impregnated surface coating on rollers and inner plates called SIL-TEC, conspires to keep the moving parts smoother operating, quieter and longer lasting, according to Shimano.
Continue to Page 2 for more on Shimano’s new 11-speed XTR group and full photo gallery »
About the author: Don Palermini
Chicago-born Don Palermini became a cycling-based life-form in the sixth grade after completing a family road bike tour of his home state. Three years later he bought his first mountain bike to help mitigate the city's pothole-strewn streets, and began exploring the region's unpaved roads and trails. Those rides sparked a much larger journey which includes all manner of bike racing, commuting, on- and off-road bike advocacy, and a 20-plus-year marketing career in the cycling industry that landed him at his current gig with Santa Cruz bicycles. Now residing in the San Francisco Bay Area, his four favorite words in the English language are "breakfast served all day," together in that order.
(Visited 35,212 times, 1 visits today)
Wordpress Comments:
  • Mark M says:
    So disappointing. I love Shimano brakes, but this is no answer to SRAM’s 10-42 1x setup. Why would I want to reduce my gear range? And no, now that I’ve been on xx1 for a year, I will never have a front derailleur on a mtb again.
  • Benja says:
    I loveLOVELove my XTR brakes, but I also LOVE my XX1 now, and I really do not care for a front der on my bigger bike. Don’t miss it, don’t want it. XX1/XO1 works well. And yes, the new crankset looks mad budget.
  • bigfoot jr says:
    I don’t have to buy a new hub or have a clunky after market set up to get a 40t…SOLD!
  • Art says:
    I don’t see peoples problem with giving people options. If you don’t want a front derailleur, don’t use one, if somebody wants a 2 x 11, or 3 x 11, it’s their bike, they can do what they want. I’ll wait for the XT or even SLX version, but I’ll be glad to ditch all my Sram stuff. Shimano SLX 1 x 11 would be sweet.
  • Preston says:
    I love it – great gear spread on the back, and 30/40t up front is perfect. Now just need to provide a 20t option instead of 22t and I won’t have to put boutique aftermarket gear on my bike. Brakes look awesome. Definitely not psyched to have to buy new shifters, derailleurs, chains, and cassettes again, and have multiple bikes with incompatible drivetrains. Seems like much of the same thing could have been accomplished sticking with the 10 spd. But that wouldn’t sell new parts either.
  • Preston says:
    Oh I forgot about the 40t cog. No 20t needed even on a 29′er….sweet.
  • Tom says:
    Fantastic! I’ll be lining up for the XT version, when it’s released.
    2 x 11 on my race bike, 1 x 11 on the big squishy bike, and done!
  • Tom says:
    Although, really, I’d be happy with a Shimano 11/40 cassette in ten speed. I’m running that now, courtesy of One Up and their perfect 16t “freebie” cog, and it is perfect. No big 36 to 42 shift (which is a fine jump on the trail bike, but not on my race bike).
    • dave says:
      Exactly what I was thinking. A 10-speed 11/40 or 12/42 cassette from Shimano or SRAM would have been a product announcement I could get excited about.
  • Stan Suarez says:
    the best part is that SHIMANO’s 11-40 gear design will TRICKLE DOWN easily to it’s cheaper GRUPPOS while SRAM’s XD design isn’t cost-effective enough for lower priced sets.
  • Stan Suarez says:
    oh… why hasn’t anybody mentioned this…. THEM CRANKS LOOK FUGLY!!!!
  • Carl says:
    I have XTR brakes on all my bikes, XX1 drivetrains on 2 of them and a CLUNKER aftermarket XT 1X with Wolftooth front and rear and works fantanstic, they are only junk to those who dont know how to turn a wrench. Love my XX1s but most likely will not buy another considering you can do it for about 150 bucks now. LOVE XTR stuff but probably wont pay the XTR price for 1X with all the options out there now.
  • dada Juma says:
    What ever you say guys here in asia SRAM is not that popular still SHIMANO rules in every bike
  • Sean says:
    They so missed the boat on gearing for 1x. It’s hard enough to get a good spread on SRAM 1×11 with 10-42, and they go with 11-40?? Then only offer down to a 30T front? Forget it for anyone who rides steep terrain on a 29er.
    This has the feel of a company that’s out of touch with mountain biking. Maybe they should focus on road for the drivetrain, become a brake only company for MTB.
  • Chris says:
    Why have so many cogs on rear? I almost have my 3*8 (34 – 11) and i could pass everywhere.
  • docmannix says:
    I would like to comment on this as i broke my almost new 2016 xtr carbon lever i think its not that tough considering its price, i hope shimano will do something about this as i also read an article review mentioning about breaking it also thanks
