Ergon GR2 Grips and Ergon BD1 Backpack
Sunday October 7th, 2007 at 12:53 AM
Posted by: Francois
Ergon Booth
Ergon green. That color stands for unique design and functional mountain bike products. They look a little different and the promise is that they work better for your body. Let’s put two of their products to the test.
Ergon GR2 grips Ergon BD1 Backpack side
The first product is the the Ergon GR2 grip. Now, I sought out this product out of necessity. About a month ago, I lost feeling in my left ring finger. This was then followed by pulsing pain down my forearm. After an x-ray and an EMG nerve test, it was determined that I pinched my ulnar nerve near my wrist. There was no accident but I suspect riding a rigid fork for over a year has a lot to do with this injury. The shock of the rigid fork traveled through my grips and compressed my ulnar nerve. It turns out this is a fairly common bike injury and is often called ‘handlebar palsy’.
So with that information, I figured out how to avoid the stress on my hands. Of course I put on a suspension fork on my 29er singlespeed bike. But I also found out about at Ergon Grip and glove system. The grips are made of soft rubber and flare out on the outside to distribute the load across a wider surface of the palm. Also, the GR2 model offers bar ends. Just when I thought the bar end was dead, it has resurfaced in a much leaner and more integrated form. The bar end on the Ergon grips seem perfectly shape with a curve on the outside following the curvature of the hand. Also the tips of the bar ends flatten out and make it natural to rest the thumb on it. Finally, at the bottom of the bar end are nice indentations where the tips of my fingers can rest and get a grip.
Ergon GR2 grips Ergon GR2 grips Ergon GR2 grips Ergon GR2 grips
Ergonomic indeed but how does it ride? The first few rides are key since it is critical to get the angle of the grips right. These grips will force you to ride at the angle of the grips so you want them positioned at the natural angle of your hand. Once positioned, my hands felt very comfortable and I didn’t feel (or have the choice to roll my wrist up or down).
Ergon GR2 hand positions Ergon GR2 hand positionsErgon GR2 hand positions Ergon GR2 hand positions
Riding on level terrain was a dream. My hands felt natural as the shock of the trail was muted as more of my palm was in contact with the bar. When climbing, it felt good as well. The bonus of the bar end was it gave me a couple of new positions. First was at the ends of the handlebars and then holding the bar ends themselves shifted my weight forward and gave me extra climbing leverage. In the singlespeeding world, it is often said that having bar ends is like having an extra gear. This is actually true as the extra reach allows you to pull on the bars a little easier and turn the pedals. In addition, just having different positions available allows you to distribute the load to different parts of your hand and prevent injury.
But how was it descending? Well here’s the compromise. Ergon grips don’t descend as well as normal grips. The biggest issue is you can’t wrap your hands around the whole grip. Thus, you get the feeling that your grip is not as secure. There is a bit of a learning curve as well and you should allow yourself a couple descents to get used to the new grip position. The bar ends actually help since they provided me more area to rest the ends of my hands and ensure I had a good grip on the handlebar. I think most XC riders will not have a problem descending with these grips at all. But downhillers and dirt jumpers will probably stick with standard grips.
Ergon BD1 Backpack
This backpack is big and it’s meant to carry big loads. That is its strength and weakness. If you like to carry a 10 lb backpack with water, food and tools to rebuild a bottom bracket on the trail, then look no further. The biggest problem with big packs is they tire your shoulders and they interfere with your nimbleness and maneuverability.
Ergon BD1 Backpack Ergon BD1 Backpack sideErgon BD1 Backpack weight
Ergon tries to solve this in two ways. First, the BD1 takes the load off your shoulders and onto your hips. Second is they’ve integrated a pivot-ball shoulder mount so the pack stays straight even as your upper body goes through all kinds of singletrack-induced contortions. Fitment is critical so the pivot-ball can be adjusted up or down to ensure that the shoulder-straps are in the ideal position in relation to the waist straps.
The pack itself weighs 2.33 lbs when empty. It has a nylon frame and has an assortment of straps. There is stretchable sleeve inside that can take differerent sized water bladders. Also, there is a helmet retention cover on the outside that can be removed when not in use. It’s a nice feature but can get in the way of accessing the inside of the pack.
Does it work? Oh, yes. I’ve ridden with it and there was hardly any tension on my shoulder straps. When properly adjusted, the weight is really carried by the hips. And riding through twisty descents, the pack was not a bother at all. It just felt centered back there with none of the usual weight shifts and flopping around of a heavy pack. I was liberating. Another bonus seemed to be that the pack was lifted off my back a little bit by the pivot-ball mechanism. This allowed more ventilation on those hot days.
Ergon BD1 Backpack Ergon BD1 Backpack Ergon BD1 Backpack
And who’s it not for? If you don’t carry a lot of stuff and prefer a 5 lb water carrier, then look elsewhere. Also, this can get rather pricey at $140 and that’s without a water reservoir. If you are bothered by a big waist strap, there is a possibility you might not like this pack. So load it up and test-ride it first to see how you like it.
Handlebar Palsy - http://www.hughston.com/hha/a_15_3_2.htm
Ergon - http://ergon-bike.com/
Share and Enjoy: These icons link to social bookmarking sites where readers can share and discover new web pages.
  • Digg
  • del.icio.us
  • Netvouz
  • DZone
  • ThisNext
  • MisterWong
  • Wists
  • New Park Tools for 2008
  • Salsa Cycles Gordo rims, 2008 Mamasita and Salsa Clothing
  • KMC Chain X-SL and Singlespeed Chain
  • Outdoor Demo Video - Day 2 Highlights
  • Smith Optics video
  • Cranks Bros
  • Miscellaneous finds at Interbike
  • Ergon GR2 Grips and Ergon BD1 Backpack
  • Wicked Racin’s Dualrailleur Guide
  • Look Quartz Mountain Pedal and Look 586 Road bike
  • Moots Mooto-XZ 29er
  • Felt Nine Pro, Nine Elite, Nine Comp, and Nine Solo
  • New ways to tension the chain
  • Exposure Lights Joystick MaXx and Enduro MaXx
  • Unique Finds at Interbike
  • Delta 7 Arantix Bike
  • Magura Shocks and Forks
  • DT Swiss Carbon Wheels, Shocks and Forks
  • KCNC Cogsets and Brakes
  • Ashima Rotors
  • Lezyne Product Introduction
  • Chumba Racing XCL
  • Cane Creek Double Barrel
  • Santa Cruz 2008 Chameleon and Stigmata cyclocross bike
  • Chris Cocalis of Pivot Cycles
  • Rase adjustable seatpost
  • Raxter bike folding rack demonstration
  • BMC Pro bike team interview
  • BMC 2008 mountain bike intro by Scott Thomson
  • Ahrens Bicycles and Ahrens Wisecracker
  • 650b love
  • Women’s Specific Bikes at Interbike
  • Interbike Hotties round 3: Impy’s list
  • Zoic Women’s Cycling Clothes Are a Huge Hit
  • Women’s Jerseys at Interbike
  • 2008 Raceface Carbon cranks and components
  • 2008 BMC Road, Cross and Mountain Bikes
  • IBIS Cycles Mojo SL and Tranny
  • 29er Tires
  • CST Making the Push
  • Moots Mooto-XZ
  • Tire Balls
  • Maxxis Tires 2008
  • X-Fusion Forks and Shocks Video
  • Spot Bikes belt-drive Carbon Drive System bikes
  • New Tires for ‘08–Part 1 and Tread Design vs Riding Style (Updated)
  • Adidas Eyewear Video
  • Tiny Rider, Big Wheels
  • Felt gets fixed
  • Interbike hotties part deux
  • Niner Bikes Jet 9, Titanium bike and WFO
  • Versus Cycles introduces several models
  • Unusual Offerings by Rue Sports
  • Knolly V-Tach wins Mtbr Best Of award for Freeride Category
  • Carver Bikes
  • Interbike Booth Babes!
  • Turner Bikes Video - 2008 New Bikes!
  • Pivot Cycles - Mach 4 and Mach 5
  • Banshee Bikes: Rune - Wildcard - Scythe
  • Intense SS (Slope Style)
  • Hayes Stroker
  • Felt Nine:C1 Prototype. 2.4 lb 29er carbon bike
  • Rocky Mountain Flatline prototype
  • Cervelo R3
  • 2008 SRAM Red road group
  • Outdoor Demo Video - Day 1 Highlights
  • 2008 Trek Fuel EX and Trek 69er
  • Knolly Bikes Endorphin and Delirium
  • Interbike Booth Babes - Day 1
  • 2008 Litespeed Obed 29er
  • 2008 Shimano XT
  • MEET BOB ROLL AT INTERBIKE!
  • Spyder Freeryde Leaves a Mark at Interbike
  • Tour de France Champion Alberto Contador to Attend Interbike
  • Niki Gudex & Julian Absalon Meet and Greet at Interbike
  • Interbike 2007 Bike Industry Tradeshow
  • Interbike OutDoor Demo Attendees Invited to Participate in Tour of Lake Mead Ride
  • Tech Clinics and Seminars at Interbike 2007
