How To Reviews
How To: Buy your first mountain bike
Understand the various bike types and which components matter most
A quick breakdown of mountain biking disciplines and key features of bikes. Photo courtesy of Art's Cyclery
Understanding the various mountain biking disciplines will aid in your buying decision (click to enlarge). Photo courtesy of Art’s Cyclery
Editor’s Note: This article was written by Art’s Cyclery web content editor Brett Murphy, who uses his mechanical engineering background to explain the latest industry advances and breakdown component design. The original post can be found here.
So you’ve finally decided to add a little dirt to your life and buy a mountain bike? Awesome! It’s a decision you wont regret. Just know that the sport has a bit of a learning curve when picking out your new bike and its key parts, so best to educate yourself before heading to the bike shop or perusing the Internet. For starters it’s important to understand the various mountain biking disciplines and the key features of the associated bikes. Local terrain and riding style will go a long way in determining the kind of bike you need. But in general mountain bikes can be categorized into three primary categories; cross-country, trail/all-mountain and freeride/downhill. Here is a rundown of each.
XC bikes are weight conscious and have suspension travel between 80 and 120mm. Photo courtesy of Art's Cyclery
XC bikes are typically lighter and have suspension travel between 80mm and 120mm (click to enlarge). Photo courtesy of Art’s Cyclery
Cross Country
Cross country riding typically consists of fire roads and singletrack that’s geared primarily toward a rider’s endurance and power output. While still requiring a fair amount of technical skills, cross country is more about efficiency and suffering than other MTB disciplines. Cross country bikes are typically lighter and usually have suspension travel between 80mm and 120mm. For years, cross country was the sole domain of the hardtail (no rear suspension), but today there are many snappy handling and fast-pedaling full suspension designs available. This additional travel provides a more supple ride at faster speeds, but usually adds some weight and expense. Road riders will likely feel most at home riding cross country, with its focus on higher cadence, clipless pedals, and less challenging terrain. Cross country bikes also have geometry that more closely resembles road bikes.
For many — if not most — new mountain bikers the optimal first bike is a hardtail XC machine, which are typically more affordable than their full suspension brethren.
For many — if not most — new mountain bikers the optimal first bike is a hardtail XC machine, which are typically more affordable than their full suspension brethren (click to enlarge).
Best to look at both hardtail and full suspension bikes when doing your pre-purchase research. As mentioned above, full suspension bikes are typically more capable on more technical terrain and can still climb fairly well. But they’re likely to be heavier, more expensive and more difficult to maintain. That’s why many new riders start out on hardtail mountain bikes, which are often the most affordable on the bike shop floor.
Trail and all-mountain bikes have slacker angles, longer wheelbases, and travel ranging from about 140 to 170 millimeters. Photo courtesy of Art's Cyclery
Trail and all-mountain bikes have slacker angles, longer wheelbases, and travel ranging from about 140mm to 170mm (click to enlarge). Photo courtesy of Art’s Cyclery
Trail/All-Mountain
Bigger drops, rock gardens, and more technical, winding trails usually require a bike with more travel than your average cross-country bike. That’s where the trail and all-mountain bikes come in. For this style of riding, pedaling efficiency is not a premium, although a good trail or all-mountain bike will still pedal uphill well. Full suspension bikes are a must for this style of riding, and these bikes have slacker angles, longer wheelbases, and travel ranging from about 140mm to 170mm, with trail bikes falling on the shorter end and all-mountain pushing up to the 170mm mark. Most new mountain bikers will fall into this category, where the bikes can climb capably and help keep you out of trouble when the trail gets technically tough.
Downhill bikes have around 200mm of supple travel for big drops and absorbing violent impacts at high speeds. Photo courtesy of Art's Cyclery
Downhill bikes have around 200mm of travel that’s meant to handle big drops and absorb violent impacts at high speed (click to enlarge). Photo courtesy of Art’s Cyclery
Downhill
Beginner mountain bikers should probably steer clear of downhill bikes, which are all about carrying as much speed as possible through obstacles that might appear to be more of a cliff than a trail. Downhill bikes have around 200mm of travel that’s designed to handle big drops and absorb violent impacts at high speeds. These bikes are typically geared strictly for going fast downhill ( seven speeds of low gearing) and don’t offer much in terms of climbing or even flat trail performance. Most downhillers also have a cross country or trail bike for days when they feel like a more rounded workout. Downhill bikes have very slack head angles (down to 63 degrees), long wheelbases, and do not handle well when climbing.
Continue to page 2 to learn about the key components when buying a mountain bike »
About the author: Paul Andrews
Dividing his time between Seattle and Santa Cruz, career journalist Paul Andrews has more than a quarter century of mountain biking under his belt, which he wishes had a few less notches.
Wordpress Comments:
