Industry Nine expands fat bike range, adds center lock hubs
New BigRig 760 pair I9 hubs and alloy spokes with HED’s BAD alloy rim
Components Fat Bike News Wheels
The HED BAD rims utilize a single wall construction that is optimized for tubeless setup and have an inner diameter of 76.0 mm (hence the name).
The 76mm inner diameter HED BAD rims utilize single wall construction that is optimized for tubeless setup.
Industry Nine’s BigRig family has grown to four with the launch of the new 760 platform. This wheelset combines their American-made hubs and alloy spokes with HED BAD alloy rims to create a complete wheelset that weighs as little as 2150 grams depending on axle configuration. For comparison, that’s almost a pound lighter than some of our favorite alloy fat bike wheels and exactly the same claimed weight as the new Reynolds Dean carbon fat bike wheels.
The new I9 wheelset is available with 170mm or 190mm rear hub spacing, six different end caps options for the front wheel, and either a Shimano HG or SRAM X1 freehub. You can also choose from 11 hub and spoke color options, including pink, purple, turquoise (pictured), and lime.
Industry Nine BigRig 760 Wheelset
  • 2150 grams, depending on specification
  • HED Big Deal Aluminum, 80mm outer, 76mm inner, 640g
  • Front Hub Endcap Options: 135QR, 10×135 rear-offset, 15×135, 15×142, 15×150
  • 170mm Rear Hub Endcap Options: 170QR, 10×170, 12×177
  • 190mm Rear Hub Endcap Options: 190QR, 12×190, 12×197
  • Shimano HG or SRAM XD1 freehub: 3 degree/120 POE/6 pawl
  • Hub and Spoke Color Options: black, red, silver, blue, gold, orange, pink, purple, turquoise, green and lime
  • MSRP starting at $1495
Industry Nine has also released new center lock versions of their Torch Classic mountain bike hubs. These share the same internals and are virtually identical to their standard hubs. Weight for the front hubs range from 130-135 grams, while the rears weigh 260-265g depending on axle configuration. As with all I9 hubs, these are available in 11 anodized color options.
When given the option, ano purple is always the correct choice.
When given the option, ano purple is always the correct choice (click to enlarge).
Torch Boost Classic Mountain Center Lock Front Hub
  • 28- or 32-hole drillings available
  • ~135g depending on axle/bearing spec
  • 15×110 Boost axle spacing
  • Color options: black, red, silver, blue, gold, orange, pink, purple, turquoise, green and lime
  • MSRP: $190
Torch Classic Mountain Center Lock Rear Hub
  • ~260g depending on axle/bearing spec
  • 12×142 or QR135 endcap options
  • MSRP: $385
Torch Boost Classic Mountain Center Lock Rear Hub
  • ~265g depending on axle/bearing spec
  • 12×148 Boost axle spacing
  • MSRP: $385
For more information visit www.industrynine.net.
Wordpress Comments:
