How to: Build a manual trainer
And how to use it
Video
Let’s face it. Pulling a manual, on a downhill and holding it for a minute is a cool trick indeed. To balance on that edge without pedaling, rocking back and forth is a skill seemingly for the elite descenders or those who grew up on two wheels.
But could there be an easier way to learn, to find that balance point and be at peace with it? Lately, the popularity of the manual trainer indicates that there might be a better way. You mount your own bike in the tilting cradle and lean back and search for that elusive balance point. A strap on the front wheel limits the movement should you lean back too far.
You get to learn and be comfortable of the balance point of your own bike. And it’s farther than you think.
The key advantage of this is it allows you to find the balance point of your own bike without consequence. Practice a few minutes a day and you develop the core muscles and the instinct to stay on the balance point.
The disadvantage is it’s still far from the actual experience of manualing and the key use of the brake lever to put the nose of the bike back down is not practiced.
Have you tried the manual trainer? What’s your take? How many out there have actually learned to manual well using the manual trainer?
A good discussion on our forums can be found here
Wordpress Comments:
