Exposure USA releases the new Diablo and Toro LED lights
James Penfold from Exposure USA showed us the exciting new lights in their line up. The Diablo is about the same size as the old Joysick light. It has a bigger head to accomodate the Seoul P7 LED emitter and the rear of the light is flared out as well to balance it out. It is ultralight at and is not much heavier than the 97 gram joystick. Yet, it almost 3x as bright at 700 lumens claimed output (Joystick was 240 lumens). The beam pattern has a wide and clear halo and a powerful spot in the middle for throw (visiblity at longer distances). This light can be mounted on the bar or helmet using the same mounting hardware as the Joystick.
There will be three light levels and the highest level of 700 lumens will only deliver 1 hour of run time. But a piggyback battery can be hooked on to double the run time. 700 lumens is about the same brightness as their old Exposure Maxx light with three LEDs.
MSRP for the Diablo is $250. The Toro is a similar light but with a larger casing to accomodate a bigger battery. Light levels will be the same but the run time will be at least double the Diablo’s.
