Reviewed by Brian Mullin aka Gram and MTBR.com Pastajet
http://www.gramslightbikes.com/
The new Morro hydration pack from Hydrapak is a glorious and comfortable pack, with a plethora of new features, which are very innovative and incredibly functional. The Morro is part of Hydrapak’s new Pro Series. The Pro Series constitutes their best design philosophy, features, materials and construction.
Features
Surge Valve
The foremost new feature for me as a longtime Hydrapak user, is that they finally solved their heinously leaky bite valve! The new Surge Valve doesn’t leak, has a twist shutoff, an adjustable angled elbow, it bites and draws well, and just plain rocks. They hit the nail on the head with this winner, and they have leaped to the top of the food chain for bite valves by a large margin!
Quantum Clip
The drinking hose also attaches with an innovative system called the Quantum Clip (no more Velcro), which uses a magnet clip on the hose, and an adjoining metal piece on the chest compression strap. It takes a bit of practice to get used to the system, but you just drop the hose clip easily on the proper spot with a distinct snap. It also prevents the hose from flopping around when you are bouncing along on rough terrain, which I had always found a bit annoying with hydration packs, in fact, I used to tuck the bite valve under the compression strap to prevent that from happening. One of Hydrapak’s statements about the Quantum Clip is, “keep your hose in check”, I am not even going to touch that one!
Too many zippers, zippers fail over time. Would be better with less expensive buckles.
