Yeti ASR 5 Carbon - Ride Impressions
Tuesday September 22nd, 2009 at 7:19 AM
Posted by: Brian Mullin
Yeti ASR 5 C
Yeti ASR 5 C
The ASR 5 (5 inch suspension) is a brand new bike for Yeti, and this was the first time I had seen this model. The ASR 5 comes in an aluminum version, and a full carbon version, which is what I tested. The moment I started pedaling this bike, I felt its instant acceleration and laser like steering and handling. Its suspension was very compliant, and the directional rigidity of the carbon material was paramount in the feel of the bike.
Yeti Carbon!
I found myself sitting in almost all the terrain the XC loops of Boulder City had to offer, and was amazed at how well the suspension just sort of floated along the undulations and rocky sections of the trail. This did not feel like a 5 inch travel bike. On one of the very steep and very loose climbs the bike went up it effortlessly, and needed very little pedaling to get to the top. This is an excellent bike, that has a carefully thought out suspension system, with an incredible amount of compliancy. It is very neutral, climbs like a demon and makes the most of the carbon material’s directional rigidity and vibration damping qualities.
Yeti - Very nicely done cable layout
http://www.yeticycles.com/#/bikes/ASR5Carbon/
Specs:
Travel - 5 inch
Weight - 4.75lbs
Sizes - small. medium, large
Colors - black/turquoise or white/black
Rear shock - RP23 (7.875 x 2)
Bottom Bracket - 73mm
Rear wheel - 135mm with QR or 142mm with 12mm
Front Derailleur - 34.9mm with traditional mount
Seatpost - 30.9mm
Kits Enduro, Race, Pro
Features:
- High Modulus, hand laid-up carbon front and rear triangles
- Tapered headtube 1 1/8 to 1 1/5
- Gravity dropper cable guide
- Interchange dropouts
- Titanium hardware
- Internal cable routing on swingarm
Tags: , ,
12 Responses to “Yeti ASR 5 Carbon - Ride Impressions”
  1. Mike Says:
    Three questions:
    1. Can a 2.4 rear tire fit without rubbing on the frame ?
    2. Is the headtube a flared 1 1/8 to 1 1/2 headtube ?
    3. Is the geometry the same as the current Yeti 575 ?
  2. PeeWeeisonLeno Says:
    What has better suspension performance - the DW bikes(Ibis, Turner, etc) or this new Yeti ?
  3. bp Says:
    to mike,
    1. maybe, depends on the tire.
    2. yes
    3. NO!
  4. Brian Mullin Says:
    It depends on what you mean by suspension performance, that is a big can of worms. The Yeti has a pretty sweet suspension system, it climbs loose terrain better than the Mojo, while the Mojo does better climbing embedded rocky terrain. I did not get enough time for anything more than a ride impression, so I will be doing a long term review of the Yeti in the Fall. Every interpretation of the DW Link is very different, so I cannot make a broad statement on all those bikes that are designed with it. The Yeti optimized Active Suspension (A.S.) is a very nice design, it is not better nor worse than the DW Link, it is just a different, and it has a whole set of its own characteristics and attributes.
  5. Roy Says:
    Did you get to see the Alloy version of the ASR5? Did they talk about any of the build packages? I hear the Carbon is frame only where as they have different build options on the ASR5 (alloy). Doesn’t mean they won’t have build packages. Sounds like this thing would be a great race bike that you can train on and do longer rides on as well with the added travel. One bike that can do all your XC needs.
  6. Eric Says:
    Is that a Fox F100 or F120 fork? I was just wondering if you can set up the AS 5C with a 4″ fork.
  7. Brian Mullin Says:
    It came with a 120. I would prefer a Fox Talas myself, and use it in the 130 mode for most riding and slap it into 150 for downhilling.
  8. rick Says:
    How much does the bike and or frame weight?
  9. Mike Says:
    @Brain,
    Thx for the response ! :-)
    What is the geometry on the bike ? Is it going to have a 69 degree head angle ?
    Any hints from Yeti when the frameset is going to go on sale ?
  10. Brian Mullin Says:
    Refer to http://www.yeticycles.com/#/bikes/ASR5Carbon/ they just revamped their website since the show!
    The head angle is 67 degrees for a 140mm fork and 68 for a 120mm fork.
    They should be on sale late Fall to early Winter? Suggest you contact your LBS or Yeti themselves for a better date?
  11. Garry Klassen Says:
    I have a Yeti 575 and bought it after a test ride. The new ASR 5 sounds so good I’m afraid to test ride it, but I will the first chance I get. The carbon sounds awsome and if you go that route I would go with light wheels like XTR. Glad to hear MTBR got to test it at Interbike and it got such a good review. Thanks.
  12. John Nelson Says:
    Brian,
    excellent review! I was sooo hoping someone was going to have the chance to ride and review this bike when i heard it was going to be at interbike. I will anxiously be waiting for the full review! I had the same question as PeeWeeisonLeno; how did it compare to the Mojo SL? I will try and fight off the itch to buy anything before i hear more, as its near impossible i will ever i have the chance to test ride either of these bikes (grrrr!).
  • Kind Shock - Interbike 2009
  • X-Fusion Shox Interbike Virtual Trade Show Booth 2009
  • Pastajet’s Interbike 2009 Top 5
  • Ergon Interbike Virtual Trade Show Booth 2009
  • Motobecane U.S.A. Interbike Virtual Trade Show Booth 2009
  • Lupine Lighting Systems Interbike Virtual Trade Show Booth 2009
  • Jamis Bicyles Interbike Virtual Trade Show Booth 2009
  • Pedro’s Interbike Virtual Trade Show Booth 2009
  • Ritchey Design Interbike Virtual Trade Show Booth 2009
  • Syncros Interbike Virtual Trade Show Booth 2009
  • Trigon USA makes their Interbike Debut
  • Cane Creek Double Barrel - updates and improvements for 2010
  • Cannondale Flash! 16.5 lbs carbon hardtail
  • Park Tool Interbike Virtual Trade Show Booth 2009
  • GT 2010 Sensor
  • GT prototype - New Ruckus 7!
  • Diamondback Interbike Virtual Trade Show Booth 2009
  • KHS Interbike Virtual Trade Show Booth 2009
  • Race Face Interbike Virtual Trade Show Booth 2009
  • Kona Interbike Virtual Trade Show Booth 2009
  • Pivot Cycles Interbike Virtual Trade Show Booth 2009
  • Hayes Bicycle Group - Interbike 2009
  • Pedro’s - Interbike 2009
  • Velocity - Interbike 2009
  • BH Bikes Interbike Virtual Trade Show Booth 2009
  • True Precision Interbike Virtual Trade Show Booth 2009
  • Turner Bikes Interbike Virtual Trade Show Booth 2009
  • Formula Disc Brakes Interbike Virtual Trade Show Booth 2009
  • Garmin, Hope, Maxxis, Continental - Interbike 2009
  • Marin Bikes - 2010 Mount Vision
  • Marin Bikes - 2010 Attack Trail
  • CamelBak 2010 lineup - Podium Ice bottle, Flow Meter, Velo Bak, and the Don
  • Rotor Bike Components - Interbike 2009
  • Gore Bike Wear - Alp-X Jacket and Xenon Lady Sonic Bib Tight
  • Giro-Easton-Blackburn Interbike Virtual Trade Show Booth 2009
  • Knolly Bikes - 2010 Podium
  • Panaracer Interbike Virtual Trade Show Booth 2009
  • Gu Energy Interbike Virtual Trade Show Booth 2009
  • Rocky Mountain Flatline World Cup
  • Rocky Mountain Altitude 29
  • Metrigear Vector Pedal-based Power Measurement Device - Interbike 2009
  • Uvex XP100 helmet video - Interbike 2009
  • Nema Digi Jersey and Gloves and Telonix Shorts
  • Montague Paratrooper folding bike
  • New Twenty6 Prerunner Pedal
  • Deuter USA hydration packs - Commuter Cross Series
  • Intense SlopeStyle II
  • Intense Tracer 29 and other new bikes!
  • Titus Rockstar 29er
  • Foes Racing B-29
  • Foes 2010 FXR
  • Fuji Bikes Interbike Virtual Trade Show Booth 2009
  • Knolly Interbike Virtual Trade Show Booth 2009
  • WTB Interbike Virtual Trade Show Booth 2009
  • Chumba Racing Interbike Virtual Trade Show Booth 2009
  • Fox Racing Shox Interbike Virtual Trade Show Booth 2009
  • Ibis Interbike Virtual Trade Show Booth 2009
  • Ashima - Interbike 2009
  • UFO Plast - Interbike 2009
  • American Classic - Interbike 2009
  • GoPro HERO HD - First Look
  • Norco Interbike Virtual Trade Show Booth 2009
  • Felt Interbike Virtual Trade Show Booth 2009
  • Look Interbike Virtual Trade Show Booth 2009
  • Exposure USA releases the new Diablo and Toro LED lights
  • Edge Interbike Virtual Trade Show Booth 2009
  • Ellsworth Interbike Virtual Trade Show Booth 2009
  • SRAM Interbike Virtual Trade Show Booth 2009
  • Santa Cruz Bicycles Interbike Virtual Trade Show Booth 2009
  • Ibis - Interbike 2009
  • Moots - Interbike 2009
  • DT Swiss Interbike 2009
  • Cannondale Shows New High Tech Suspension Technology: SIMON
  • Banshee Spitfire
  • Panaracer Unveils Cedric Gracia Signature Tires, CG XC 2.1, Today
  • Electra Ticino 20D - hand built style
  • New Haro Sonix 650B
  • Updated WTB Tire pics
  • Happy Medium (better pics)
  • Larry Leads the Way for the Pugsley
  • New Hans Ray and Eric Carter Signature Tires from Kenda
  • Reworked Weirwolf Leads WTB Tire Lineup
  • Yeti ASR 5 Carbon - Ride Impressions
  • Pivot Firebird - Ride Impressions
  • Ibis Mojo HD - First Look
  • Titus FTM Carbon - Ride Impressions
  • Gary Fisher Rumblefish - Ride Impression
  • Giant Faith - back again!
  • Giant Reign X
  • Interbike Hotties!
  • Titus X Carbon
  • Titus FTM Carbon
  • New from Banshee Bikes - Spitfire
  • First day at the 2009 Interbike Outdoor demo
  • Interbike Preview - Santa Cruz and Canfield 29ers At Bootleg Canyon
  • RACE FACE, PINKBIKE AND ROCKY MOUNTAIN PRESENT INTERBIKE BREAKER BREAKER 09 - LIVE FROM LAS VEGAS
  • LIVE: Cyclist vs. Motorcycle in Paris at Hutchinson Booth #3375
  • Interbike and Bikes Belong Invest $50,000 to Enhance Bicycling in Las Vegas
  • Kona and IMBA Fundraising Raffle at Interbike
  • Meet Chris Carmichael at Interbike!
  • Tell Mtbr What YOU Want To See from the Show!
  • ZOIC® iPod® Giveaway at InterBike Gets Dealers in the Groove
  • Urban Legend Fashion and Art Show is Back for Second Year at Interbike 2009
  • 2009 Exhibitor List On Par with Last Year - Major Exhibitors Returning
  • Begin Interbike 2009 Coverage
