American Classic - Interbike 2009
American Classic has updated their mountain bike wheelset with a few new tweaks. Foremost is that the rim is now tubeless. I have a set of their All Mountain wheels, and I have used a rim strip to run them tubeless, and it was hit and miss getting tires to work. So the new tubeless rims are a welcome change. The rims come in either white or black, while the hubs are a very cool red! The new rims are wider, deeper and lighter, and the new geometry has increased stiffness. They come in both 26 and 29 inch sizes.
I had a very nice technical walk through of the new wheels by the President, founder, engineer and techno geek Bill Shook. Bill led me through some interesting engineering features of their products that relate to the wheels. The IS disc brake interface posts on the hub are slightly raised, which aids keeping the rotors from getting warped.
Instead of using brass nipples Bill uses aluminum nipples, which are extremely lightweight and hence reduce rotational weight. He extended the body of the nipple so that the threads go slightly past where the nipple is cradled in the rim, so that the nipple is held in compression instead of tension, which reduces fatigue and breakage.
While I was at their booth Jenny Fletcher, their sponsored triathlete was signing autographs, so I got one for my daughter, and of course I got one for my basement bike shop! Jenny was really nice, and down to earth, and we yakked on about training and such.
September 28th, 2009 at 8:22 am
Any weights for the wheelset?
September 28th, 2009 at 9:56 am
Hi! The tubeless 26″ pair is 1486 grams and tubeless 29″ pair is 1600 grams (less than our 09 wheelset!) This is for the QR geared style set. We have singlespeed, 15mm t/a etc., too!
September 30th, 2009 at 10:02 am
Will there be a MTB 29 tubeless 20mm t/a option. Currently the only t.a option is with the heavy all MTN 29 wheelset.
October 9th, 2009 at 12:10 pm
Hi, how much wheels cost? Where i can buy it?
October 11th, 2009 at 11:38 pm
Question: Will there be a MTB 29 tubeless 20mm t/a option. Currently the only t.a option is with the heavy all MTN 29 wheelset.
Answer: Their is a 29 version with a 15mm thru axle, but it would have to be a special order to get the 20mm hub for the new wheels.
Question: Hi, how much wheels cost? Where i can buy it?
Answer: Not sure, I can look into it, but you might be better off contacting AC directly, I would guess around MSRP of $775
